RTEMS 6.1-rc8
| struct | _sai_config |
| SAI user configuration structure. More... | |
| struct | _sai_transfer_format |
| sai transfer format More... | |
| struct | _sai_bit_clock |
| sai bit clock configurations More... | |
| struct | _sai_frame_sync |
| sai frame sync configurations More... | |
| struct | _sai_serial_data |
| sai serial data configurations More... | |
| struct | _sai_transceiver |
| sai transceiver configurations More... | |
| struct | _sai_transfer |
| SAI transfer structure. More... | |
| struct | _sai_handle |
| SAI handle structure. More... | |
Driver version | |
| enum | { kStatus_SAI_TxBusy = MAKE_STATUS(kStatusGroup_SAI, 0) , kStatus_SAI_RxBusy = MAKE_STATUS(kStatusGroup_SAI, 1) , kStatus_SAI_TxError = MAKE_STATUS(kStatusGroup_SAI, 2) , kStatus_SAI_RxError = MAKE_STATUS(kStatusGroup_SAI, 3) , kStatus_SAI_QueueFull = MAKE_STATUS(kStatusGroup_SAI, 4) , kStatus_SAI_TxIdle = MAKE_STATUS(kStatusGroup_SAI, 5) , kStatus_SAI_RxIdle = MAKE_STATUS(kStatusGroup_SAI, 6) } |
| _sai_status_t, SAI return status. More... | |
| enum | { kSAI_Channel0Mask = 1 << 0U , kSAI_Channel1Mask = 1 << 1U , kSAI_Channel2Mask = 1 << 2U , kSAI_Channel3Mask = 1 << 3U , kSAI_Channel4Mask = 1 << 4U , kSAI_Channel5Mask = 1 << 5U , kSAI_Channel6Mask = 1 << 6U , kSAI_Channel7Mask = 1 << 7U } |
| _sai_channel_mask,.sai channel mask value, actual channel numbers is depend soc specific More... | |
| enum | _sai_protocol { kSAI_BusLeftJustified = 0x0U , kSAI_BusRightJustified , kSAI_BusI2S , kSAI_BusPCMA , kSAI_BusPCMB } |
| Define the SAI bus type. More... | |
| enum | _sai_master_slave { kSAI_Master = 0x0U , kSAI_Slave = 0x1U , kSAI_Bclk_Master_FrameSync_Slave = 0x2U , kSAI_Bclk_Slave_FrameSync_Master = 0x3U } |
| Master or slave mode. More... | |
| enum | _sai_mono_stereo { kSAI_Stereo = 0x0U , kSAI_MonoRight , kSAI_MonoLeft } |
| Mono or stereo audio format. More... | |
| enum | _sai_data_order { kSAI_DataLSB = 0x0U , kSAI_DataMSB } |
| SAI data order, MSB or LSB. More... | |
| enum | _sai_clock_polarity { kSAI_PolarityActiveHigh = 0x0U , kSAI_PolarityActiveLow = 0x1U , kSAI_SampleOnFallingEdge = 0x0U , kSAI_SampleOnRisingEdge = 0x1U } |
| SAI clock polarity, active high or low. More... | |
| enum | _sai_sync_mode { kSAI_ModeAsync = 0x0U , kSAI_ModeSync } |
| Synchronous or asynchronous mode. More... | |
| enum | _sai_mclk_source { kSAI_MclkSourceSysclk = 0x0U , kSAI_MclkSourceSelect1 , kSAI_MclkSourceSelect2 , kSAI_MclkSourceSelect3 } |
| Mater clock source. More... | |
| enum | _sai_bclk_source { kSAI_BclkSourceBusclk = 0x0U , kSAI_BclkSourceMclkOption1 = 0x1U , kSAI_BclkSourceMclkOption2 = 0x2U , kSAI_BclkSourceMclkOption3 = 0x3U , kSAI_BclkSourceMclkDiv = 0x1U , kSAI_BclkSourceOtherSai0 = 0x2U , kSAI_BclkSourceOtherSai1 = 0x3U } |
| Bit clock source. More... | |
| enum | { kSAI_WordStartInterruptEnable , kSAI_SyncErrorInterruptEnable = I2S_TCSR_SEIE_MASK , kSAI_FIFOWarningInterruptEnable = I2S_TCSR_FWIE_MASK , kSAI_FIFOErrorInterruptEnable = I2S_TCSR_FEIE_MASK } |
| _sai_interrupt_enable_t, The SAI interrupt enable flag More... | |
| enum | { kSAI_FIFOWarningDMAEnable = I2S_TCSR_FWDE_MASK } |
| _sai_dma_enable_t, The DMA request sources More... | |
| enum | { kSAI_WordStartFlag = I2S_TCSR_WSF_MASK , kSAI_SyncErrorFlag = I2S_TCSR_SEF_MASK , kSAI_FIFOErrorFlag = I2S_TCSR_FEF_MASK , kSAI_FIFOWarningFlag = I2S_TCSR_FWF_MASK } |
| _sai_flags, The SAI status flag More... | |
