RTEMS 6.2-rc3
libio.h
2
15/*
16 * COPYRIGHT (C) 1989, 2021 On-Line Applications Research Corporation (OAR).
17 *
18 * Modifications to support reference counting in the file system are
19 * Copyright (C) 2012 embedded brains GmbH & Co. KG
20 *
21 * Copyright (C) 2025 Contemporary Software
22 *
23 * Redistribution and use in source and binary forms, with or without
24 * modification, are permitted provided that the following conditions
25 * are met:
26 * 1. Redistributions of source code must retain the above copyright
27 * notice, this list of conditions and the following disclaimer.
28 * 2. Redistributions in binary form must reproduce the above copyright
29 * notice, this list of conditions and the following disclaimer in the
30 * documentation and/or other materials provided with the distribution.
31 *
32 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
33 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
34 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
35 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
36 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
37 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
38 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
39 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
40 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
41 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
42 * POSSIBILITY OF SUCH DAMAGE.
43 */
44
45#ifndef _RTEMS_RTEMS_LIBIO_H
46#define _RTEMS_RTEMS_LIBIO_H
47
48#include <sys/types.h>
49#include <sys/stat.h>
50#include <sys/ioccom.h>
51#include <sys/statvfs.h>
52#include <sys/uio.h>
53
54#include <unistd.h>
55#include <termios.h>
56
57#include <rtems.h>
58#include <rtems/fs.h>
59#include <rtems/chain.h>
60#include <rtems/score/atomic.h>
61#include <rtems/termiosdevice.h>
62
63#ifdef __cplusplus
64extern "C" {
65#endif
66
67struct knote;
68
89);
90
100);
101
105typedef struct {
109 const char *path;
110
114 size_t pathlen;
115
120 const char *token;
121
126 size_t tokenlen;
127
140 int flags;
141
148
157
163
170
180);
181
196 const rtems_filesystem_location_info_t *parentloc,
197 const rtems_filesystem_location_info_t *targetloc,
198 const char *name,
199 size_t namelen
200);
201
215 mode_t mode
216);
217
232 uid_t owner,
233 gid_t group
234);
235
253);
254
264);
265
284);
285
300 const void *data
301);
302
319);
320
334);
335
353);
354
372 const rtems_filesystem_location_info_t *parentloc,
373 const char *name,
374 size_t namelen,
375 mode_t mode,
376 dev_t dev
377);
378
391 const rtems_filesystem_location_info_t *parentloc,
393);
394
408 struct timespec times[2]
409);
410
426 const rtems_filesystem_location_info_t *parentloc,
427 const char *name,
428 size_t namelen,
429 const char *target
430);
431
446 char *buf,
447 size_t bufsize
448);
449
465 const rtems_filesystem_location_info_t *oldparentloc,
467 const rtems_filesystem_location_info_t *newparentloc,
468 const char *name,
469 size_t namelen
470);
471
485 struct statvfs *buf
486);
487
496 rtems_filesystem_are_nodes_equal_t are_nodes_equal_h;
505 rtems_filesystem_fsunmount_me_t fsunmount_me_h;
511};
512
518
526);
527
535);
536
545);
546
553 const rtems_filesystem_location_info_t *parentloc,
554 const rtems_filesystem_location_info_t *targetloc,
555 const char *name,
556 size_t namelen
557);
558
574);
575
582 const rtems_filesystem_location_info_t *parentloc,
583 const char *name,
584 size_t namelen,
585 mode_t mode,
586 dev_t dev
587);
588
595 const rtems_filesystem_location_info_t *parentloc,
597);
598
606 mode_t mode
607);
608
616 uid_t owner,
617 gid_t group
618);
619
627);
628
634);
635
642 rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
643);
644
651 rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
652);
653
