RTEMS 6.2-rc1
RAM Disk Block Device API. More...
| struct | rtems_ramdisk_config |
| RAM disk configuration table entry. More... | |
| struct | ramdisk |
| RAM disk descriptor. More... | |
Static Configuration | |
| #define | RAMDISK_DRIVER_TABLE_ENTRY |
| #define | RAMDISK_DEVICE_BASE_NAME "/dev/rd" |
| typedef struct rtems_ramdisk_config | rtems_ramdisk_config |
| RAM disk configuration table entry. | |
| rtems_ramdisk_config | rtems_ramdisk_configuration [] |
| External reference to the RAM disk configuration table describing each RAM disk in the system. | |
| size_t | rtems_ramdisk_configuration_size |
| External reference the size of the RAM disk configuration table rtems_ramdisk_configuration. | |
| rtems_device_driver | ramdisk_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| RAM disk driver initialization entry point. | |
Runtime Configuration | |
| typedef struct ramdisk | ramdisk |
| RAM disk descriptor. | |
| int | ramdisk_ioctl (rtems_disk_device *dd, uint32_t req, void *argp) |
| ramdisk * | ramdisk_allocate (void *area_begin, uint32_t media_block_size, rtems_blkdev_bnum media_block_count, bool trace) |
| Allocates and initializes a RAM disk descriptor. | |
| void | ramdisk_free (ramdisk *rd) |
| rtems_status_code | ramdisk_register (uint32_t media_block_size, rtems_blkdev_bnum media_block_count, bool trace, const char *disk) |
| Allocates, initializes and registers a RAM disk. | |
