RTEMS 7.0-rc1
libio.h
2
15/*
16 * COPYRIGHT (C) 1989, 2021 On-Line Applications Research Corporation (OAR).
17 *
18 * Modifications to support reference counting in the file system are
19 * Copyright (C) 2012 embedded brains GmbH & Co. KG
20 *
21 * Copyright (C) 2025 Contemporary Software
22 *
23 * Redistribution and use in source and binary forms, with or without
24 * modification, are permitted provided that the following conditions
25 * are met:
26 * 1. Redistributions of source code must retain the above copyright
27 * notice, this list of conditions and the following disclaimer.
28 * 2. Redistributions in binary form must reproduce the above copyright
29 * notice, this list of conditions and the following disclaimer in the
30 * documentation and/or other materials provided with the distribution.
31 *
32 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
33 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
34 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
35 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
36 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
37 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
38 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
39 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
40 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
41 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
42 * POSSIBILITY OF SUCH DAMAGE.
43 */
44
45#ifndef _RTEMS_RTEMS_LIBIO_H
46#define _RTEMS_RTEMS_LIBIO_H
47
48#include <sys/types.h>
49#include <sys/stat.h>
50#include <sys/ioccom.h>
51#include <sys/statvfs.h>
52#include <sys/uio.h>
53
54#include <unistd.h>
55#include <termios.h>
56
57#include <rtems.h>
58#include <rtems/fs.h>
59#include <rtems/chain.h>
60#include <rtems/score/atomic.h>
61#include <rtems/termiosdevice.h>
62
63#ifdef __cplusplus
64extern "C" {
65#endif
66
67struct knote;
68
89);
90
100);
101
105typedef struct {
109 const char *path;
110
114 size_t pathlen;
115
120 const char *token;
121
126 size_t tokenlen;
127
140 int flags;
141
148
157
163
170
180);
181
196 const rtems_filesystem_location_info_t *parentloc,
197 const rtems_filesystem_location_info_t *targetloc,
198 const char *name,
199 size_t namelen
200);
201
215 mode_t mode
216);
217
232 uid_t owner,
233 gid_t group
234);
235
253);
254
264);
265
284 const void *data
285);
286
303);
304
318);
319
337);
338
356 const rtems_filesystem_location_info_t *parentloc,
357 const char *name,
358 size_t namelen,
359 mode_t mode,
360 dev_t dev
361);
362
375 const rtems_filesystem_location_info_t *parentloc,
377);
378
392 struct timespec times[2]
393);
394
410 const rtems_filesystem_location_info_t *parentloc,
411 const char *name,
412 size_t namelen,
413 const char *target
414);
415
430 char *buf,
431 size_t bufsize
432);
433
449 const rtems_filesystem_location_info_t *oldparentloc,
451 const rtems_filesystem_location_info_t *newparentloc,
452 const char *name,
453 size_t namelen
454);
455
469 struct statvfs *buf
470);
471
480 rtems_filesystem_are_nodes_equal_t are_nodes_equal_h;
489 rtems_filesystem_fsunmount_me_t fsunmount_me_h;
495};
496
502
510);
511
519);
520
529);
530
537 const rtems_filesystem_location_info_t *parentloc,
538 const rtems_filesystem_location_info_t *targetloc,
539 const char *name,
540 size_t namelen
541);
542
558);
559
566 const rtems_filesystem_location_info_t *parentloc,
567 const char *name,
568 size_t namelen,
569 mode_t mode,
570 dev_t dev
571);
572
579 const rtems_filesystem_location_info_t *parentloc,
581);
582
590 mode_t mode
591);
592
600 uid_t owner,
601 gid_t group
602);
603
611);
612
618);
619
626 rtems_filesystem_mount_table_entry_t *mt_entry, /* IN */
627 const void *data
628);
629
636 rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
637);
638