660 rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
661);
662
670 struct timespec times[2]
671);
672
679 const rtems_filesystem_location_info_t *parentloc,
680 const char *name,
681 size_t namelen,
682 const char *target
683);
684
692 char *buf,
693 size_t bufsize
694);
695
702 const rtems_filesystem_location_info_t *oldparentloc,
704 const rtems_filesystem_location_info_t *newparentloc,
705 const char *name,
706 size_t namelen
707);
708
716 struct statvfs *buf
717);
718
744 rtems_libio_t *iop,
745 const char *path,
746 int oflag,
747 mode_t mode
748);
749
761 rtems_libio_t *iop
762);
763
778typedef ssize_t (*rtems_filesystem_read_t)(
779 rtems_libio_t *iop,
780 void *buffer,
781 size_t count
782);
783
800typedef ssize_t (*rtems_filesystem_readv_t)(
801 rtems_libio_t *iop,
802 const struct iovec *iov,
803 int iovcnt,
804 ssize_t total
805);
806
821typedef ssize_t (*rtems_filesystem_write_t)(
822 rtems_libio_t *iop,
823 const void *buffer,
824 size_t count
825);
826
843typedef ssize_t (*rtems_filesystem_writev_t)(
844 rtems_libio_t *iop,
845 const struct iovec *iov,
846 int iovcnt,
847 ssize_t total
848);
849
863 rtems_libio_t *iop,
864 ioctl_command_t request,
865 void *buffer
866);
867
883 rtems_libio_t *iop,
884 off_t offset,
885 int whence
886);
887
901 struct stat *buf
902);
903
917 rtems_libio_t *iop,
918 off_t length
919);
920
933 rtems_libio_t *iop
934);
935
948 rtems_libio_t *iop
949);
950
963 rtems_libio_t *iop,
964 int cmd
965);
966
978 rtems_libio_t *iop,
979 int events
980);
981
994 rtems_libio_t *iop,
995 struct knote *kn
996);
997
1013 rtems_libio_t *iop,
1014 void **addr,
1015 size_t len,
1016 int prot,
1017 off_t off
1018);
1019
1031 rtems_filesystem_ftruncate_t ftruncate_h;
1033 rtems_filesystem_fdatasync_t fdatasync_h;
1036 rtems_filesystem_kqfilter_t kqfilter_h;
1040};
1041
1047
1054 rtems_libio_t *iop,
1055 const char *path,
1056 int oflag,
1057 mode_t mode
1058);
1059
1066 rtems_libio_t *iop
1067);
1068
1075 rtems_libio_t *iop,
1076 void *buffer,
1077 size_t count
1078);
1079
1086 rtems_libio_t *iop,
1087 const struct iovec *iov,
1088 int iovcnt,
1089 ssize_t total
1090);
1091
1098 rtems_libio_t *iop,
1099 const void *buffer,
1100 size_t count
1101);
1102
1109 rtems_libio_t *iop,
1110 const struct iovec *iov,
1111 int iovcnt,
1112 ssize_t total
1113);
1114
1121 rtems_libio_t *iop,
1122 ioctl_command_t request,
1123 void *buffer
1124);
1125
1132 rtems_libio_t *iop,
1133 off_t offset,
1134 int whence
1135);
1136
1149 rtems_libio_t *iop,
1150 off_t offset,
1151 int whence
1152);
1153
1172 rtems_libio_t *iop,
1173 off_t offset,
1174 int whence
1175);
1176
1186 struct stat *buf
1187);
1188
1195 rtems_libio_t *iop,
1196 off_t length
1197);
1198
1205 rtems_libio_t *iop,
1206 off_t length
1207);
1208
1215 rtems_libio_t *iop
1216);
1217
1224 rtems_libio_t *iop
1225);
1226
1233 rtems_libio_t *iop,
1234 int cmd
1235);
1236
1245 rtems_libio_t *iop,
1246 int events
1247);
1248
1257 rtems_libio_t *iop,
1258 struct knote *kn
1259);
1260
1269 rtems_libio_t *iop,
1270 void **addr,
1271 size_t len,
1272 int prot,
1273 off_t off
1274);
1275
1292typedef off_t rtems_off64_t __attribute__((deprecated));
1293
1302 const char *type
1303);
1304
1309typedef struct {
1310 int link_max; /* count */
1311 int max_canon; /* max formatted input line size */
1312 int max_input; /* max input line size */
1313 int name_max; /* max name length */
1314 int path_max; /* max path */
1315 int pipe_buf; /* pipe buffer size */
1316 int posix_async_io; /* async IO supported on fs, 0=no, 1=yes */
1317 int posix_chown_restrictions; /* can chown: 0=no, 1=yes */
1318 int posix_no_trunc; /* error on names > max name, 0=no, 1=yes */
1319 int posix_prio_io; /* priority IO, 0=no, 1=yes */
1320 int posix_sync_io; /* file can be sync'ed, 0=no, 1=yes */
