RTEMS 7.0-rc1
Macros | Functions
can-queue.c File Reference
This file is part of CAN/CAN FD bus common support and implements CAN FIFOs and generic hubs/ends for chip and character driver interface sides. More...
#include <dev/can/can-impl.h>
#define RTEMS_CAN_QUEUE_ROUND_ROBIN   1
int rtems_can_queue_fifo_flush_slots (struct rtems_can_queue_fifo *fifo)
 This function frees all ready slots from the FIFO.
int rtems_can_queue_fifo_init_slots (struct rtems_can_queue_fifo *fifo)
 This function initializes slot chain of one CAN FIFO.
void rtems_can_queue_do_edge_decref (struct rtems_can_queue_edge *qedge)
 This function decrements the edge user counter.
int rtems_can_queue_get_inslot (struct rtems_can_queue_ends *qends, struct rtems_can_queue_edge **qedgep, struct rtems_can_queue_slot **slotp, int cmd)
 This function finds one outgoing edge and allocates slot from it.
int rtems_can_queue_get_inslot_for_prio (struct rtems_can_queue_ends *qends, struct rtems_can_queue_edge **qedgep, struct rtems_can_queue_slot **slotp, const struct can_frame_header *header, int cmd, int prio)
 This function finds best outgoing edge and slot for given priority.
int rtems_can_queue_test_inslot (struct rtems_can_queue_ends *qends)
 This function tests whether there is a free space in any outgoing edge.
int rtems_can_queue_put_inslot (struct rtems_can_queue_ends *qends, struct rtems_can_queue_edge *qedge, struct rtems_can_queue_slot *slot)
 This function schedules filled slot for processing.
int rtems_can_queue_abort_inslot (struct rtems_can_queue_ends *qends, struct rtems_can_queue_edge *qedge, struct rtems_can_queue_slot *slot)
 This function aborts preparation of the message in the slot.
int rtems_can_queue_filter_frame_to_edges (struct rtems_can_queue_ends *qends, struct rtems_can_queue_edge *src_edge, struct can_frame *frame, unsigned int flags2add)
 This function sends message into all edges which accept its ID.
int rtems_can_queue_test_outslot (struct rtems_can_queue_ends *qends, struct rtems_can_queue_edge **qedgep, struct rtems_can_queue_slot **slotp)
 This function tests and retrieves ready slot for given ends.
int rtems_can_queue_pending_outslot_prio (struct rtems_can_queue_ends *qends, int prio_min)
 This function tests ready outslot with minimum priority.
int rtems_can_queue_free_outslot (struct rtems_can_queue_ends *qends, struct rtems_can_queue_edge *qedge, struct rtems_can_queue_slot *slot)
 This function frees processed output slot.
int rtems_can_queue_push_back_outslot (struct rtems_can_queue_ends *qends, struct rtems_can_queue_edge *qedge, struct rtems_can_queue_slot *slot)
 This function reschedules output slot to process it again later.
int rtems_can_queue_flush (struct rtems_can_queue_edge *qedge)
 This function flushes all ready slots in the edge.
int rtems_can_queue_ends_init (struct rtems_can_queue_ends *qends)
 This function implements subsystem independent routine to initialize ends state.
int rtems_can_queue_connect_edge (struct rtems_can_queue_edge *qedge, struct rtems_can_queue_ends *input_ends, struct rtems_can_queue_ends *output_ends)
 This function connects edge between two communication entities.
int rtems_can_queue_disconnect_edge (struct rtems_can_queue_edge *qedge)
 This function disconnects edge from communication entities.
void rtems_can_queue_block_inlist (struct rtems_can_queue_ends *qends)
 This function blocks slot allocation of all outgoing edges of specified ends.
void rtems_can_queue_block_outlist (struct rtems_can_queue_ends *qends)
 This function blocks slot allocation of all incoming edges of specified ends.
int rtems_can_queue_ends_kill_inlist (struct rtems_can_queue_ends *qends, int send_rest)
 This function sends request to die to all outgoing edges.
int rtems_can_queue_ends_kill_outlist (struct rtems_can_queue_ends *qends)
 This function sends request to die to all incomming edges.
int rtems_can_queue_ends_flush_inlist (struct rtems_can_queue_ends *qends)
 This function flushes all messages in incoming edges.
int rtems_can_queue_ends_flush_outlist (struct rtems_can_queue_ends *qends)
 This function flushes all messages in outgoing edges.