645 rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
646);
647
655 struct timespec times[2]
656);
657
664 const rtems_filesystem_location_info_t *parentloc,
665 const char *name,
666 size_t namelen,
667 const char *target
668);
669
677 char *buf,
678 size_t bufsize
679);
680
687 const rtems_filesystem_location_info_t *oldparentloc,
689 const rtems_filesystem_location_info_t *newparentloc,
690 const char *name,
691 size_t namelen
692);
693
701 struct statvfs *buf
702);
703
729 rtems_libio_t *iop,
730 const char *path,
731 int oflag,
732 mode_t mode
733);
734
746 rtems_libio_t *iop
747);
748
763typedef ssize_t (*rtems_filesystem_read_t)(
764 rtems_libio_t *iop,
765 void *buffer,
766 size_t count
767);
768
785typedef ssize_t (*rtems_filesystem_readv_t)(
786 rtems_libio_t *iop,
787 const struct iovec *iov,
788 int iovcnt,
789 ssize_t total
790);
791
806typedef ssize_t (*rtems_filesystem_write_t)(
807 rtems_libio_t *iop,
808 const void *buffer,
809 size_t count
810);
811
828typedef ssize_t (*rtems_filesystem_writev_t)(
829 rtems_libio_t *iop,
830 const struct iovec *iov,
831 int iovcnt,
832 ssize_t total
833);
834
848 rtems_libio_t *iop,
849 ioctl_command_t request,
850 void *buffer
851);
852
868 rtems_libio_t *iop,
869 off_t offset,
870 int whence
871);
872
886 struct stat *buf
887);
888
902 rtems_libio_t *iop,
903 off_t length
904);
905
918 rtems_libio_t *iop
919);
920
933 rtems_libio_t *iop
934);
935
948 rtems_libio_t *iop,
949 int cmd
950);
951
963 rtems_libio_t *iop,
964 int events
965);
966
979 rtems_libio_t *iop,
980 struct knote *kn
981);
982
998 rtems_libio_t *iop,
999 void **addr,
1000 size_t len,
1001 int prot,
1002 off_t off
1003);
1004
1016 rtems_filesystem_ftruncate_t ftruncate_h;
1018 rtems_filesystem_fdatasync_t fdatasync_h;
1021 rtems_filesystem_kqfilter_t kqfilter_h;
1025};
1026
1032
1039 rtems_libio_t *iop,
1040 const char *path,
1041 int oflag,
1042 mode_t mode
1043);
1044
1051 rtems_libio_t *iop
1052);
1053
1060 rtems_libio_t *iop,
1061 void *buffer,
1062 size_t count
1063);
1064
1071 rtems_libio_t *iop,
1072 const struct iovec *iov,
1073 int iovcnt,
1074 ssize_t total
1075);
1076
1083 rtems_libio_t *iop,
1084 const void *buffer,
1085 size_t count
1086);
1087
1094 rtems_libio_t *iop,
1095 const struct iovec *iov,
1096 int iovcnt,
1097 ssize_t total
1098);
1099
1106 rtems_libio_t *iop,
1107 ioctl_command_t request,
1108 void *buffer
1109);
1110
1117 rtems_libio_t *iop,
1118 off_t offset,
1119 int whence
1120);
1121
1134 rtems_libio_t *iop,
1135 off_t offset,
1136 int whence
1137);
1138
1157 rtems_libio_t *iop,
1158 off_t offset,
1159 int whence
1160);
1161
1171 struct stat *buf
1172);
1173
1180 rtems_libio_t *iop,
1181 off_t length
1182);
1183
1190 rtems_libio_t *iop,
1191 off_t length
1192);
1193
1200 rtems_libio_t *iop
1201);
1202
1209 rtems_libio_t *iop
1210);
1211
1218 rtems_libio_t *iop,
1219 int cmd
1220);
1221
1230 rtems_libio_t *iop,
1231 int events
1232);
1233
1242 rtems_libio_t *iop,
1243 struct knote *kn
1244);
1245
1254 rtems_libio_t *iop,
1255 void **addr,
1256 size_t len,
1257 int prot,
1258 off_t off
1259);
1260
1277typedef off_t rtems_off64_t __attribute__((deprecated));
1278
1287 const char *type
1288);
1289
1294typedef struct {
1295 int link_max; /* count */
1296 int max_canon; /* max formatted input line size */
1297 int max_input; /* max input line size */
1298 int name_max; /* max name length */
1299 int path_max; /* max path */
1300 int pipe_buf; /* pipe buffer size */
1301 int posix_async_io; /* async IO supported on fs, 0=no, 1=yes */
1302 int posix_chown_restrictions; /* can chown: 0=no, 1=yes */
1303 int posix_no_trunc; /* error on names > max name, 0=no, 1=yes */
1304 int posix_prio_io; /* priority IO, 0=no, 1=yes */
1305 int posix_sync_io; /* file can be sync'ed, 0=no, 1=yes */