| enum | _sai_reset_type { kSAI_ResetTypeSoftware = I2S_TCSR_SR_MASK , kSAI_ResetTypeFIFO = I2S_TCSR_FR_MASK , kSAI_ResetAll = I2S_TCSR_SR_MASK | I2S_TCSR_FR_MASK } |
| The reset type. More... | |
| enum | _sai_sample_rate { kSAI_SampleRate8KHz = 8000U , kSAI_SampleRate11025Hz = 11025U , kSAI_SampleRate12KHz = 12000U , kSAI_SampleRate16KHz = 16000U , kSAI_SampleRate22050Hz = 22050U , kSAI_SampleRate24KHz = 24000U , kSAI_SampleRate32KHz = 32000U , kSAI_SampleRate44100Hz = 44100U , kSAI_SampleRate48KHz = 48000U , kSAI_SampleRate96KHz = 96000U , kSAI_SampleRate192KHz = 192000U , kSAI_SampleRate384KHz = 384000U } |
| Audio sample rate. More... | |
| enum | _sai_word_width { kSAI_WordWidth8bits = 8U , kSAI_WordWidth16bits = 16U , kSAI_WordWidth24bits = 24U , kSAI_WordWidth32bits = 32U } |
| Audio word width. More... | |
| enum | _sai_transceiver_type { kSAI_Transmitter = 0U , kSAI_Receiver = 1U } |
| sai transceiver type More... | |
| enum | _sai_frame_sync_len { kSAI_FrameSyncLenOneBitClk = 0U , kSAI_FrameSyncLenPerWordWidth = 1U } |
| sai frame sync len More... | |
| typedef enum _sai_protocol | sai_protocol_t |
| Define the SAI bus type. | |
| typedef enum _sai_master_slave | sai_master_slave_t |
| Master or slave mode. | |
| typedef enum _sai_mono_stereo | sai_mono_stereo_t |
| Mono or stereo audio format. | |
| typedef enum _sai_data_order | sai_data_order_t |
| SAI data order, MSB or LSB. | |
| typedef enum _sai_clock_polarity | sai_clock_polarity_t |
| SAI clock polarity, active high or low. | |
| typedef enum _sai_sync_mode | sai_sync_mode_t |
| Synchronous or asynchronous mode. | |
| typedef enum _sai_mclk_source | sai_mclk_source_t |
| Mater clock source. | |
| typedef enum _sai_bclk_source | sai_bclk_source_t |
| Bit clock source. | |
| typedef enum _sai_reset_type | sai_reset_type_t |
| The reset type. | |
| typedef struct _sai_config | sai_config_t |
| SAI user configuration structure. | |
| typedef enum _sai_sample_rate | sai_sample_rate_t |
| Audio sample rate. | |
| typedef enum _sai_word_width | sai_word_width_t |
| Audio word width. | |
| typedef enum _sai_transceiver_type | sai_transceiver_type_t |
| sai transceiver type | |
| typedef enum _sai_frame_sync_len | sai_frame_sync_len_t |
| sai frame sync len | |
| typedef struct _sai_transfer_format | sai_transfer_format_t |
| sai transfer format | |
| typedef struct _sai_bit_clock | sai_bit_clock_t |
| sai bit clock configurations | |
| typedef struct _sai_frame_sync | sai_frame_sync_t |
| sai frame sync configurations | |
| typedef struct _sai_serial_data | sai_serial_data_t |
| sai serial data configurations | |
| typedef struct _sai_transceiver | sai_transceiver_t |
| sai transceiver configurations | |
| typedef struct _sai_transfer | sai_transfer_t |
| SAI transfer structure. | |
| typedef struct _sai_handle | sai_handle_t |
| typedef void(* | sai_transfer_callback_t) (I2S_Type *base, sai_handle_t *handle, status_t status, void *userData) |
| SAI transfer callback prototype. | |
| #define | FSL_SAI_DRIVER_VERSION (MAKE_VERSION(2, 3, 8)) |
| #define | SAI_XFER_QUEUE_SIZE (4U) |
| SAI transfer queue size, user can refine it according to use case. | |
| #define | FSL_SAI_HAS_FIFO_EXTEND_FEATURE 0 |
| sai fifo feature | |
Initialization and deinitialization | |
| void | SAI_TxInit (I2S_Type *base, const sai_config_t *config) |
| Initializes the SAI Tx peripheral. | |