1321 int posix_vdisable; /* special char processing, 0=no, 1=yes */
1323
1331
1341 Atomic_Uint flags;
1342 off_t offset; /* current offset into file */
1344 uint32_t data0; /* private to "driver" */
1345 void *data1; /* ... */
1346};
1347
1354typedef struct {
1355 rtems_libio_t *iop;
1356 off_t offset;
1357 char *buffer;
1358 uint32_t count;
1359 uint32_t flags;
1360 uint32_t bytes_moved;
1362
1367 rtems_libio_t *iop;
1368 uint32_t flags;
1369 uint32_t mode;
1371
1375typedef struct {
1376 rtems_libio_t *iop;
1377 ioctl_command_t command;
1378 void *buffer;
1379 int ioctl_return;
1381
1387#define LIBIO_FLAGS_FREE 0x0001U /* on the free list */
1388#define LIBIO_FLAGS_NO_DELAY 0x0002U /* return immediately if no data */
1389#define LIBIO_FLAGS_READ 0x0004U /* reading */
1390#define LIBIO_FLAGS_WRITE 0x0008U /* writing */
1391#define LIBIO_FLAGS_OPEN 0x0100U /* device is open */
1392#define LIBIO_FLAGS_APPEND 0x0200U /* all writes append */
1393#define LIBIO_FLAGS_CLOSE_BUSY 0x0400U /* close with refs held */
1394#define LIBIO_FLAGS_CLOSE_ON_EXEC 0x0800U /* close on process exec() */
1395#define LIBIO_FLAGS_REFERENCE_INC 0x1000U
1396/* masks */
1397#define LIBIO_FLAGS_READ_WRITE (LIBIO_FLAGS_READ | LIBIO_FLAGS_WRITE)
1398#define LIBIO_FLAGS_FLAGS_MASK (LIBIO_FLAGS_REFERENCE_INC - 1U)
1399#define LIBIO_FLAGS_REFERENCE_MASK (~LIBIO_FLAGS_FLAGS_MASK)
1400
1403static inline unsigned int rtems_libio_iop_flags( const rtems_libio_t *iop )
1404{
1405 return _Atomic_Load_uint( &iop->flags, ATOMIC_ORDER_RELAXED );
1406}
1407
1414static inline unsigned int rtems_libio_iop_flags_bad_fd(
1415 const unsigned int flags
1416)
1417{
1418 return ( ( flags & LIBIO_FLAGS_FREE ) != 0 )
1419 || ( ( flags & LIBIO_FLAGS_OPEN ) == 0 );
1420}
1421
1427static inline bool rtems_libio_iop_is_no_delay( const rtems_libio_t *iop )
1428{
1429 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_NO_DELAY ) != 0;
1430}
1431
1437static inline bool rtems_libio_iop_is_readable( const rtems_libio_t *iop )
1438{
1439 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_READ ) != 0;
1440}
1441
1447static inline bool rtems_libio_iop_is_writeable( const rtems_libio_t *iop )
1448{
1449 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_WRITE ) != 0;
1450}
1451
1457static inline bool rtems_libio_iop_is_open( const rtems_libio_t *iop )
1458{
1459 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_OPEN ) != 0;
1460}
1461
1467static inline bool rtems_libio_iop_is_append( const rtems_libio_t *iop )
1468{
1469 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_APPEND ) != 0;
1470}
1471
1477static inline bool rtems_libio_iop_is_held( const rtems_libio_t *iop )
1478{
1479 const unsigned int ref_count =
1480 rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_REFERENCE_MASK;
1481 return ref_count != 0;
1482}
1483
1489static inline bool rtems_libio_iop_is_free( const rtems_libio_t *iop )
1490{
1491 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_FREE ) != 0;
1492}
1493
1499typedef int (*rtems_libio_open_t)(
1500 const char *pathname,
1501 uint32_t flag,
1502 uint32_t mode
1503);
1504
1505typedef int (*rtems_libio_close_t)(
1506 int fd
1507);
1508
1509typedef ssize_t (*rtems_libio_read_t)(
1510 int fd,
1511 void *buffer,
1512 size_t count
1513);
1514
1515typedef ssize_t (*rtems_libio_write_t)(
1516 int fd,
1517 const void *buffer,
1518 size_t count
1519);
1520
1521typedef int (*rtems_libio_ioctl_t)(
1522 int fd,
1523 uint32_t command,
1524 void *buffer
1525);
1526
1527typedef off_t (*rtems_libio_lseek_t)(
1528 int fd,
1529 off_t offset,
1530 int whence
1531);
1532
1540/*
1541 * The following macros are used to build up the permissions sets
1542 * used to check permissions. These are similar in style to the
1543 * mode_t bits and should stay compatible with them.