1306 int posix_vdisable; /* special char processing, 0=no, 1=yes */
1308
1316
1326 Atomic_Uint flags;
1327 off_t offset; /* current offset into file */
1329 uint32_t data0; /* private to "driver" */
1330 void *data1; /* ... */
1331};
1332
1339typedef struct {
1340 rtems_libio_t *iop;
1341 off_t offset;
1342 char *buffer;
1343 uint32_t count;
1344 uint32_t flags;
1345 uint32_t bytes_moved;
1347
1352 rtems_libio_t *iop;
1353 uint32_t flags;
1354 uint32_t mode;
1356
1360typedef struct {
1361 rtems_libio_t *iop;
1362 ioctl_command_t command;
1363 void *buffer;
1364 int ioctl_return;
1366
1372#define LIBIO_FLAGS_FREE 0x0001U /* on the free list */
1373#define LIBIO_FLAGS_NO_DELAY 0x0002U /* return immediately if no data */
1374#define LIBIO_FLAGS_READ 0x0004U /* reading */
1375#define LIBIO_FLAGS_WRITE 0x0008U /* writing */
1376#define LIBIO_FLAGS_OPEN 0x0100U /* device is open */
1377#define LIBIO_FLAGS_APPEND 0x0200U /* all writes append */
1378#define LIBIO_FLAGS_CLOSE_BUSY 0x0400U /* close with refs held */
1379#define LIBIO_FLAGS_CLOSE_ON_EXEC 0x0800U /* close on process exec() */
1380#define LIBIO_FLAGS_REFERENCE_INC 0x1000U
1381/* masks */
1382#define LIBIO_FLAGS_READ_WRITE (LIBIO_FLAGS_READ | LIBIO_FLAGS_WRITE)
1383#define LIBIO_FLAGS_FLAGS_MASK (LIBIO_FLAGS_REFERENCE_INC - 1U)
1384#define LIBIO_FLAGS_REFERENCE_MASK (~LIBIO_FLAGS_FLAGS_MASK)
1385
1388static inline unsigned int rtems_libio_iop_flags( const rtems_libio_t *iop )
1389{
1390 return _Atomic_Load_uint( &iop->flags, ATOMIC_ORDER_RELAXED );
1391}
1392
1399static inline unsigned int rtems_libio_iop_flags_bad_fd(
1400 const unsigned int flags
1401)
1402{
1403 return ( ( flags & LIBIO_FLAGS_FREE ) != 0 )
1404 || ( ( flags & LIBIO_FLAGS_OPEN ) == 0 );
1405}
1406
1412static inline bool rtems_libio_iop_is_no_delay( const rtems_libio_t *iop )
1413{
1414 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_NO_DELAY ) != 0;
1415}
1416
1422static inline bool rtems_libio_iop_is_readable( const rtems_libio_t *iop )
1423{
1424 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_READ ) != 0;
1425}
1426
1432static inline bool rtems_libio_iop_is_writeable( const rtems_libio_t *iop )
1433{
1434 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_WRITE ) != 0;
1435}
1436
1442static inline bool rtems_libio_iop_is_open( const rtems_libio_t *iop )
1443{
1444 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_OPEN ) != 0;
1445}
1446
1452static inline bool rtems_libio_iop_is_append( const rtems_libio_t *iop )
1453{
1454 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_APPEND ) != 0;
1455}
1456
1462static inline bool rtems_libio_iop_is_held( const rtems_libio_t *iop )
1463{
1464 const unsigned int ref_count =
1465 rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_REFERENCE_MASK;
1466 return ref_count != 0;
1467}
1468
1474static inline bool rtems_libio_iop_is_free( const rtems_libio_t *iop )
1475{
1476 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_FREE ) != 0;
1477}
1478
1484typedef int (*rtems_libio_open_t)(
1485 const char *pathname,
1486 uint32_t flag,
1487 uint32_t mode
1488);
1489
1490typedef int (*rtems_libio_close_t)(
1491 int fd
1492);
1493
1494typedef ssize_t (*rtems_libio_read_t)(
1495 int fd,
1496 void *buffer,
1497 size_t count
1498);
1499
1500typedef ssize_t (*rtems_libio_write_t)(
1501 int fd,
1502 const void *buffer,
1503 size_t count
1504);
1505
1506typedef int (*rtems_libio_ioctl_t)(
1507 int fd,
1508 uint32_t command,
1509 void *buffer
1510);
1511
1512typedef off_t (*rtems_libio_lseek_t)(
1513 int fd,
1514 off_t offset,
1515 int whence
1516);
1517
1525/*
1526 * The following macros are used to build up the permissions sets
1527 * used to check permissions. These are similar in style to the
1528 * mode_t bits and should stay compatible with them.