| void | SAI_RxInit (I2S_Type *base, const sai_config_t *config) |
| Initializes the SAI Rx peripheral. | |
| void | SAI_TxGetDefaultConfig (sai_config_t *config) |
| Sets the SAI Tx configuration structure to default values. | |
| void | SAI_RxGetDefaultConfig (sai_config_t *config) |
| Sets the SAI Rx configuration structure to default values. | |
| void | SAI_Init (I2S_Type *base) |
| Initializes the SAI peripheral. | |
| void | SAI_Deinit (I2S_Type *base) |
| De-initializes the SAI peripheral. | |
| void | SAI_TxReset (I2S_Type *base) |
| Resets the SAI Tx. | |
| void | SAI_RxReset (I2S_Type *base) |
| Resets the SAI Rx. | |
| void | SAI_TxEnable (I2S_Type *base, bool enable) |
| Enables/disables the SAI Tx. | |
| void | SAI_RxEnable (I2S_Type *base, bool enable) |
| Enables/disables the SAI Rx. | |
| void | SAI_TxSetBitClockRate (I2S_Type *base, uint32_t sourceClockHz, uint32_t sampleRate, uint32_t bitWidth, uint32_t channelNumbers) |
| Transmitter bit clock rate configurations. | |
| void | SAI_RxSetBitClockRate (I2S_Type *base, uint32_t sourceClockHz, uint32_t sampleRate, uint32_t bitWidth, uint32_t channelNumbers) |
| Receiver bit clock rate configurations. | |
| void | SAI_TxSetBitclockConfig (I2S_Type *base, sai_master_slave_t masterSlave, sai_bit_clock_t *config) |
| Transmitter Bit clock configurations. | |
| void | SAI_RxSetBitclockConfig (I2S_Type *base, sai_master_slave_t masterSlave, sai_bit_clock_t *config) |
| Receiver Bit clock configurations. | |
| void | SAI_TxSetFrameSyncConfig (I2S_Type *base, sai_master_slave_t masterSlave, sai_frame_sync_t *config) |
| SAI transmitter Frame sync configurations. | |
| void | SAI_RxSetFrameSyncConfig (I2S_Type *base, sai_master_slave_t masterSlave, sai_frame_sync_t *config) |
| SAI receiver Frame sync configurations. | |
| void | SAI_TxSetSerialDataConfig (I2S_Type *base, sai_serial_data_t *config) |
| SAI transmitter Serial data configurations. | |
| void | SAI_RxSetSerialDataConfig (I2S_Type *base, sai_serial_data_t *config) |
| SAI receiver Serial data configurations. | |
| void | SAI_TxSetConfig (I2S_Type *base, sai_transceiver_t *config) |
| SAI transmitter configurations. | |
| void | SAI_RxSetConfig (I2S_Type *base, sai_transceiver_t *config) |
| SAI receiver configurations. | |
| void | SAI_GetClassicI2SConfig (sai_transceiver_t *config, sai_word_width_t bitWidth, sai_mono_stereo_t mode, uint32_t saiChannelMask) |
| Get classic I2S mode configurations. | |
| void | SAI_GetLeftJustifiedConfig (sai_transceiver_t *config, sai_word_width_t bitWidth, sai_mono_stereo_t mode, uint32_t saiChannelMask) |
| Get left justified mode configurations. | |
| void | SAI_GetRightJustifiedConfig (sai_transceiver_t *config, sai_word_width_t bitWidth, sai_mono_stereo_t mode, uint32_t saiChannelMask) |
| Get right justified mode configurations. | |
| void | SAI_GetTDMConfig (sai_transceiver_t *config, sai_frame_sync_len_t frameSyncWidth, sai_word_width_t bitWidth, uint32_t dataWordNum, uint32_t saiChannelMask) |
| Get TDM mode configurations. | |
| void | SAI_GetDSPConfig (sai_transceiver_t *config, sai_frame_sync_len_t frameSyncWidth, sai_word_width_t bitWidth, sai_mono_stereo_t mode, uint32_t saiChannelMask) |
| Get DSP mode configurations. | |
Status | |
| void | SAI_TxSoftwareReset (I2S_Type *base, sai_reset_type_t resetType) |
| Do software reset or FIFO reset . | |
| void | SAI_RxSoftwareReset (I2S_Type *base, sai_reset_type_t resetType) |
