RTEMS 6.2-rc1
Files | |
| file | ramdisk-config.c |
| RAM disk block device implementation. | |
| file | ramdisk-driver.c |
| file | ramdisk-init.c |
| file | ramdisk-register.c |
| struct | rtems_ramdisk_config |
| RAM disk configuration table entry. More... | |
| struct | ramdisk |
| RAM disk descriptor. More... | |
Static Configuration | |
| typedef struct rtems_ramdisk_config | rtems_ramdisk_config |
| RAM disk configuration table entry. | |
| rtems_ramdisk_config | rtems_ramdisk_configuration [] |
| External reference to the RAM disk configuration table describing each RAM disk in the system. | |
| size_t | rtems_ramdisk_configuration_size |
| External reference the size of the RAM disk configuration table rtems_ramdisk_configuration. | |
| rtems_device_driver | ramdisk_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| RAM disk driver initialization entry point. | |
| #define | RAMDISK_DRIVER_TABLE_ENTRY |
| #define | RAMDISK_DEVICE_BASE_NAME "/dev/rd" |
Runtime Configuration | |
| typedef struct ramdisk | ramdisk |
| RAM disk descriptor. | |
| int | ramdisk_ioctl (rtems_disk_device *dd, uint32_t req, void *argp) |
| ramdisk * | ramdisk_allocate (void *area_begin, uint32_t media_block_size, rtems_blkdev_bnum media_block_count, bool trace) |
| Allocates and initializes a RAM disk descriptor. | |
| void | ramdisk_free (ramdisk *rd) |
| rtems_status_code | ramdisk_register (uint32_t media_block_size, rtems_blkdev_bnum media_block_count, bool trace, const char *disk) |
| Allocates, initializes and registers a RAM disk. | |
| #define RAMDISK_DRIVER_TABLE_ENTRY |
RAM disk driver table entry.
| ramdisk * ramdisk_allocate | ( | void * | area_begin, |
| uint32_t | media_block_size, | ||
| rtems_blkdev_bnum | media_block_count, | ||
| bool | trace | ||
The block size will be media_block_size. The block count will be media_block_count. The disk storage area begins at area_begin. If area_begin is NULL, the memory will be allocated and zeroed. Sets the trace enable to trace.
NULL if no memory is available.| rtems_status_code ramdisk_register | ( | uint32_t | media_block_size, |
| bool | trace, | ||
| const char * | disk | ||
The block size will be media_block_size. The block count will be media_block_count. The disk storage will be allocated. Sets the trace enable to trace. Registers a device node with disk name path disk. The registered device number will be returned in dev.
| RTEMS_SUCCESSFUL | Successful operation. |
| RTEMS_UNSATISFIED | Something is wrong. |
extern |
The configuration table is provided by the application.
extern |
The configuration table size is provided by the application.