1529 */
1530#define RTEMS_FS_PERMS_READ 0x4
1531#define RTEMS_FS_PERMS_WRITE 0x2
1532#define RTEMS_FS_PERMS_EXEC 0x1
1533#define RTEMS_FS_PERMS_RWX \
1534 (RTEMS_FS_PERMS_READ | RTEMS_FS_PERMS_WRITE | RTEMS_FS_PERMS_EXEC)
1535#define RTEMS_FS_FOLLOW_HARD_LINK 0x8
1536#define RTEMS_FS_FOLLOW_SYM_LINK 0x10
1537#define RTEMS_FS_FOLLOW_LINK \
1538 (RTEMS_FS_FOLLOW_HARD_LINK | RTEMS_FS_FOLLOW_SYM_LINK)
1539#define RTEMS_FS_MAKE 0x20
1540#define RTEMS_FS_EXCLUSIVE 0x40
1541#define RTEMS_FS_ACCEPT_RESIDUAL_DELIMITERS 0x80
1542#define RTEMS_FS_REJECT_TERMINAL_DOT 0x100
1543
1547 dev_t device;
1548 struct {
1551 } __overlay;
1552};
1553
1554static inline dev_t rtems_filesystem_make_dev_t(
1557)
1558{
1559 union __rtems_dev_t temp;
1560
1561 temp.__overlay.major = _major;
1562 temp.__overlay.minor = _minor;
1563 return temp.device;
1564}
1565
1566static inline dev_t rtems_filesystem_make_dev_t_from_pointer(
1567 const void *pointer
1568)
1569{
1570 uint64_t temp = (((uint64_t) 1) << 63) | (((uintptr_t) pointer) >> 1);
1571
1572 return rtems_filesystem_make_dev_t((uint32_t) (temp >> 32), (uint32_t) temp);
1573}
1574
1575static inline rtems_device_major_number rtems_filesystem_dev_major_t(
1576 dev_t device
1577)
1578{
1579 union __rtems_dev_t temp;
1580
1581 temp.device = device;
1582 return temp.__overlay.major;
1583}
1584
1585
1586static inline rtems_device_minor_number rtems_filesystem_dev_minor_t(
1587 dev_t device
1588)
1589{
1590 union __rtems_dev_t temp;
1591
1592 temp.device = device;
1593 return temp.__overlay.minor;
1594}
1595
1596#define rtems_filesystem_split_dev_t( _dev, _major, _minor ) \
1597 do { \
1598 (_major) = rtems_filesystem_dev_major_t ( _dev ); \
1599 (_minor) = rtems_filesystem_dev_minor_t( _dev ); \
1600 } while(0)
1601
1602/*
1603 * Prototypes for filesystem
1604 */
1605
1614void rtems_filesystem_initialize( void );
1615
1616void rtems_libio_post_driver(void);
1617
1618void rtems_libio_exit(void);
1619
1629extern int rtems_mkdir(const char *path, mode_t mode);
1630
1647#define RTEMS_FILESYSTEM_TYPE_IMFS "imfs"
1648#define RTEMS_FILESYSTEM_TYPE_FTPFS "ftpfs"
1649#define RTEMS_FILESYSTEM_TYPE_TFTPFS "tftpfs"
1650#define RTEMS_FILESYSTEM_TYPE_NFS "nfs"
1651#define RTEMS_FILESYSTEM_TYPE_DOSFS "dosfs"
1652#define RTEMS_FILESYSTEM_TYPE_FATFS "fatfs"
1653#define RTEMS_FILESYSTEM_TYPE_RFS "rfs"
1654#define RTEMS_FILESYSTEM_TYPE_JFFS2 "jffs2"
1655
1662 rtems_chain_node mt_node;
1663 void *fs_info;
1665 const void *immutable_fs_info;
1666 rtems_chain_control location_chain;
1669 bool mounted;
1670 bool writeable;
1671 bool no_regular_file_mknod;
1672 const rtems_filesystem_limits_and_options_t *pathconf_limits_and_options;
1673
1674 /*
1675 * The target or mount point of the file system.
1676 */
1677 const char *target;
1678
1679 /*
1680 * The type of filesystem or the name of the filesystem.
1681 */
1682 const char *type;
1683
1684 /*
1685 * When someone adds a mounted filesystem on a real device,
1686 * this will need to be used.
1687 *
1688 * The lower layers can manage how this is managed. Leave as a
1689 * string.