| void | SAI_TxSetChannelFIFOMask (I2S_Type *base, uint8_t mask) |
| Set the Tx channel FIFO enable mask. | |
| void | SAI_RxSetChannelFIFOMask (I2S_Type *base, uint8_t mask) |
| Set the Rx channel FIFO enable mask. | |
| void | SAI_TxSetDataOrder (I2S_Type *base, sai_data_order_t order) |
| Set the Tx data order. | |
| void | SAI_RxSetDataOrder (I2S_Type *base, sai_data_order_t order) |
| Set the Rx data order. | |
| void | SAI_TxSetBitClockPolarity (I2S_Type *base, sai_clock_polarity_t polarity) |
| void | SAI_RxSetBitClockPolarity (I2S_Type *base, sai_clock_polarity_t polarity) |
| void | SAI_TxSetFrameSyncPolarity (I2S_Type *base, sai_clock_polarity_t polarity) |
| void | SAI_RxSetFrameSyncPolarity (I2S_Type *base, sai_clock_polarity_t polarity) |
Bus Operations | |
| void | SAI_TxSetFormat (I2S_Type *base, sai_transfer_format_t *format, uint32_t mclkSourceClockHz, uint32_t bclkSourceClockHz) |
| Configures the SAI Tx audio format. | |
| void | SAI_RxSetFormat (I2S_Type *base, sai_transfer_format_t *format, uint32_t mclkSourceClockHz, uint32_t bclkSourceClockHz) |
| Configures the SAI Rx audio format. | |
| void | SAI_WriteBlocking (I2S_Type *base, uint32_t channel, uint32_t bitWidth, uint8_t *buffer, uint32_t size) |
| Sends data using a blocking method. | |
| void | SAI_WriteMultiChannelBlocking (I2S_Type *base, uint32_t channel, uint32_t channelMask, uint32_t bitWidth, uint8_t *buffer, uint32_t size) |
| Sends data to multi channel using a blocking method. | |
| void | SAI_ReadBlocking (I2S_Type *base, uint32_t channel, uint32_t bitWidth, uint8_t *buffer, uint32_t size) |
| Receives data using a blocking method. | |
| void | SAI_ReadMultiChannelBlocking (I2S_Type *base, uint32_t channel, uint32_t channelMask, uint32_t bitWidth, uint8_t *buffer, uint32_t size) |
| Receives multi channel data using a blocking method. | |
Transactional | |
| void | SAI_TransferTxCreateHandle (I2S_Type *base, sai_handle_t *handle, sai_transfer_callback_t callback, void *userData) |
| Initializes the SAI Tx handle. | |
| void | SAI_TransferRxCreateHandle (I2S_Type *base, sai_handle_t *handle, sai_transfer_callback_t callback, void *userData) |
| Initializes the SAI Rx handle. | |
| void | SAI_TransferTxSetConfig (I2S_Type *base, sai_handle_t *handle, sai_transceiver_t *config) |
| SAI transmitter transfer configurations. | |
| void | SAI_TransferRxSetConfig (I2S_Type *base, sai_handle_t *handle, sai_transceiver_t *config) |
| SAI receiver transfer configurations. | |
| status_t | SAI_TransferTxSetFormat (I2S_Type *base, sai_handle_t *handle, sai_transfer_format_t *format, uint32_t mclkSourceClockHz, uint32_t bclkSourceClockHz) |
| status_t | SAI_TransferRxSetFormat (I2S_Type *base, sai_handle_t *handle, sai_transfer_format_t *format, uint32_t mclkSourceClockHz, uint32_t bclkSourceClockHz) |
| status_t | SAI_TransferSendNonBlocking (I2S_Type *base, sai_handle_t *handle, sai_transfer_t *xfer) |
| Performs an interrupt non-blocking send transfer on SAI. | |
| status_t | SAI_TransferReceiveNonBlocking (I2S_Type *base, sai_handle_t *handle, sai_transfer_t *xfer) |
| Performs an interrupt non-blocking receive transfer on SAI. | |
| status_t | SAI_TransferGetSendCount (I2S_Type *base, sai_handle_t *handle, size_t *count) |
| Gets a set byte count. | |
| status_t | SAI_TransferGetReceiveCount (I2S_Type *base, sai_handle_t *handle, size_t *count) |
