RTEMS 7.0-rc1
uarts.c File Reference
Console driver for GUMSTIX. More...
#include <bsp.h>
#include <rtems/libio.h>
#include <termios.h>
#include <rtems/bspIo.h>
#include <pxa255.h>
#include <libchip/serial.h>
#include <libchip/sersupp.h>
#define NUM_DEVS   1
console_tblBSP_get_uart_from_minor (int minor)
unsigned long Console_Configuration_Count = NUM_DEVS
const console_fns ffuart_fns
console_tbl Console_Configuration_Ports []
This driver uses the shared console driver in bsps/shared/dev/serial/legacy-console.c
Variable Documentation
◆ Console_Configuration_Count
The number of serial ports defined in Console_Configuration_Ports
◆ Console_Configuration_Ports
console_tbl Console_Configuration_Ports[]
Initial value:
"/dev/com0",
SERIAL_CUSTOM,
&ffuart_fns,
NULL,
NULL,
0,
0,
NULL,
FFUART_BASE,
0,
0,
NULL,
NULL,
NULL,
NULL,
0,
0
The statically configured serial port information tables which are used to initially populate the dynamic tables.
