RTEMS 6.2-rc3
framebuffer support. More...
#include <stdlib.h>#include <string.h>#include <stdio.h>#include <errno.h>#include <sys/types.h>#include <bsp.h>#include <bsp/raspberrypi.h>#include <bsp/mailbox.h>#include <bsp/vc.h>#include <bsp/rpi-fb.h>#include <libcpu/arm-cp15.h>#include <rtems.h>#include <rtems/libio.h>#include <rtems/fb.h>#include <rtems/framebuffer.h>#include <rtems/score/atomic.h>#include <rtems/bspIo.h>Macros | |
| #define | SCREEN_WIDTH 1024 |
| #define | SCREEN_HEIGHT 768 |
| #define | BPP 32 |
| rtems_device_driver frame_buffer_close | ( | rtems_device_major_number | major, |
| rtems_device_minor_number | minor, | ||
| void * | arg | ||
Frame Buffer Close Entry Point.
This method closes a specific device supported by the frame buffer device driver.
| [in] | major | is the device driver major number |
| [in] | minor | is the device driver minor number |
| [in] | arg | is the parameters to this call |
| rtems_device_driver frame_buffer_control | ( | rtems_device_major_number | major, |
| void * | arg | ||
Frame Buffer IO Control Entry Point.
This method performs an IO Control operation on a specific device supported by the frame buffer device driver.
| rtems_device_driver frame_buffer_initialize | ( | rtems_device_major_number | major, |
| void * | arg | ||
Frame Buffer Initialization Entry Point.
This method initializes the frame buffer device driver.
| rtems_device_driver frame_buffer_open | ( | rtems_device_major_number | major, |
| void * | arg | ||
Frame Buffer Open Entry Point.
This method opens a specific device supported by the frame buffer device driver.
| rtems_device_driver frame_buffer_read | ( | rtems_device_major_number | major, |
| void * | arg | ||
Frame Buffer Read Entry Point.
This method reads from a specific device supported by the frame buffer device driver.
| rtems_device_driver frame_buffer_write | ( | rtems_device_major_number | major, |
| void * | arg | ||
Frame Buffer Write Entry Point.
This method writes to a specific device supported by the frame buffer device driver.