| Gets a received byte count. | |
| void | SAI_TransferAbortSend (I2S_Type *base, sai_handle_t *handle) |
| Aborts the current send. | |
| void | SAI_TransferAbortReceive (I2S_Type *base, sai_handle_t *handle) |
| Aborts the current IRQ receive. | |
| void | SAI_TransferTerminateSend (I2S_Type *base, sai_handle_t *handle) |
| Terminate all SAI send. | |
| void | SAI_TransferTerminateReceive (I2S_Type *base, sai_handle_t *handle) |
| Terminate all SAI receive. | |
| void | SAI_TransferTxHandleIRQ (I2S_Type *base, sai_handle_t *handle) |
| Tx interrupt handler. | |
| void | SAI_TransferRxHandleIRQ (I2S_Type *base, sai_handle_t *handle) |
| #define FSL_SAI_DRIVER_VERSION (MAKE_VERSION(2, 3, 8)) |
Version 2.3.8
| anonymous enum |
| anonymous enum |
| anonymous enum |
| anonymous enum |
| anonymous enum |
Bit clock source.
Audio sample rate.
| void SAI_Deinit | ( | I2S_Type * | base | ) |
This API gates the SAI clock. The SAI module can't operate unless SAI_TxInit or SAI_RxInit is called to enable the clock.
| base | SAI base pointer. |
brief De-initializes the SAI peripheral.
param base SAI base pointer
| void SAI_GetClassicI2SConfig | ( | sai_transceiver_t * | config, |
| sai_word_width_t | bitWidth, | ||
| sai_mono_stereo_t | mode, | ||
| uint32_t | saiChannelMask | ||
| config | transceiver configurations. |
| bitWidth | audio data bitWidth. |
| mode | audio data channel. |
| saiChannelMask | mask value of the channel to be enable. |
brief Get classic I2S mode configurations.
param config transceiver configurations. param bitWidth audio data bitWidth. param mode audio data channel. param saiChannelMask channel mask value to enable.
| void SAI_GetDSPConfig | ( | sai_transceiver_t * | config, |
| sai_frame_sync_len_t | frameSyncWidth, | ||
DSP/PCM MODE B configuration flow for TX. RX is similiar but uses SAI_RxSetConfig instead of SAI_TxSetConfig:
| frameSyncWidth | length of frame sync. |
| saiChannelMask | mask value of the channel to enable. |
brief Get DSP mode configurations.
note DSP mode is also called PCM mode which support MODE A and MODE B, DSP/PCM MODE A configuration flow. RX is similiar but uses SAI_RxSetConfig instead of SAI_TxSetConfig: code SAI_GetDSPConfig(config, kSAI_FrameSyncLenOneBitClk, bitWidth, kSAI_Stereo, channelMask) config->frameSync.frameSyncEarly = true; SAI_TxSetConfig(base, config) endcode
DSP/PCM MODE B configuration flow for TX. RX is similiar but uses SAI_RxSetConfig instead of SAI_TxSetConfig: code SAI_GetDSPConfig(config, kSAI_FrameSyncLenOneBitClk, bitWidth, kSAI_Stereo, channelMask) SAI_TxSetConfig(base, config) endcode
param config transceiver configurations. param frameSyncWidth length of frame sync. param bitWidth audio data bitWidth. param mode audio data channel. param saiChannelMask mask value of the channel to enable.
| void SAI_GetLeftJustifiedConfig | ( | sai_transceiver_t * | config, |
brief Get left justified mode configurations.
| void SAI_GetRightJustifiedConfig | ( | sai_transceiver_t * | config, |
brief Get right justified mode configurations.
| void SAI_GetTDMConfig | ( | sai_transceiver_t * | config, |
| uint32_t | dataWordNum, | ||
| bitWidth | audio data word width. |
| dataWordNum | word number in one frame. |
brief Get TDM mode configurations.
| void SAI_Init | ( | I2S_Type * | base | ) |
This API gates the SAI clock. The SAI module can't operate unless SAI_Init is called to enable the clock.
