RTEMS 7.0-rc1
This structure represents the CAN message header. More...
#include <can-frame.h>
Data Fields | |
| uint64_t | timestamp |
| This member holds the CAN timestamp value. | |
| uint32_t | can_id |
| This member holds the CAN identifier value. Only first 29 bits are be valid for CAN ID. In case 31st bit is set ( CAN_ERR_ID_TAG ), the frame is not valid. In this case, it might be an error frame. | |
| uint16_t | flags |
| This member holds the CAN flags. These are used to pass additional information between driver and application. For possible flags, refer to CANFrameFlags group. | |
| uint16_t | dlen |
| This member holds the data length of CAN frame. This length does not include size of the header. | |
