RTEMS 7.0-rc1
Interrupt support. More...
#include <rtems/score/armv4.h>
#include <bsp.h>
#include <bsp/irq.h>
#include <bsp/irq-generic.h>
#include <bsp/lpc32xx.h>
#include <bsp/linker-symbols.h>
#include <bsp/mmu.h>
union  lpc32xx_irq_fields
#define LPC32XX_MIC_STATUS_MASK   0x3ffffffcU
#define LPC32XX_IRQ_BIT_OPS_DEFINE
#define LPC32XX_IRQ_BIT_OPS_FOR_REG_DEFINE
#define LPC32XX_IRQ_OFFSET_ER   0U
#define LPC32XX_IRQ_OFFSET_RSR   4U
#define LPC32XX_IRQ_OFFSET_SR   8U
#define LPC32XX_IRQ_OFFSET_APR   12U
#define LPC32XX_IRQ_OFFSET_ATR   16U
#define LPC32XX_IRQ_OFFSET_ITR   20U
bool bsp_interrupt_is_valid_vector (rtems_vector_number vector)
rtems_status_code bsp_interrupt_set_priority (rtems_vector_number vector, uint32_t priority)
 Sets the priority of the interrupt vector.
rtems_status_code bsp_interrupt_get_priority (rtems_vector_number vector, uint32_t *priority)
 Gets the priority of the interrupt vector.
void lpc32xx_irq_set_activation_polarity (rtems_vector_number vector, lpc32xx_irq_activation_polarity activation_polarity)
lpc32xx_irq_activation_polarity lpc32xx_irq_get_activation_polarity (rtems_vector_number vector)
void lpc32xx_irq_set_activation_type (rtems_vector_number vector, lpc32xx_irq_activation_type activation_type)
lpc32xx_irq_activation_type lpc32xx_irq_get_activation_type (rtems_vector_number vector)
void bsp_interrupt_dispatch (void)
rtems_status_code bsp_interrupt_get_attributes (rtems_vector_number vector, rtems_interrupt_attributes *attributes)
 Gets the attributes of the interrupt vector.
rtems_status_code bsp_interrupt_is_pending (rtems_vector_number vector, bool *pending)
 Checks if the interrupt is pending.
rtems_status_code bsp_interrupt_raise (rtems_vector_number vector)
 Causes the interrupt vector.
rtems_status_code bsp_interrupt_clear (rtems_vector_number vector)
 Clears the interrupt vector.
rtems_status_code bsp_interrupt_vector_is_enabled (rtems_vector_number vector, bool *enabled)
 Checks if the interrupt is enabled.
rtems_status_code bsp_interrupt_vector_enable (rtems_vector_number vector)
 Enables the interrupt vector.
rtems_status_code bsp_interrupt_vector_disable (rtems_vector_number vector)
 Disables the interrupt vector.
void lpc32xx_set_exception_handler (Arm_symbolic_exception_name exception, void(*handler)(void))
void bsp_interrupt_facility_initialize (void)
 BSP specific initialization.
Interrupt support.
◆ LPC32XX_IRQ_BIT_OPS_DEFINE
Value:
unsigned bit = index & 0x1fU; \
unsigned module = index >> 5
◆ LPC32XX_IRQ_BIT_OPS_FOR_REG_DEFINE
Value:
LPC32XX_IRQ_BIT_OPS_DEFINE; \
unsigned module_offset = module << 14; \
volatile uint32_t *reg = (volatile uint32_t *) \
((volatile char *) &lpc32xx.mic + module_offset + register_offset)