1544 */
1545#define RTEMS_FS_PERMS_READ 0x4
1546#define RTEMS_FS_PERMS_WRITE 0x2
1547#define RTEMS_FS_PERMS_EXEC 0x1
1548#define RTEMS_FS_PERMS_RWX \
1549 (RTEMS_FS_PERMS_READ | RTEMS_FS_PERMS_WRITE | RTEMS_FS_PERMS_EXEC)
1550#define RTEMS_FS_FOLLOW_HARD_LINK 0x8
1551#define RTEMS_FS_FOLLOW_SYM_LINK 0x10
1552#define RTEMS_FS_FOLLOW_LINK \
1553 (RTEMS_FS_FOLLOW_HARD_LINK | RTEMS_FS_FOLLOW_SYM_LINK)
1554#define RTEMS_FS_MAKE 0x20
1555#define RTEMS_FS_EXCLUSIVE 0x40
1556#define RTEMS_FS_ACCEPT_RESIDUAL_DELIMITERS 0x80
1557#define RTEMS_FS_REJECT_TERMINAL_DOT 0x100
1558
1562 dev_t device;
1563 struct {
1566 } __overlay;
1567};
1568
1569static inline dev_t rtems_filesystem_make_dev_t(
1572)
1573{
1574 union __rtems_dev_t temp;
1575
1576 temp.__overlay.major = _major;
1577 temp.__overlay.minor = _minor;
1578 return temp.device;
1579}
1580
1581static inline dev_t rtems_filesystem_make_dev_t_from_pointer(
1582 const void *pointer
1583)
1584{
1585 uint64_t temp = (((uint64_t) 1) << 63) | (((uintptr_t) pointer) >> 1);
1586
1587 return rtems_filesystem_make_dev_t((uint32_t) (temp >> 32), (uint32_t) temp);
1588}
1589
1590static inline rtems_device_major_number rtems_filesystem_dev_major_t(
1591 dev_t device
1592)
1593{
1594 union __rtems_dev_t temp;
1595
1596 temp.device = device;
1597 return temp.__overlay.major;
1598}
1599
1600
1601static inline rtems_device_minor_number rtems_filesystem_dev_minor_t(
1602 dev_t device
1603)
1604{
1605 union __rtems_dev_t temp;
1606
1607 temp.device = device;
1608 return temp.__overlay.minor;
1609}
1610
1611#define rtems_filesystem_split_dev_t( _dev, _major, _minor ) \
1612 do { \
1613 (_major) = rtems_filesystem_dev_major_t ( _dev ); \
1614 (_minor) = rtems_filesystem_dev_minor_t( _dev ); \
1615 } while(0)
1616
1617/*
1618 * Prototypes for filesystem
1619 */
1620
1629void rtems_filesystem_initialize( void );
1630
1631void rtems_libio_post_driver(void);
1632
1633void rtems_libio_exit(void);
1634
1644extern int rtems_mkdir(const char *path, mode_t mode);
1645
1662#define RTEMS_FILESYSTEM_TYPE_IMFS "imfs"
1663#define RTEMS_FILESYSTEM_TYPE_FTPFS "ftpfs"
1664#define RTEMS_FILESYSTEM_TYPE_TFTPFS "tftpfs"
1665#define RTEMS_FILESYSTEM_TYPE_NFS "nfs"
1666#define RTEMS_FILESYSTEM_TYPE_DOSFS "dosfs"
1667#define RTEMS_FILESYSTEM_TYPE_RFS "rfs"
1668#define RTEMS_FILESYSTEM_TYPE_JFFS2 "jffs2"
1669
1676 rtems_chain_node mt_node;
1677 void *fs_info;
1679 const void *immutable_fs_info;
1680 rtems_chain_control location_chain;
1683 bool mounted;
1684 bool writeable;
1685 bool no_regular_file_mknod;
1686 const rtems_filesystem_limits_and_options_t *pathconf_limits_and_options;
1687
1688 /*
1689 * The target or mount point of the file system.
1690 */
1691 const char *target;
1692
1693 /*
1694 * The type of filesystem or the name of the filesystem.
1695 */
1696 const char *type;
1697
1698 /*
1699 * When someone adds a mounted filesystem on a real device,
1700 * this will need to be used.
1701 *
1702 * The lower layers can manage how this is managed. Leave as a
1703 * string.