brief Initializes the SAI peripheral.
| void SAI_ReadBlocking | ( | I2S_Type * | base, |
| uint32_t | channel, | ||
| uint32_t | bitWidth, | ||
| uint8_t * | buffer, | ||
| uint32_t | size | ||
| channel | Data channel used. |
| bitWidth | How many bits in an audio word; usually 8/16/24/32 bits. |
| buffer | Pointer to the data to be read. |
| size | Bytes to be read. |
brief Receives data using a blocking method.
note This function blocks by polling until data is ready to be sent.
param base SAI base pointer. param channel Data channel used. param bitWidth How many bits in an audio word; usually 8/16/24/32 bits. param buffer Pointer to the data to be read. param size Bytes to be read.
| void SAI_ReadMultiChannelBlocking | ( | I2S_Type * | base, |
| uint32_t | channelMask, | ||
| channelMask | channel mask. |
brief Receives multi channel data using a blocking method.
param base SAI base pointer. param channel Data channel used. param channelMask channel mask. param bitWidth How many bits in an audio word; usually 8/16/24/32 bits. param buffer Pointer to the data to be read. param size Bytes to be read.
| void SAI_RxEnable | ( | I2S_Type * | base, |
| bool | enable | ||
| enable | True means enable SAI Rx, false means disable. |
brief Enables/disables the SAI Rx.
param base SAI base pointer param enable True means enable SAI Rx, false means disable.
| void SAI_RxGetDefaultConfig | ( | sai_config_t * | config | ) |
This API initializes the configuration structure for use in SAI_RxConfig(). The initialized structure can remain unchanged in SAI_RxConfig() or it can be modified before calling SAI_RxConfig(). This is an example.
| config | pointer to master configuration structure |
brief Sets the SAI Rx configuration structure to default values.
deprecated Do not use this function. It has been superceded by SAI_GetClassicI2SConfig,SAI_GetLeftJustifiedConfig,SAI_GetRightJustifiedConfig,SAI_GetDSPConfig,SAI_GetTDMConfig
This API initializes the configuration structure for use in SAI_RxConfig(). The initialized structure can remain unchanged in SAI_RxConfig() or it can be modified before calling SAI_RxConfig(). This is an example. code sai_config_t config; SAI_RxGetDefaultConfig(&config); endcode
param config pointer to master configuration structure
| void SAI_RxInit | ( | I2S_Type * | base, |
| const sai_config_t * | config | ||
Ungates the SAI clock, resets the module, and configures the SAI Rx with a configuration structure. The configuration structure can be custom filled or set with default values by SAI_RxGetDefaultConfig().
| base | SAI base pointer |
| config | SAI configuration structure. |
brief Initializes the SAI Rx peripheral.
deprecated Do not use this function. It has been superceded by SAI_Init
note This API should be called at the beginning of the application to use the SAI driver. Otherwise, accessing the SAI module can cause a hard fault because the clock is not enabled.
param base SAI base pointer param config SAI configuration structure.
| void SAI_RxReset | ( | I2S_Type * | base | ) |
Resets the SAI Rx.
This function enables the software reset and FIFO reset of SAI Rx. After reset, clear the reset bit.
brief Resets the SAI Rx.
| void SAI_RxSetBitclockConfig | ( | I2S_Type * | base, |
| sai_master_slave_t | masterSlave, | ||
| sai_bit_clock_t * | config | ||
| masterSlave | master or slave. |
| config | bit clock other configurations, can be NULL in slave mode. |
brief Receiver Bit clock configurations.
param base SAI base pointer. param masterSlave master or slave. param config bit clock other configurations, can be NULL in slave mode.
| void SAI_RxSetBitClockPolarity | ( | I2S_Type * | base, |
| sai_clock_polarity_t | polarity | ||
| polarity |
brief Set the Rx data order.
param base SAI base pointer param order Data order MSB or LSB
| void SAI_RxSetBitClockRate | ( | I2S_Type * | base, |
| uint32_t | sourceClockHz, | ||
| uint32_t | sampleRate, | ||
| uint32_t | channelNumbers | ||
| sourceClockHz | Bit clock source frequency. |
| sampleRate | Audio data sample rate. |
| bitWidth | Audio data bitWidth. |
| channelNumbers | Audio channel numbers. |
brief Receiver bit clock rate configurations.