Implementation is based on original LinCAN - Linux CAN bus driver Part of OrtCAN project https://ortcan.sourceforge.net/
◆ rtems_can_queue_abort_inslot()
int rtems_can_queue_abort_inslot ( struct rtems_can_queue_ends qends,
struct rtems_can_queue_edge qedge,
struct rtems_can_queue_slot slot
Frees slot previously acquired by rtems_can_queue_get_inslot or rtems_can_queue_get_inslot_for_prio function call. Used when message copying into slot fails.
Parameters
qendsEnds structure belonging to calling communication object.
qedgeEdge the slot belongs to.
slotPointer to the preprared slot.
Returns
Positive value informs, that queue full state has been negated.
◆ rtems_can_queue_block_inlist()
void rtems_can_queue_block_inlist ( struct rtems_can_queue_ends qends)
Parameters
qendsPointer to ends structure.
Returns
None.
◆ rtems_can_queue_block_outlist()
void rtems_can_queue_block_outlist ( struct rtems_can_queue_ends qends)
Parameters
Returns
None.
◆ rtems_can_queue_connect_edge()
int rtems_can_queue_connect_edge ( struct rtems_can_queue_edge qedge,
struct rtems_can_queue_ends input_ends,
struct rtems_can_queue_ends output_ends
Parameters
qedgePointer to edge.
input_endsPointer to ends the input of the edge should be connected to.
output_endsPointer to ends the output of the edge should be connected to.
Returns
Negative value informs about failed operation.
◆ rtems_can_queue_disconnect_edge()
int rtems_can_queue_disconnect_edge ( struct rtems_can_queue_edge qedge)
Parameters
Returns
Negative value means, that edge is used by somebody other and cannot be disconnected. Operation has to be delayed.
◆ rtems_can_queue_do_edge_decref()
void rtems_can_queue_do_edge_decref ( struct rtems_can_queue_edge edge)
Parameters
qedgePointer to the edge to be disconnected.
Returns
None
◆ rtems_can_queue_ends_flush_inlist()
int rtems_can_queue_ends_flush_inlist ( struct rtems_can_queue_ends qends)
Parameters
qendspointer to ends structure
Return Value: Negative value informs about unsuccessful result
◆ rtems_can_queue_ends_flush_outlist()
int rtems_can_queue_ends_flush_outlist ( struct rtems_can_queue_ends qends)
Parameters
Returns
Negative value informs about unsuccessful result.
◆ rtems_can_queue_ends_init()
int rtems_can_queue_ends_init ( struct rtems_can_queue_ends qends)
Parameters
qendsPointer to the end.
Returns
This fucntion cannot fail.
◆ rtems_can_queue_ends_kill_inlist()
int rtems_can_queue_ends_kill_inlist ( struct rtems_can_queue_ends qends,
int  send_rest
Parameters
send_restSelect, whether already allocated slots should be processed by FIFO output side.
Returns
Non-zero value means, that not all edges could be immediately disconnected and that ends structure memory release has to be delayed.
◆ rtems_can_queue_ends_kill_outlist()
int rtems_can_queue_ends_kill_outlist ( struct rtems_can_queue_ends qends)
Parameters
Returns
◆ rtems_can_queue_fifo_flush_slots()
int rtems_can_queue_fifo_flush_slots ( struct rtems_can_queue_fifo fifo)
The caller should be prepared to handle situations, when some slots are held by input or output side slots processing. These slots cannot be flushed or their processing interrupted.
Parameters
fifoPointer to the FIFO structure.
Returns
The nonzero value indicates that queue has not been empty before the function call.
◆ rtems_can_queue_fifo_init_slots()
int rtems_can_queue_fifo_init_slots ( struct rtems_can_queue_fifo fifo)
Parameters
Returns
The negative value indicates that there is no memory to allocate space for the requested number of the slots.