1704 */
1705 char *dev;
1706
1714};
1715
1719typedef enum {
1720 RTEMS_FILESYSTEM_READ_ONLY,
1721 RTEMS_FILESYSTEM_READ_WRITE,
1722 RTEMS_FILESYSTEM_BAD_OPTIONS
1724
1729 const char *type;
1732
1739
1740extern rtems_chain_control rtems_filesystem_mount_table;
1741
1751 const char *type,
1753);
1754
1762 const char *type
1763);
1764
1787int unmount(
1788 const char *mount_path
1789);
1790
1838int mount(
1839 const char *source,
1840 const char *target,
1841 const char *filesystemtype,
1843 const void *data
1844);
1845
1858 const char *source,
1859 const char *target,
1860 const char *filesystemtype,
1862 const void *data
1863);
1864
1874 const rtems_filesystem_table_t *fs_entry,
1875 void *arg
1876);
1877
1893 void *routine_arg
1894);
1895
1906 void *arg
1907);
1908
1924 void *visitor_arg
1925);
1926
1927typedef struct {
1928 const char *source;
1929 const char *target;
1930 const char *filesystemtype;
1932 const void *data;
1934
1936 rtems_filesystem_root_configuration;
1937
1949struct rtems_termios_tty;
1950
1952 int (*firstOpen)(int major, int minor, void *arg);
1953 int (*lastClose)(int major, int minor, void *arg);
1954 int (*pollRead)(int minor);
1955 ssize_t (*write)(int minor, const char *buf, size_t len);
1956 int (*setAttributes)(int minor, const struct termios *t);
1957 int (*stopRemoteTx)(int minor);
1958 int (*startRemoteTx)(int minor);
1959 rtems_termios_device_mode outputUsesInterrupts;
1961
1962static inline void rtems_termios_initialize( void )
1963{
1964 /* Nothing to do, provided for backward compatibility */
1965}
1966
1967/*
1968 * CCJ: Change before opening a tty. Newer code from Eric is coming
1969 * so extra work to handle an open tty is not worth it. If the tty
1970 * is open, close then open it again.
1971 */
1972rtems_status_code rtems_termios_bufsize (
1973 size_t cbufsize, /* cooked buffer size */
1974 size_t raw_input, /* raw input buffer size */
1975 size_t raw_output /* raw output buffer size */
1976);
1977
1982typedef enum {
1990
2002
2010
2028 unsigned char c,
2029 struct rtems_termios_tty *tty
2030);
2031
2051 unsigned char c,
2052 struct rtems_termios_tty *tty
2053);
2054
2069 unsigned char c,
2070 struct rtems_termios_tty *tty
2071);
2072
2087);
2088
2089int rtems_termios_enqueue_raw_characters(
2090 void *ttyp,
2091 const char *buf,
2092 int len
2093);
2094
2095rtems_status_code rtems_termios_open (
2098 void *arg,
2099 const rtems_termios_callbacks *callbacks
2100);
2101
2102rtems_status_code rtems_termios_close(
2103 void *arg
2104);
2105
2106rtems_status_code rtems_termios_read(
2107 void *arg
2108);
2109
2110rtems_status_code rtems_termios_write(
2111 void *arg
2112);
2113
2114rtems_status_code rtems_termios_ioctl(
2115 void *arg
2116);
2117
2118int rtems_termios_dequeue_characters(
2119 void *ttyp,
2120 int len
2121);
2122
2128#define rtems_filesystem_pathconf(_mte) ((_mte)->pathconf_limits_and_options)
2129
2133#define rtems_filesystem_type(_mte) ((_mte)->type)
2134
2138#define rtems_filesystem_mount_point(_mte) ((_mte)->target)
2139
2143#define rtems_filesystem_mount_device(_mte) ((_mte)->dev)
2144
2145#ifdef __cplusplus
2146}
2147#endif
2148
2149#endif /* _RTEMS_LIBIO_H */
clock_t times(struct tms *ptms)
Definition: __times.c:97
This header file provides the Chains API.
bool rtems_filesystem_mount_iterate(rtems_filesystem_mt_entry_visitor visitor, void *visitor_arg)
Iterates over all file system mount entries.
Definition: sup_fs_mount_iterate.c:42
int mount_and_make_target_path(const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
Mounts a file system and makes the target path.
Definition: mount-mktgt.c:44
bool rtems_filesystem_iterate(rtems_per_filesystem_routine routine, void *routine_arg)
Iterates over all file system types.
Definition: mount-mgr.c:58
int unmount(const char *mount_path)
Unmounts the file system instance at the specified mount path.
Definition: unmount.c:62
int rtems_filesystem_unregister(const char *type)
Unregisters a file system type.
Definition: mount-mgr.c:160
const rtems_filesystem_table_t rtems_filesystem_table[]
Static table of file systems.
bool(* rtems_filesystem_mt_entry_visitor)(const rtems_filesystem_mount_table_entry_t *mt_entry, void *arg)
Mount table entry visitor.
Definition: libio.h:1904
bool(* rtems_per_filesystem_routine)(const rtems_filesystem_table_t *fs_entry, void *arg)
Per file system type routine.
Definition: libio.h:1873
int rtems_filesystem_register(const char *type, rtems_filesystem_fsmount_me_t mount_h)
Registers a file system type.
Definition: mount-mgr.c:126
File system options.