param base SAI base pointer. param sourceClockHz, bit clock source frequency. param sampleRate audio data sample rate. param bitWidth, audio data bitWidth. param channelNumbers, audio channel numbers.
| void SAI_RxSetChannelFIFOMask | ( | I2S_Type * | base, |
| uint8_t | mask | ||
| mask | Channel enable mask, 0 means all channel FIFO disabled, 1 means channel 0 enabled, 3 means both channel 0 and channel 1 enabled. |
brief Set the Rx channel FIFO enable mask.
param base SAI base pointer param mask Channel enable mask, 0 means all channel FIFO disabled, 1 means channel 0 enabled, 3 means both channel 0 and channel 1 enabled.
| void SAI_RxSetConfig | ( | I2S_Type * | base, |
| sai_transceiver_t * | config | ||
| config | receiver configurations. |
brief SAI receiver configurations.
param base SAI base pointer. param config transmitter configurations.
| void SAI_RxSetDataOrder | ( | I2S_Type * | base, |
| sai_data_order_t | order | ||
| order | Data order MSB or LSB |
| void SAI_RxSetFormat | ( | I2S_Type * | base, |
| sai_transfer_format_t * | format, | ||
| uint32_t | mclkSourceClockHz, | ||
| uint32_t | bclkSourceClockHz | ||
The audio format can be changed at run-time. This function configures the sample rate and audio data format to be transferred.
| format | Pointer to the SAI audio data format structure. |
| mclkSourceClockHz | SAI master clock source frequency in Hz. |
| bclkSourceClockHz | SAI bit clock source frequency in Hz. If the bit clock source is a master clock, this value should equal the masterClockHz. |
brief Configures the SAI Rx audio format.
deprecated Do not use this function. It has been superceded by SAI_RxSetConfig
param base SAI base pointer. param format Pointer to the SAI audio data format structure. param mclkSourceClockHz SAI master clock source frequency in Hz. param bclkSourceClockHz SAI bit clock source frequency in Hz. If the bit clock source is a master clock, this value should equal the masterClockHz.
| void SAI_RxSetFrameSyncConfig | ( | I2S_Type * | base, |
| sai_frame_sync_t * | config | ||
| config | frame sync configurations, can be NULL in slave mode. |
brief SAI receiver Frame sync configurations.
param base SAI base pointer. param masterSlave master or slave. param config frame sync configurations, can be NULL in slave mode.
| void SAI_RxSetFrameSyncPolarity | ( | I2S_Type * | base, |
| polarity |
| void SAI_RxSetSerialDataConfig | ( | I2S_Type * | base, |
| sai_serial_data_t * | config | ||
| config | serial data configurations. |
| void SAI_RxSoftwareReset | ( | I2S_Type * | base, |
| sai_reset_type_t | resetType | ||
FIFO reset means clear all the data in the FIFO, and make the FIFO pointer both to 0. Software reset means clear the Rx internal logic, including the bit clock, frame count etc. But software reset will not clear any configuration registers like RCR1~RCR5. This function will also clear all the error flags such as FIFO error, sync error etc.
| resetType | Reset type, FIFO reset or software reset |
brief Do software reset or FIFO reset .
param base SAI base pointer param resetType Reset type, FIFO reset or software reset
| void SAI_TransferAbortReceive | ( | I2S_Type * | base, |
| sai_handle_t * | handle | ||
| handle | Pointer to the sai_handle_t structure which stores the transfer state. |
brief Aborts the current IRQ receive.
note This API can be called when an interrupt non-blocking transfer initiates to abort the transfer early.
param base SAI base pointer param handle Pointer to the sai_handle_t structure which stores the transfer state.
| void SAI_TransferAbortSend | ( | I2S_Type * | base, |
brief Aborts the current send.
note This API can be called any time when an interrupt non-blocking transfer initiates to abort the transfer early.
param base SAI base pointer. param handle Pointer to the sai_handle_t structure which stores the transfer state.
| status_t SAI_TransferGetReceiveCount | ( | I2S_Type * | base, |
| sai_handle_t * | handle, | ||
| size_t * | count | ||
| count | Bytes count received. |
| kStatus_Success | Succeed get the transfer count. |
| kStatus_NoTransferInProgress | There is not a non-blocking transaction currently in progress. |
brief Gets a received byte count.
param base SAI base pointer. param handle Pointer to the sai_handle_t structure which stores the transfer state. param count Bytes count received. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress.
