RTEMS 6.2-rc2
Macros | Functions
Scheduler Manager
The scheduling concepts relate to the allocation of processing time for tasks. More...
#define rtems_scheduler_get_processor(void)   _SMP_Get_current_processor()
 Returns the index of the current processor.
#define rtems_scheduler_get_processor_maximum(void)   _SMP_Get_processor_maximum()
 Returns the processor maximum supported by the system.
rtems_status_code rtems_scheduler_ident (rtems_name name, rtems_id *id)
 Identifies a scheduler by the object name.
rtems_status_code rtems_scheduler_ident_by_processor (uint32_t cpu_index, rtems_id *id)
 Identifies a scheduler by the processor index.
rtems_status_code rtems_scheduler_ident_by_processor_set (size_t cpusetsize, const cpu_set_t *cpuset, rtems_id *id)
 Identifies a scheduler by the processor set.
rtems_status_code rtems_scheduler_get_maximum_priority (rtems_id scheduler_id, rtems_task_priority *priority)
 Gets the maximum task priority of the scheduler.
rtems_status_code rtems_scheduler_map_priority_to_posix (rtems_id scheduler_id, rtems_task_priority priority, int *posix_priority)
 Maps a Classic API task priority to the corresponding POSIX thread priority.
rtems_status_code rtems_scheduler_map_priority_from_posix (rtems_id scheduler_id, int posix_priority, rtems_task_priority *priority)
 Maps a POSIX thread priority to the corresponding Classic API task priority.
rtems_status_code rtems_scheduler_get_processor_set (rtems_id scheduler_id, size_t cpusetsize, cpu_set_t *cpuset)
 Gets the set of processors owned by the scheduler.
rtems_status_code rtems_scheduler_add_processor (rtems_id scheduler_id, uint32_t cpu_index)
 Adds the processor to the set of processors owned by the scheduler.
rtems_status_code rtems_scheduler_remove_processor (rtems_id scheduler_id, uint32_t cpu_index)
 Removes the processor from the set of processors owned by the scheduler.
The concept of scheduling in real-time systems dictates the ability to provide an immediate response to specific external events, particularly the necessity of scheduling tasks to run within a specified time limit after the occurrence of an event. For example, software embedded in life-support systems used to monitor hospital patients must take instant action if a change in the patient's status is detected.
The component of RTEMS responsible for providing this capability is appropriately called the scheduler. The scheduler's sole purpose is to allocate the all important resource of processor time to the various tasks competing for attention.
◆ rtems_scheduler_get_processor
uint32_t rtems_scheduler_get_processor (   void)    _SMP_Get_current_processor()
Where the system was built with SMP support disabled, this directive evaluates to a compile time constant of zero.
Where the system was built with SMP support enabled, this directive returns the index of the current processor. The set of processor indices is the range of integers starting with zero up to rtems_scheduler_get_processor_maximum() minus one.
Returns
Notes
Outside of sections with disabled thread dispatching the current processor index may change after every instruction since the thread may migrate from one processor to another. Sections with disabled interrupts are sections with thread dispatching disabled.
Constraints
The following constraints apply to this directive:
  • The directive may be called from within any runtime context.
  • The directive will not cause the calling task to be preempted.
◆ rtems_scheduler_get_processor_maximum
uint32_t rtems_scheduler_get_processor_maximum (   void)    _SMP_Get_processor_maximum()
Where the system was built with SMP support disabled, this directive evaluates to a compile time constant of one.
Where the system was built with SMP support enabled, this directive returns the minimum of the processors (physically or virtually) available at the target and the configured processor maximum (see CONFIGURE_MAXIMUM_PROCESSORS). Not all processors in the range from processor index zero to the last processor index (which is the processor maximum minus one) may be configured to be used by a scheduler or may be online (online processors have a scheduler assigned).
Returns
Constraints
◆ rtems_scheduler_add_processor()
rtems_status_code rtems_scheduler_add_processor ( rtems_id  scheduler_id,
uint32_t  cpu_index
Parameters
scheduler_idis the scheduler identifier.
cpu_indexis the index of the processor to add.
This directive adds the processor specified by the cpu_index to the scheduler specified by scheduler_id.
Return values
RTEMS_SUCCESSFULThe requested operation was successful.
RTEMS_INVALID_IDThere was no scheduler associated with the identifier specified by scheduler_id.
RTEMS_NOT_CONFIGUREDThe processor was not configured to be used by the application.
RTEMS_INCORRECT_STATEThe processor was configured to be used by the application, however, it was not online.
RTEMS_RESOURCE_IN_USEThe processor was already assigned to a scheduler.
Constraints
  • The directive may be called from within device driver initialization context.
  • The directive may be called from within task context.
  • The directive may obtain and release the object allocator mutex. This may cause the calling task to be preempted.