Definition: libio.h:1719
int mount(const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
Mounts a file system instance at the specified target path.
Definition: mount.c:197
int(* rtems_filesystem_ioctl_t)(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
IO control of a node.
Definition: libio.h:862
int rtems_filesystem_default_fcntl(rtems_libio_t *iop, int cmd)
Definition: default_fcntl.c:41
int(* rtems_filesystem_poll_t)(rtems_libio_t *iop, int events)
Poll and select support.
Definition: libio.h:977
int rtems_filesystem_default_ftruncate(rtems_libio_t *iop, off_t length)
Definition: default_ftruncate.c:44
int rtems_filesystem_default_ftruncate_directory(rtems_libio_t *iop, off_t length)
Definition: default_ftruncate_directory.c:43
off_t rtems_filesystem_default_lseek_directory(rtems_libio_t *iop, off_t offset, int whence)
An offset 0 with a whence of SEEK_SET will perform a directory rewind operation.
Definition: default_lseek_directory.c:42
ssize_t(* rtems_filesystem_read_t)(rtems_libio_t *iop, void *buffer, size_t count)
Reads from a node.
Definition: libio.h:778
int(* rtems_filesystem_fcntl_t)(rtems_libio_t *iop, int cmd)
File control.
Definition: libio.h:962
int rtems_filesystem_default_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
Definition: default_ioctl.c:43
int rtems_filesystem_default_poll(rtems_libio_t *iop, int events)
Default poll handler.
Definition: default_poll.c:44
int rtems_filesystem_default_fsync_or_fdatasync(rtems_libio_t *iop)
Definition: default_fsync.c:43
const rtems_filesystem_file_handlers_r rtems_filesystem_handlers_default
File system node handler table with default node handlers.
Definition: default_handlers.c:38
off_t rtems_filesystem_default_lseek_file(rtems_libio_t *iop, off_t offset, int whence)
Default lseek() handler for files.
Definition: default_lseek_file.c:42
int(* rtems_filesystem_kqfilter_t)(rtems_libio_t *iop, struct knote *kn)
Kernel event filter support.
Definition: libio.h:993
int rtems_filesystem_default_fstat(const rtems_filesystem_location_info_t *loc, struct stat *buf)
Sets the mode to S_IRWXU | S_IRWXG | S_IRWXO.
Definition: default_fstat.c:43
int rtems_filesystem_default_fsync_or_fdatasync_success(rtems_libio_t *iop)
Definition: default_fsync_success.c:42
int rtems_filesystem_default_kqfilter(rtems_libio_t *iop, struct knote *kn)
Default kernel event filter handler.
Definition: default_kqfilter.c:42
ssize_t rtems_filesystem_default_writev(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the write handler for each IO vector entry.
Definition: default_writev.c:45
int(* rtems_filesystem_close_t)(rtems_libio_t *iop)
Closes a node.
Definition: libio.h:760
ssize_t rtems_filesystem_default_readv(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the read handler for each IO vector entry.
Definition: default_readv.c:45
off_t(* rtems_filesystem_lseek_t)(rtems_libio_t *iop, off_t offset, int whence)
Moves the read/write file offset.
Definition: libio.h:882
off_t rtems_filesystem_default_lseek(rtems_libio_t *iop, off_t offset, int whence)
Definition: default_lseek.c:43
ssize_t(* rtems_filesystem_writev_t)(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Writes an IO vector to a node.
Definition: libio.h:843
int(* rtems_filesystem_fstat_t)(const rtems_filesystem_location_info_t *loc, struct stat *buf)
Gets a node status.
Definition: libio.h:899
int rtems_filesystem_default_mmap(rtems_libio_t *iop, void **addr, size_t len, int prot, off_t off)
Default MMAP handler.
Definition: default_mmap.c:42
ssize_t(* rtems_filesystem_write_t)(rtems_libio_t *iop, const void *buffer, size_t count)
Writes to a node.
Definition: libio.h:821
int rtems_filesystem_default_close(rtems_libio_t *iop)
Definition: default_close.c:37
int(* rtems_filesystem_fsync_t)(rtems_libio_t *iop)
Synchronizes changes to a file.
Definition: libio.h:932
ssize_t rtems_filesystem_default_read(rtems_libio_t *iop, void *buffer, size_t count)
Definition: default_read.c:39
int(* rtems_filesystem_fdatasync_t)(rtems_libio_t *iop)
Synchronizes the data of a file.
Definition: libio.h:947
int rtems_filesystem_default_open(rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
Definition: default_open.c:43
int(* rtems_filesystem_mmap_t)(rtems_libio_t *iop, void **addr, size_t len, int prot, off_t off)
MMAP support.