1690 */
1691 char *dev;
1692
1700};
1701
1705typedef enum {
1706 RTEMS_FILESYSTEM_READ_ONLY,
1707 RTEMS_FILESYSTEM_READ_WRITE,
1708 RTEMS_FILESYSTEM_BAD_OPTIONS
1710
1715 const char *type;
1718
1725
1726extern rtems_chain_control rtems_filesystem_mount_table;
1727
1737 const char *type,
1739);
1740
1748 const char *type
1749);
1750
1773int unmount(
1774 const char *mount_path
1775);
1776
1824int mount(
1825 const char *source,
1826 const char *target,
1827 const char *filesystemtype,
1829 const void *data
1830);
1831
1844 const char *source,
1845 const char *target,
1846 const char *filesystemtype,
1848 const void *data
1849);
1850
1860 const rtems_filesystem_table_t *fs_entry,
1861 void *arg
1862);
1863
1879 void *routine_arg
1880);
1881
1892 void *arg
1893);
1894
1910 void *visitor_arg
1911);
1912
1913typedef struct {
1914 const char *source;
1915 const char *target;
1916 const char *filesystemtype;
1918 const void *data;
1920
1922 rtems_filesystem_root_configuration;
1923
1935struct rtems_termios_tty;
1936
1938 int (*firstOpen)(int major, int minor, void *arg);
1939 int (*lastClose)(int major, int minor, void *arg);
1940 int (*pollRead)(int minor);
1941 ssize_t (*write)(int minor, const char *buf, size_t len);
1942 int (*setAttributes)(int minor, const struct termios *t);
1943 int (*stopRemoteTx)(int minor);
1944 int (*startRemoteTx)(int minor);
1945 rtems_termios_device_mode outputUsesInterrupts;
1947
1948static inline void rtems_termios_initialize( void )
1949{
1950 /* Nothing to do, provided for backward compatibility */
1951}
1952
1953/*
1954 * CCJ: Change before opening a tty. Newer code from Eric is coming
1955 * so extra work to handle an open tty is not worth it. If the tty
1956 * is open, close then open it again.
1957 */
1958rtems_status_code rtems_termios_bufsize (
1959 size_t cbufsize, /* cooked buffer size */
1960 size_t raw_input, /* raw input buffer size */
1961 size_t raw_output /* raw output buffer size */
1962);
1963
1968typedef enum {
1976
1988
1996
2014 unsigned char c,
2015 struct rtems_termios_tty *tty
2016);
2017
2037 unsigned char c,
2038 struct rtems_termios_tty *tty
2039);
2040
2055 unsigned char c,
2056 struct rtems_termios_tty *tty
2057);
2058
2073);
2074
2075int rtems_termios_enqueue_raw_characters(
2076 void *ttyp,
2077 const char *buf,
2078 int len
2079);
2080
2081rtems_status_code rtems_termios_open (
2084 void *arg,
2085 const rtems_termios_callbacks *callbacks
2086);
2087
2088rtems_status_code rtems_termios_close(
2089 void *arg
2090);
2091
2092rtems_status_code rtems_termios_read(
2093 void *arg
2094);
2095
2096rtems_status_code rtems_termios_write(
2097 void *arg
2098);
2099
2100rtems_status_code rtems_termios_ioctl(
2101 void *arg
2102);
2103
2104int rtems_termios_dequeue_characters(
2105 void *ttyp,
2106 int len
2107);
2108
2114#define rtems_filesystem_pathconf(_mte) ((_mte)->pathconf_limits_and_options)
2115
2119#define rtems_filesystem_type(_mte) ((_mte)->type)
2120
2124#define rtems_filesystem_mount_point(_mte) ((_mte)->target)
2125
2129#define rtems_filesystem_mount_device(_mte) ((_mte)->dev)
2130
2131#ifdef __cplusplus
2132}
2133#endif
2134
2135#endif /* _RTEMS_LIBIO_H */
clock_t times(struct tms *ptms)
Definition: __times.c:97
This header file provides the Chains API.
bool rtems_filesystem_mount_iterate(rtems_filesystem_mt_entry_visitor visitor, void *visitor_arg)
Iterates over all file system mount entries.
Definition: sup_fs_mount_iterate.c:42
int rtems_filesystem_register(const char *type, rtems_filesystem_mount_t mount_h)
Registers a file system type.
Definition: mount-mgr.c:126
int mount_and_make_target_path(const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
Mounts a file system and makes the target path.
Definition: mount-mktgt.c:44
bool rtems_filesystem_iterate(rtems_per_filesystem_routine routine, void *routine_arg)
Iterates over all file system types.
Definition: mount-mgr.c:58
int unmount(const char *mount_path)
Unmounts the file system instance at the specified mount path.
Definition: unmount.c:62
int rtems_filesystem_unregister(const char *type)
Unregisters a file system type.
Definition: mount-mgr.c:160
const rtems_filesystem_table_t rtems_filesystem_table[]
Static table of file systems.
bool(* rtems_filesystem_mt_entry_visitor)(const rtems_filesystem_mount_table_entry_t *mt_entry, void *arg)
Mount table entry visitor.
Definition: libio.h:1890
bool(* rtems_per_filesystem_routine)(const rtems_filesystem_table_t *fs_entry, void *arg)
Per file system type routine.
