#define | CPU_SIMPLE_VECTORED_INTERRUPTS FALSE |
#define | CPU_ISR_PASSES_FRAME_POINTER FALSE |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_SOFTWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP FALSE |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_USE_DEFERRED_FP_SWITCH TRUE |
#define | CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_CACHE_LINE_BYTES 64 |
#define | CPU_STRUCTURE_ALIGNMENT |
#define | CPU_MAXIMUM_PROCESSORS 32 |
#define | I386_CONTEXT_CONTROL_EFLAGS_OFFSET 0 |
#define | I386_CONTEXT_CONTROL_ESP_OFFSET 4 |
#define | I386_CONTEXT_CONTROL_EBP_OFFSET 8 |
#define | I386_CONTEXT_CONTROL_EBX_OFFSET 12 |
#define | I386_CONTEXT_CONTROL_ESI_OFFSET 16 |
#define | I386_CONTEXT_CONTROL_EDI_OFFSET 20 |
#define | I386_CONTEXT_CONTROL_GS_0_OFFSET 24 |
#define | I386_CONTEXT_CONTROL_GS_1_OFFSET 28 |
#define | I386_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 32 |
#define | _CPU_Context_Get_SP(_context) (uintptr_t) (_context)->esp |
#define | CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) |
#define | CPU_MODES_INTERRUPT_MASK 0x00000001 /* interrupt level in mode */ |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024 |
#define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
#define | CPU_STACK_MINIMUM_SIZE 4096 |
#define | CPU_SIZEOF_POINTER 4 |
#define | CPU_ALIGNMENT 4 |
#define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_STACK_ALIGNMENT 16 |
#define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
#define | _CPU_ISR_Disable(_level) i386_disable_interrupts( _level ) |
#define | _CPU_ISR_Enable(_level) i386_enable_interrupts( _level ) |
#define | _CPU_ISR_Flash(_level) i386_flash_interrupts( _level ) |
| #define | _CPU_ISR_Set_level(_new_level) |
| #define | _CPU_Interrupt_stack_setup(_lo, _hi) |
#define | CPU_EFLAGS_INTERRUPTS_ON 0x00003202 |
#define | CPU_EFLAGS_INTERRUPTS_OFF 0x00003002 |
#define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
| #define | _CPU_Context_Initialize_fp(_fp_area) |
#define | CPU_USE_LIBC_INIT_FINI_ARRAY FALSE |
#define | CPU_USE_GENERIC_BITFIELD_CODE FALSE |
| #define | _CPU_Bitfield_Find_first_bit(_value, _output) |
#define | _CPU_Priority_Mask(_bit_number) ( 1 << (_bit_number) ) |
#define | _CPU_Priority_bits_index(_priority) (_priority) |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
#define | CPU_INTERRUPT_FRAME_SIZE 52 |
#define | CPU_THREAD_LOCAL_STORAGE_VARIANT 20 |
| enum | Intel_symbolic_exception_name {
I386_EXCEPTION_DIVIDE_BY_ZERO = 0
, I386_EXCEPTION_DEBUG = 1
, I386_EXCEPTION_NMI = 2
, I386_EXCEPTION_BREAKPOINT = 3
I386_EXCEPTION_OVERFLOW = 4
, I386_EXCEPTION_BOUND = 5
, I386_EXCEPTION_ILLEGAL_INSTR = 6
, I386_EXCEPTION_MATH_COPROC_UNAVAIL = 7
I386_EXCEPTION_DOUBLE_FAULT = 8
, I386_EXCEPTION_I386_COPROC_SEG_ERR = 9
, I386_EXCEPTION_INVALID_TSS = 10
, I386_EXCEPTION_SEGMENT_NOT_PRESENT = 11
I386_EXCEPTION_STACK_SEGMENT_FAULT = 12
, I386_EXCEPTION_GENERAL_PROT_ERR = 13
, I386_EXCEPTION_PAGE_FAULT = 14
, I386_EXCEPTION_INTEL_RES15 = 15
I386_EXCEPTION_FLOAT_ERROR = 16
, I386_EXCEPTION_ALIGN_CHECK = 17
, I386_EXCEPTION_MACHINE_CHECK = 18
, I386_EXCEPTION_ENTER_RDBG = 50
void | rtems_exception_init_mngt (void) |
uint32_t | _CPU_ISR_Get_level (void) |
void | _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
| void | _CPU_Initialize (void) |
| | CPU initialization.
void | _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler) |
RTEMS_NO_RETURN void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| | CPU switch context.
RTEMS_NO_RETURN void | _CPU_Context_switch_no_return (Context_Control *executing, Context_Control *heir) |
RTEMS_NO_RETURN void | _CPU_Context_restore (Context_Control *new_context) |
void | _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr) |
void | _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr) |
void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
uint32_t | _CPU_Counter_frequency (void) |
CPU_Counter_ticks | _CPU_Counter_read (void) |
i386 specific support.
This include file contains information pertaining to the Intel i386 processor.
This file contains definitions for data structure related to Intel system programming. More information can be found on Intel site and more precisely in the following book :
Formerly contained in and extracted from libcpu/i386/cpu.h.
Applications must not include this file directly.