Definition: libio.h:1012
ssize_t(* rtems_filesystem_readv_t)(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Reads an IO vector from a node.
Definition: libio.h:800
ssize_t rtems_filesystem_default_write(rtems_libio_t *iop, const void *buffer, size_t count)
Definition: default_write.c:41
int(* rtems_filesystem_ftruncate_t)(rtems_libio_t *iop, off_t length)
Truncates a file to a specified length.
Definition: libio.h:916
int(* rtems_filesystem_open_t)(rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
Opens a node.
Definition: libio.h:743
int(* rtems_filesystem_statvfs_t)(const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
Gets file system information.
Definition: libio.h:483
int rtems_filesystem_default_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_unmount.c:41
int(* rtems_filesystem_link_t)(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Creates a new link for the existing file.
Definition: libio.h:195
int(* rtems_filesystem_mount_t)(rtems_filesystem_mount_table_entry_t *mt_entry)
Mounts a file system instance in a mount point (directory).
Definition: libio.h:282
int(* rtems_filesystem_fchmod_t)(const rtems_filesystem_location_info_t *loc, mode_t mode)
Changes the mode of a node.
Definition: libio.h:213
void rtems_filesystem_default_lock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Obtains the IO library mutex.
Definition: default_lock_and_unlock.c:42
int rtems_filesystem_default_rename(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Definition: default_rename.c:44
void(* rtems_filesystem_fsunmount_me_t)(rtems_filesystem_mount_table_entry_t *mt_entry)
Destroys a file system instance.
Definition: libio.h:332
int rtems_filesystem_default_mknod(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Definition: default_mknod.c:44
int rtems_filesystem_default_fchmod(const rtems_filesystem_location_info_t *loc, mode_t mode)
Definition: default_fchmod.c:42
void(* rtems_filesystem_eval_path_t)(rtems_filesystem_eval_path_context_t *ctx)
Path evaluation.
Definition: libio.h:178
int(* rtems_filesystem_unmount_t)(rtems_filesystem_mount_table_entry_t *mt_entry)
Unmounts a file system instance in a mount point (directory).
Definition: libio.h:317
int rtems_filesystem_default_clonenode(rtems_filesystem_location_info_t *loc)
Definition: default_clone.c:42
void rtems_filesystem_default_unlock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Releases the IO library mutex.
Definition: default_lock_and_unlock.c:49
bool rtems_filesystem_default_are_nodes_equal(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node access pointer of one location is equal to the node access pointer of the other loc...
Definition: default_are_nodes_equal.c:42
int(* rtems_filesystem_rmnod_t)(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Removes a node.
Definition: libio.h:390
int rtems_filesystem_default_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Definition: default_rmnod.c:44
int(* rtems_filesystem_rename_t)(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Renames a node.
Definition: libio.h:464
int rtems_filesystem_default_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_mount.c:41
int(* rtems_filesystem_clonenode_t)(rtems_filesystem_location_info_t *loc)
Clones a location.
Definition: libio.h:251
void rtems_filesystem_default_freenode(const rtems_filesystem_location_info_t *loc)
Definition: default_freenode.c:43
ssize_t(* rtems_filesystem_readlink_t)(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Reads the contents of a symbolic link.
Definition: libio.h:444
void rtems_filesystem_default_fsunmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_fsunmount.c:39
int(* rtems_filesystem_mknod_t)(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Creates a new node.
Definition: libio.h:371
bool(* rtems_filesystem_are_nodes_equal_t)(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node of one location is equal to the node of the other location.
Definition: libio.h:350
void(* rtems_filesystem_mt_entry_unlock_t)(const rtems_filesystem_mount_table_entry_t *mt_entry)
Unlocks a file system instance.
Definition: libio.h:98
void rtems_filesystem_default_eval_path(rtems_filesystem_eval_path_context_t *ctx)
Terminates the path evaluation and replaces the current location with the null location.
Definition: default_eval_path.c:42
int rtems_filesystem_default_symlink(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Definition: default_symlink.c:44
int rtems_filesystem_default_statvfs(const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
Definition: default_statvfs.c:42
int(* rtems_filesystem_utimens_t)(const rtems_filesystem_location_info_t *loc, struct timespec times[2])
Set node access and modification times.
Definition: libio.h:406
int(* rtems_filesystem_fsmount_me_t)(rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
Initializes a file system instance.
Definition: libio.h:298
int(* rtems_filesystem_chown_t)(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Changes owner and group of a node.
Definition: libio.h:230
const rtems_filesystem_operations_table rtems_filesystem_operations_default
File system operations table with default operations.
