RTEMS 6.1-rc8
SAI DMA transfer handle, users should not touch the content of the handle. More...
#include <fsl_sai_edma.h>
Data Fields | |
| edma_handle_t * | dmaHandle |
| uint8_t | nbytes |
| uint8_t | bytesPerFrame |
| uint8_t | channelMask |
| uint8_t | channelNums |
| uint8_t | channel |
| uint8_t | count |
| uint32_t | state |
| sai_edma_callback_t | callback |
| void * | userData |
| uint8_t | tcd [(SAI_XFER_QUEUE_SIZE+1U) *sizeof(edma_tcd_t)] |
| sai_transfer_t | saiQueue [SAI_XFER_QUEUE_SIZE] |
| size_t | transferSize [SAI_XFER_QUEUE_SIZE] |
| volatile uint8_t | queueUser |
| volatile uint8_t | queueDriver |
| uint8_t sai_edma_handle::bytesPerFrame |
Bytes in a frame
| sai_edma_callback_t sai_edma_handle::callback |
Callback for users while transfer finish or error occurs
| uint8_t sai_edma_handle::channel |
Which data channel
| uint8_t sai_edma_handle::channelMask |
Enabled channel mask value, reference _sai_channel_mask
| uint8_t sai_edma_handle::channelNums |
total enabled channel nums
| uint8_t sai_edma_handle::count |
The transfer data count in a DMA request
| edma_handle_t* sai_edma_handle::dmaHandle |
DMA handler for SAI send
| uint8_t sai_edma_handle::nbytes |
eDMA minor byte transfer count initially configured.
| volatile uint8_t sai_edma_handle::queueDriver |
Index for driver to get the transfer data and size
| volatile uint8_t sai_edma_handle::queueUser |
Index for user to queue transfer.
| sai_transfer_t sai_edma_handle::saiQueue[SAI_XFER_QUEUE_SIZE] |
Transfer queue storing queued transfer.
| uint32_t sai_edma_handle::state |
Internal state for SAI eDMA transfer
| uint8_t sai_edma_handle::tcd[(SAI_XFER_QUEUE_SIZE+1U) *sizeof(edma_tcd_t)] |
TCD pool for eDMA transfer.
| size_t sai_edma_handle::transferSize[SAI_XFER_QUEUE_SIZE] |
Data bytes need to transfer
| void* sai_edma_handle::userData |
User callback parameter
