RTEMS 6.2-rc2
Test context for spec:/rtems/scheduler/req/ident-by-processor-set test case. More...
Data Fields | |
| rtems_id | second_scheduler_id |
| This member contains the identifier of a second scheduler. | |
| cpu_set_t | cpuset_value |
This member provides the object referenced by the cpuset parameter. | |
| rtems_id | id_value |
This member provides the object referenced by the id parameter. | |
| bool | cpu_has_scheduler |
If this member is true, then the processor specified by the cpusetsize parameter shall be owned by a scheduler. | |
| rtems_status_code | status |
| This member contains the return value of the rtems_scheduler_ident_by_processor_set() call. | |
| size_t | cpusetsize |
This member specifies if the cpusetsize parameter value. | |
| const cpu_set_t * | cpuset |
This member specifies if the cpuset parameter value. | |
| rtems_id * | id |
This member specifies if the id parameter value. | |
| struct { | |
| size_t pci [5] | |
| This member defines the pre-condition indices for the next action. | |
| size_t pcs [5] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsSchedulerReqIdentByProcessorSet_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