Definition: default_ops.c:38
void(* rtems_filesystem_freenode_t)(const rtems_filesystem_location_info_t *loc)
Frees the location of a node.
Definition: libio.h:262
void(* rtems_filesystem_mt_entry_lock_t)(const rtems_filesystem_mount_table_entry_t *mt_entry)
Locks a file system instance.
Definition: libio.h:87
int rtems_filesystem_default_chown(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Definition: default_chown.c:42
ssize_t rtems_filesystem_default_readlink(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Definition: default_readlink.c:44
int(* rtems_filesystem_symlink_t)(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Makes a symbolic link to a node.
Definition: libio.h:425
int rtems_filesystem_default_link(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Definition: default_link.c:42
int rtems_filesystem_default_utimens(const rtems_filesystem_location_info_t *loc, struct timespec times[2])
Definition: default_utimens.c:43
struct rtems_libio_open_close_args rtems_libio_open_close_args_t
Parameter block for open/close.
rtems_filesystem_fsmount_me_t rtems_filesystem_get_mount_handler(const char *type)
Gets the mount handler for the file system type.
Definition: mount-mgr.c:109
Creates a directory and all its parent directories according to path.
Definition: rtems_mkdir.c:130
void rtems_filesystem_initialize(void)
Base File System Initialization.
Definition: base_fs.c:51
const rtems_filesystem_limits_and_options_t rtems_filesystem_default_pathconf
Default pathconf settings.
Definition: mount.c:49
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition: io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
rtems_termios_iproc_status_code rtems_termios_default_isig_handler(unsigned char c, struct rtems_termios_tty *tty)
Default handler for ISIG (VINTR/VKILL)
Definition: termios.c:1312
rtems_termios_iproc_status_code(* rtems_termios_isig_handler)(unsigned char c, struct rtems_termios_tty *tty)
Type for ISIG (VINTR/VKILL) handler.
Definition: libio.h:2027
The status code returned by all Termios input processing (iproc) functions and input signal (isig) ha...
Definition: libio.h:1982
rtems_status_code rtems_termios_register_isig_handler(rtems_termios_isig_handler handler)
Register handler for ISIG (VINTR/VKILL)
Definition: termios.c:1324
rtems_termios_iproc_status_code rtems_termios_posix_isig_handler(unsigned char c, struct rtems_termios_tty *tty)
POSIX handler for ISIG (VINTR/VKILL)
Definition: termios_posix_isig_handler.c:23
@ RTEMS_TERMIOS_IPROC_DONE
This status indicates that the input processing is done.
Definition: libio.h:2008
@ RTEMS_TERMIOS_IPROC_CONTINUE
This status indicates that the input processing can continue.
Definition: libio.h:1989
@ RTEMS_TERMIOS_IPROC_INTERRUPT
This status indicates that the input processing should stop due to a signal.
Definition: libio.h:2001
rtems_termios_device_handler handler
The device handler.
Definition: termiostypes.h:166
Basic Filesystem Types.
This header file provides the interfaces of the Atomic Operations.
This header file provides the statvfs() and fstatvfs() interfaces.
This structure represents a chain node.
Definition: chain.h:78
Definition: xnandpsu_onfi.h:185
File system node operations table.
Definition: libio.h:1023
File system operations table.
Definition: libio.h:491
Definition: iterateoverthreads.c:44
Path evaluation context.
Definition: libio.h:105
int recursionlevel
Definition: libio.h:147
rtems_filesystem_location_info_t currentloc
Definition: libio.h:156
const char * path
Definition: libio.h:109
size_t pathlen
Definition: libio.h:114
rtems_filesystem_global_location_t * rootloc
Definition: libio.h:162
size_t tokenlen
Definition: libio.h:126
const char * token
Definition: libio.h:120
int flags
Definition: libio.h:140
rtems_filesystem_global_location_t * startloc
Definition: libio.h:168
Global file system location.
Definition: fs.h:100
Contain file system specific information which is required to support fpathconf().
Definition: libio.h:1309
File system location.
Definition: fs.h:72
Definition: libio.h:1927
Mount table entry.
Definition: libio.h:1675
rtems_id unmount_task
Definition: libio.h:1713
File system table entry.
Definition: libio.h:1728
Parameter block for ioctl.
Definition: libio.h:1375
Definition: libio.h:1366
Paramameter block for read/write.
Definition: libio.h:1354
An open file data structure.
Definition: libio.h:1340
Definition: libio.h:1951
Definition: termiostypes.h:94
Definition: statvfs.h:56
This header file provides the interfaces of the RTEMS Termios Device Support.
This union represents a chain control block.
Definition: chain.h:96
Definition: libio.h:1561