Definition: libio.h:1859
File system options.
Definition: libio.h:1705
int mount(const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
Mounts a file system instance at the specified target path.
Definition: mount.c:197
int(* rtems_filesystem_ioctl_t)(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
IO control of a node.
Definition: libio.h:847
int rtems_filesystem_default_fcntl(rtems_libio_t *iop, int cmd)
Definition: default_fcntl.c:41
int(* rtems_filesystem_poll_t)(rtems_libio_t *iop, int events)
Poll and select support.
Definition: libio.h:962
int rtems_filesystem_default_ftruncate(rtems_libio_t *iop, off_t length)
Definition: default_ftruncate.c:44
int rtems_filesystem_default_ftruncate_directory(rtems_libio_t *iop, off_t length)
Definition: default_ftruncate_directory.c:43
off_t rtems_filesystem_default_lseek_directory(rtems_libio_t *iop, off_t offset, int whence)
An offset 0 with a whence of SEEK_SET will perform a directory rewind operation.
Definition: default_lseek_directory.c:42
ssize_t(* rtems_filesystem_read_t)(rtems_libio_t *iop, void *buffer, size_t count)
Reads from a node.
Definition: libio.h:763
int(* rtems_filesystem_fcntl_t)(rtems_libio_t *iop, int cmd)
File control.
Definition: libio.h:947
int rtems_filesystem_default_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
Definition: default_ioctl.c:43
int rtems_filesystem_default_poll(rtems_libio_t *iop, int events)
Default poll handler.
Definition: default_poll.c:44
int rtems_filesystem_default_fsync_or_fdatasync(rtems_libio_t *iop)
Definition: default_fsync.c:43
const rtems_filesystem_file_handlers_r rtems_filesystem_handlers_default
File system node handler table with default node handlers.
Definition: default_handlers.c:38
off_t rtems_filesystem_default_lseek_file(rtems_libio_t *iop, off_t offset, int whence)
Default lseek() handler for files.
Definition: default_lseek_file.c:42
int(* rtems_filesystem_kqfilter_t)(rtems_libio_t *iop, struct knote *kn)
Kernel event filter support.
Definition: libio.h:978
int rtems_filesystem_default_fstat(const rtems_filesystem_location_info_t *loc, struct stat *buf)
Sets the mode to S_IRWXU | S_IRWXG | S_IRWXO.
Definition: default_fstat.c:43
int rtems_filesystem_default_fsync_or_fdatasync_success(rtems_libio_t *iop)
Definition: default_fsync_success.c:42
int rtems_filesystem_default_kqfilter(rtems_libio_t *iop, struct knote *kn)
Default kernel event filter handler.
Definition: default_kqfilter.c:42
ssize_t rtems_filesystem_default_writev(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the write handler for each IO vector entry.
Definition: default_writev.c:45
int(* rtems_filesystem_close_t)(rtems_libio_t *iop)
Closes a node.
Definition: libio.h:745
ssize_t rtems_filesystem_default_readv(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the read handler for each IO vector entry.
Definition: default_readv.c:45
off_t(* rtems_filesystem_lseek_t)(rtems_libio_t *iop, off_t offset, int whence)
Moves the read/write file offset.
Definition: libio.h:867
off_t rtems_filesystem_default_lseek(rtems_libio_t *iop, off_t offset, int whence)
Definition: default_lseek.c:43
ssize_t(* rtems_filesystem_writev_t)(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Writes an IO vector to a node.
Definition: libio.h:828
int(* rtems_filesystem_fstat_t)(const rtems_filesystem_location_info_t *loc, struct stat *buf)
Gets a node status.
Definition: libio.h:884
int rtems_filesystem_default_mmap(rtems_libio_t *iop, void **addr, size_t len, int prot, off_t off)
Default MMAP handler.
Definition: default_mmap.c:42
ssize_t(* rtems_filesystem_write_t)(rtems_libio_t *iop, const void *buffer, size_t count)
Writes to a node.
Definition: libio.h:806
int rtems_filesystem_default_close(rtems_libio_t *iop)
Definition: default_close.c:37
int(* rtems_filesystem_fsync_t)(rtems_libio_t *iop)
Synchronizes changes to a file.
Definition: libio.h:917
ssize_t rtems_filesystem_default_read(rtems_libio_t *iop, void *buffer, size_t count)
Definition: default_read.c:39
int(* rtems_filesystem_fdatasync_t)(rtems_libio_t *iop)
Synchronizes the data of a file.