◆ rtems_can_queue_filter_frame_to_edges()
int rtems_can_queue_filter_frame_to_edges ( struct rtems_can_queue_ends qends,
struct rtems_can_queue_edge src_edge,
struct can_frame frame,
Sends message to all outgoing edges connected to the given ends, which accepts message communication ID.
Parameters
src_edgeOptional source edge for echo detection
framePointer to CAN frame.
flags2addOptional additional CAN Frame flags.
Returns
Returns number of edges message has been send to.
◆ rtems_can_queue_flush()
int rtems_can_queue_flush ( struct rtems_can_queue_edge qedge)
Tries to flush all allocated slots from the edge, but there could exist some slots associated to edge which are processed by input or output side and cannot be flushed at this moment
Parameters
qedgePointer to the edge.
Returns
The nonzero value indicates, that queue has not been empty before the function call
◆ rtems_can_queue_free_outslot()
int rtems_can_queue_free_outslot ( struct rtems_can_queue_ends qends,
Function releases processed slot previously acquired by rtems_can_queue_test_outslot function call.
Parameters
slotPointer to the processed slot.
Returns
Informs if input side has been notified to know about change of edge state
◆ rtems_can_queue_get_inslot()
int rtems_can_queue_get_inslot ( struct rtems_can_queue_ends qends,
struct rtems_can_queue_edge **  qedgep,
struct rtems_can_queue_slot **  slotp,
int  cmd
Function looks for the first non-blocked outgoing edge in @qends structure and tries to allocate slot from it.
Parameters
qedgepPlace to store pointer to found edge.
slotpPlace to store pointer to allocated slot.
cmdCommand type for slot.
Returns
If there is no usable edge or there is no free slot in edge negative value is returned.
◆ rtems_can_queue_get_inslot_for_prio()
int rtems_can_queue_get_inslot_for_prio ( struct rtems_can_queue_ends qends,
const struct can_frame_header header,
int  cmd,
int  prio
Function looks for the non-blocked outgoing edge accepting messages with given ID. If edge is found, slot is allocated from that edge. The edges with non-zero mask are preferred over edges open to all messages. If more edges with mask accepts given message ID, the edge with highest priority below or equal to required priority is selected.
Parameters
can_frame_headerPointer to CAN frame header.
prioOptional priority of message,
Returns
◆ rtems_can_queue_pending_outslot_prio()
int rtems_can_queue_pending_outslot_prio ( struct rtems_can_queue_ends qends,
int  prio_min
Function searches for ready slot in active incoming edge. The difference from rtems_can_queue_test_outslot function is that this function does not retreive the slot from FIFO, it just checks its existence. This can be used to determined whether there is a slot with higher priority class in the infrastruce.
Parameters
prio_minMinimum slot priority to be considered
Returns
Negative value informs, that there is no ready output slot for given ends and minimum priority. Positive value informs about the available slot priority.
◆ rtems_can_queue_push_back_outslot()
int rtems_can_queue_push_back_outslot ( struct rtems_can_queue_ends qends,
Function reschedules slot previously acquired by rtems_can_queue_test_outslot function call for second time processing.
Parameters
Returns
Function cannot fail.
◆ rtems_can_queue_put_inslot()
int rtems_can_queue_put_inslot ( struct rtems_can_queue_ends qends,
Puts slot previously acquired by rtems_can_queue_get_inslot or rtems_can_queue_get_inslot_for_prio function call into FIFO queue and activates edge processing if needed.
Parameters
Returns
Positive value informs, that activation of output end has been necessary
◆ rtems_can_queue_test_inslot()
int rtems_can_queue_test_inslot ( struct rtems_can_queue_ends qends)
Function looks for the first non-blocked outgoing edge in @qends structure with free space for slot.
Parameters
Returns
0 if there is usable edge with free space available, -1 otherwise.
◆ rtems_can_queue_test_outslot()
int rtems_can_queue_test_outslot ( struct rtems_can_queue_ends qends,
Function takes highest priority active incoming edge and retrieves oldest ready slot from it.
Parameters
slotpPlace to store pointer to received slot.
Returns
Negative value informs, that there is no ready output slot for given ends. Positive value is equal to the command slot has been allocated by the input side.