◆ rtems_scheduler_get_maximum_priority()
rtems_status_code rtems_scheduler_get_maximum_priority ( rtems_id  scheduler_id,
Parameters
[out]priorityis the pointer to an rtems_task_priority object. When the directive the maximum priority of the scheduler will be stored in this object.
Return values
RTEMS_INVALID_ADDRESSThe priority parameter was NULL.
Constraints
◆ rtems_scheduler_get_processor_set()
rtems_status_code rtems_scheduler_get_processor_set ( rtems_id  scheduler_id,
size_t  cpusetsize,
cpu_set_t *  cpuset
Parameters
cpusetsizeis the size of the processor set referenced by cpuset in bytes.
[out]cpusetis the pointer to a cpu_set_t object. When the directive call is successful, the processor set of the scheduler will be stored in this object. A set bit in the processor set means that the corresponding processor is owned by the scheduler, otherwise the bit is cleared.
Return values
RTEMS_INVALID_ADDRESSThe cpuset parameter was NULL.
RTEMS_INVALID_SIZEThe provided processor set was too small for the set of processors owned by the scheduler.
Constraints
◆ rtems_scheduler_ident()
rtems_status_code rtems_scheduler_ident ( rtems_name  name,
rtems_id id
Parameters
nameis the scheduler name to look up.
[out]idis the pointer to an rtems_id object. When the directive call is successful, the identifier of the scheduler will be stored in this object.
This directive obtains a scheduler identifier associated with the scheduler name specified in name.
Return values
RTEMS_INVALID_NAMEThere was no scheduler associated with the name.
RTEMS_INVALID_ADDRESSThe id parameter was NULL.
Notes
The scheduler name is determined by the scheduler configuration.
The scheduler identifier is used with other scheduler related directives to access the scheduler.
Constraints
◆ rtems_scheduler_ident_by_processor()
rtems_status_code rtems_scheduler_ident_by_processor ( uint32_t  cpu_index,
rtems_id id
Parameters
cpu_indexis the processor index to identify the scheduler.
Return values
RTEMS_INVALID_NAMEThe processor index was invalid.
RTEMS_INCORRECT_STATEThe processor index was valid, however, the corresponding processor was not owned by a scheduler.
Constraints
◆ rtems_scheduler_ident_by_processor_set()
rtems_status_code rtems_scheduler_ident_by_processor_set ( size_t  cpusetsize,
const cpu_set_t *  cpuset,
rtems_id id
Parameters
cpusetsizeis the size of the processor set referenced by cpuset in bytes. The size shall be positive.
cpusetis the pointer to a cpu_set_t. The referenced processor set will be used to identify the scheduler.
The scheduler is selected according to the highest numbered online processor in the specified processor set.
Return values
RTEMS_INVALID_SIZEThe processor set size was invalid.
RTEMS_INVALID_NAMEThe processor set contained no online processor.
RTEMS_INCORRECT_STATEThe processor set was valid, however, the highest numbered online processor in the processor set was not owned by a scheduler.
Constraints
◆ rtems_scheduler_map_priority_from_posix()
rtems_status_code rtems_scheduler_map_priority_from_posix ( rtems_id  scheduler_id,
int  posix_priority,
Parameters
posix_priorityis the POSIX thread priority to map.
[out]priorityis the pointer to an rtems_task_priority object. When the directive call is successful, the Classic API task priority value corresponding to the specified POSIX thread priority value will be stored in this object.
Return values
RTEMS_INVALID_PRIORITYThe POSIX thread priority was invalid.
Constraints
◆ rtems_scheduler_map_priority_to_posix()
rtems_status_code rtems_scheduler_map_priority_to_posix ( rtems_id  scheduler_id,
int *  posix_priority
Parameters
priorityis the Classic API task priority to map.
[out]posix_priorityis the pointer to an int object. When the directive call is successful, the POSIX thread priority value corresponding to the specified Classic API task priority value will be stored in this object.
Return values
RTEMS_INVALID_ADDRESSThe posix_priority parameter was NULL.
RTEMS_INVALID_PRIORITYThe Classic API task priority was invalid.
Constraints
◆ rtems_scheduler_remove_processor()
rtems_status_code rtems_scheduler_remove_processor ( rtems_id  scheduler_id,
uint32_t  cpu_index
Parameters
cpu_indexis the index of the processor to remove.
This directive removes the processor specified by the cpu_index from the scheduler specified by scheduler_id.
Return values
RTEMS_INVALID_NUMBERThe processor was not owned by the scheduler.
RTEMS_RESOURCE_IN_USEThe processor was required by at least one non-idle task that used the scheduler as its home scheduler.
RTEMS_RESOURCE_IN_USEThe processor was the last processor owned by the scheduler and there was at least one task that used the scheduler as a helping scheduler.
Notes
Removing a processor from a scheduler is a complex operation that involves all tasks of the system.
Constraints