Definition: libio.h:932
int rtems_filesystem_default_open(rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
Definition: default_open.c:43
int(* rtems_filesystem_mmap_t)(rtems_libio_t *iop, void **addr, size_t len, int prot, off_t off)
MMAP support.
Definition: libio.h:997
ssize_t(* rtems_filesystem_readv_t)(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Reads an IO vector from a node.
Definition: libio.h:785
ssize_t rtems_filesystem_default_write(rtems_libio_t *iop, const void *buffer, size_t count)
Definition: default_write.c:41
int(* rtems_filesystem_ftruncate_t)(rtems_libio_t *iop, off_t length)
Truncates a file to a specified length.
Definition: libio.h:901
int(* rtems_filesystem_open_t)(rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
Opens a node.
Definition: libio.h:728
int(* rtems_filesystem_statvfs_t)(const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
Gets file system information.
Definition: libio.h:467
int rtems_filesystem_default_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_unmount.c:41
int(* rtems_filesystem_link_t)(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Creates a new link for the existing file.
Definition: libio.h:195
int(* rtems_filesystem_fchmod_t)(const rtems_filesystem_location_info_t *loc, mode_t mode)
Changes the mode of a node.
Definition: libio.h:213
void rtems_filesystem_default_lock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Obtains the IO library mutex.
Definition: default_lock_and_unlock.c:42
int rtems_filesystem_default_rename(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Definition: default_rename.c:44
void(* rtems_filesystem_fsunmount_me_t)(rtems_filesystem_mount_table_entry_t *mt_entry)
Destroys a file system instance.
Definition: libio.h:316
int rtems_filesystem_default_mknod(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Definition: default_mknod.c:44
int(* rtems_filesystem_mount_t)(rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
Mounts a file system instance in a mount point (directory).
Definition: libio.h:282
int rtems_filesystem_default_fchmod(const rtems_filesystem_location_info_t *loc, mode_t mode)
Definition: default_fchmod.c:42
void(* rtems_filesystem_eval_path_t)(rtems_filesystem_eval_path_context_t *ctx)
Path evaluation.
Definition: libio.h:178
int(* rtems_filesystem_unmount_t)(rtems_filesystem_mount_table_entry_t *mt_entry)
Unmounts a file system instance in a mount point (directory).
Definition: libio.h:301
int rtems_filesystem_default_clonenode(rtems_filesystem_location_info_t *loc)
Definition: default_clone.c:42
void rtems_filesystem_default_unlock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Releases the IO library mutex.
Definition: default_lock_and_unlock.c:51
bool rtems_filesystem_default_are_nodes_equal(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node access pointer of one location is equal to the node access pointer of the other loc...
Definition: default_are_nodes_equal.c:42
int(* rtems_filesystem_rmnod_t)(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Removes a node.
Definition: libio.h:374
int rtems_filesystem_default_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Definition: default_rmnod.c:44
int(* rtems_filesystem_rename_t)(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Renames a node.
Definition: libio.h:448
int(* rtems_filesystem_clonenode_t)(rtems_filesystem_location_info_t *loc)
Clones a location.
Definition: libio.h:251
void rtems_filesystem_default_freenode(const rtems_filesystem_location_info_t *loc)
Definition: default_freenode.c:43
ssize_t(* rtems_filesystem_readlink_t)(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Reads the contents of a symbolic link.
Definition: libio.h:428
void rtems_filesystem_default_fsunmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_fsunmount.c:39
int(* rtems_filesystem_mknod_t)(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Creates a new node.
Definition: libio.h:355
bool(* rtems_filesystem_are_nodes_equal_t)(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node of one location is equal to the node of the other location.
Definition: libio.h:334
void(* rtems_filesystem_mt_entry_unlock_t)(const rtems_filesystem_mount_table_entry_t *mt_entry)
Unlocks a file system instance.
Definition: libio.h:98
void rtems_filesystem_default_eval_path(rtems_filesystem_eval_path_context_t *ctx)
Terminates the path evaluation and replaces the current location with the null location.
Definition: default_eval_path.c:42
int rtems_filesystem_default_symlink(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Definition: default_symlink.c:44
int rtems_filesystem_default_statvfs(const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
Definition: default_statvfs.c:42
int(* rtems_filesystem_utimens_t)(const rtems_filesystem_location_info_t *loc, struct timespec times[2])
Set node access and modification times.
Definition: libio.h:390
int(* rtems_filesystem_chown_t)(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Changes owner and group of a node.
Definition: libio.h:230
const rtems_filesystem_operations_table rtems_filesystem_operations_default
File system operations table with default operations.
Definition: default_ops.c:38
void(* rtems_filesystem_freenode_t)(const rtems_filesystem_location_info_t *loc)
Frees the location of a node.
Definition: libio.h:262
void(* rtems_filesystem_mt_entry_lock_t)(const rtems_filesystem_mount_table_entry_t *mt_entry)
Locks a file system instance.
Definition: libio.h:87
int rtems_filesystem_default_chown(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Definition: default_chown.c:42
ssize_t rtems_filesystem_default_readlink(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Definition: default_readlink.c:44
int(* rtems_filesystem_symlink_t)(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Makes a symbolic link to a node.
Definition: libio.h:409
int rtems_filesystem_default_mount(rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
Definition: default_mount.c:41
int rtems_filesystem_default_link(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Definition: default_link.c:42
int rtems_filesystem_default_utimens(const rtems_filesystem_location_info_t *loc, struct timespec times[2])
Definition: default_utimens.c:43
struct rtems_libio_open_close_args rtems_libio_open_close_args_t
Parameter block for open/close.
Creates a directory and all its parent directories according to path.
Definition: rtems_mkdir.c:130
void rtems_filesystem_initialize(void)
Base File System Initialization.
Definition: base_fs.c:51
rtems_filesystem_mount_t rtems_filesystem_get_mount_handler(const char *type)
Gets the mount handler for the file system type.
Definition: mount-mgr.c:109
const rtems_filesystem_limits_and_options_t rtems_filesystem_default_pathconf
Default pathconf settings.
Definition: mount.c:49
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition: io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
rtems_termios_iproc_status_code rtems_termios_default_isig_handler(unsigned char c, struct rtems_termios_tty *tty)
Default handler for ISIG (VINTR/VKILL)
Definition: termios.c:1332
rtems_termios_iproc_status_code(* rtems_termios_isig_handler)(unsigned char c, struct rtems_termios_tty *tty)
Type for ISIG (VINTR/VKILL) handler.
Definition: libio.h:2013
The status code returned by all Termios input processing (iproc) functions and input signal (isig) ha...
Definition: libio.h:1968
rtems_status_code rtems_termios_register_isig_handler(rtems_termios_isig_handler handler)
Register handler for ISIG (VINTR/VKILL)
Definition: termios.c:1347
rtems_termios_iproc_status_code rtems_termios_posix_isig_handler(unsigned char c, struct rtems_termios_tty *tty)
POSIX handler for ISIG (VINTR/VKILL)
Definition: termios_posix_isig_handler.c:23
@ RTEMS_TERMIOS_IPROC_DONE
This status indicates that the input processing is done.
Definition: libio.h:1994
@ RTEMS_TERMIOS_IPROC_CONTINUE
This status indicates that the input processing can continue.
Definition: libio.h:1975
@ RTEMS_TERMIOS_IPROC_INTERRUPT
This status indicates that the input processing should stop due to a signal.
Definition: libio.h:1987
rtems_termios_device_handler handler
The device handler.
Definition: termiostypes.h:166
Basic Filesystem Types.
This header file provides the interfaces of the Atomic Operations.
This header file provides the statvfs() and fstatvfs() interfaces.
This structure represents a chain node.
Definition: chain.h:78
Definition: xnandpsu_onfi.h:185
File system node operations table.
Definition: libio.h:1008
File system operations table.
Definition: libio.h:475
Definition: iterateoverthreads.c:44
Path evaluation context.
Definition: libio.h:105
int recursionlevel
Definition: libio.h:147
rtems_filesystem_location_info_t currentloc
Definition: libio.h:156
const char * path
Definition: libio.h:109
size_t pathlen
Definition: libio.h:114
rtems_filesystem_global_location_t * rootloc
Definition: libio.h:162
size_t tokenlen
Definition: libio.h:126
const char * token
Definition: libio.h:120
int flags
Definition: libio.h:140
rtems_filesystem_global_location_t * startloc
Definition: libio.h:168
Global file system location.
Definition: fs.h:100
Contain file system specific information which is required to support fpathconf().
Definition: libio.h:1294
File system location.
Definition: fs.h:72
Definition: libio.h:1913
Mount table entry.
Definition: libio.h:1661
rtems_id unmount_task
Definition: libio.h:1699
File system table entry.
Definition: libio.h:1714
Parameter block for ioctl.
Definition: libio.h:1360
Definition: libio.h:1351
Paramameter block for read/write.
Definition: libio.h:1339
An open file data structure.
Definition: libio.h:1325
Definition: libio.h:1937
Definition: termiostypes.h:94
Definition: statvfs.h:56
This header file provides the interfaces of the RTEMS Termios Device Support.
This union represents a chain control block.
Definition: chain.h:96
Definition: libio.h:1546