| status_t SAI_TransferGetSendCount | ( | I2S_Type * | base, |
| count | Bytes count sent. |
brief Gets a set byte count.
param base SAI base pointer. param handle Pointer to the sai_handle_t structure which stores the transfer state. param count Bytes count sent. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress.
| status_t SAI_TransferReceiveNonBlocking | ( | I2S_Type * | base, |
| sai_transfer_t * | xfer | ||
| xfer | Pointer to the sai_transfer_t structure. |
| kStatus_Success | Successfully started the data receive. |
| kStatus_SAI_RxBusy | Previous receive still not finished. |
| kStatus_InvalidArgument | The input parameter is invalid. |
brief Performs an interrupt non-blocking receive transfer on SAI.
note This API returns immediately after the transfer initiates. Call the SAI_RxGetTransferStatusIRQ to poll the transfer status and check whether the transfer is finished. If the return status is not kStatus_SAI_Busy, the transfer is finished.
param base SAI base pointer param handle Pointer to the sai_handle_t structure which stores the transfer state. param xfer Pointer to the sai_transfer_t structure. retval kStatus_Success Successfully started the data receive. retval kStatus_SAI_RxBusy Previous receive still not finished. retval kStatus_InvalidArgument The input parameter is invalid.
| void SAI_TransferRxCreateHandle | ( | I2S_Type * | base, |
| sai_transfer_callback_t | callback, | ||
| void * | userData | ||
This function initializes the Rx handle for the SAI Rx transactional APIs. Call this function once to get the handle initialized.
| handle | SAI handle pointer. |
| callback | Pointer to the user callback function. |
| userData | User parameter passed to the callback function. |
brief Initializes the SAI Rx handle.
param base SAI base pointer. param handle SAI handle pointer. param callback Pointer to the user callback function. param userData User parameter passed to the callback function.
| void SAI_TransferRxHandleIRQ | ( | I2S_Type * | base, |
| handle | Pointer to the sai_handle_t structure. |
brief Tx interrupt handler.
param base SAI base pointer. param handle Pointer to the sai_handle_t structure.
| void SAI_TransferRxSetConfig | ( | I2S_Type * | base, |
This function initializes the Rx, include bit clock, frame sync, master clock, serial data and fifo configurations.
brief SAI receiver transfer configurations.
This function initializes the TX, include bit clock, frame sync, master clock, serial data and fifo configurations.
param base SAI base pointer. param handle SAI handle pointer. param config tranmitter configurations.
| status_t SAI_TransferRxSetFormat | ( | I2S_Type * | base, |
| bclkSourceClockHz | SAI bit clock source frequency in Hz. If a bit clock source is a master clock, this value should equal the masterClockHz in format. |
deprecated Do not use this function. It has been superceded by SAI_TransferRxSetConfig
param base SAI base pointer. param handle SAI handle pointer. param format Pointer to the SAI audio data format structure. param mclkSourceClockHz SAI master clock source frequency in Hz. param bclkSourceClockHz SAI bit clock source frequency in Hz. If a bit clock source is a master clock, this value should equal the masterClockHz in format. return Status of this function. Return value is one of status_t.
| status_t SAI_TransferSendNonBlocking | ( | I2S_Type * | base, |
| kStatus_SAI_TxBusy | Previous receive still not finished. |
brief Performs an interrupt non-blocking send transfer on SAI.
note This API returns immediately after the transfer initiates. Call the SAI_TxGetTransferStatusIRQ to poll the transfer status and check whether the transfer is finished. If the return status is not kStatus_SAI_Busy, the transfer is finished.
param base SAI base pointer. param handle Pointer to the sai_handle_t structure which stores the transfer state. param xfer Pointer to the sai_transfer_t structure. retval kStatus_Success Successfully started the data receive. retval kStatus_SAI_TxBusy Previous receive still not finished. retval kStatus_InvalidArgument The input parameter is invalid.
| void SAI_TransferTerminateReceive | ( | I2S_Type * | base, |
This function will clear all transfer slots buffered in the sai queue. If users only want to abort the current transfer slot, please call SAI_TransferAbortReceive.
| handle | SAI eDMA handle pointer. |
brief Terminate all SAI receive.
param base SAI base pointer. param handle SAI eDMA handle pointer.
| void SAI_TransferTerminateSend | ( | I2S_Type * | base, |
This function will clear all transfer slots buffered in the sai queue. If users only want to abort the current transfer slot, please call SAI_TransferAbortSend.
brief Terminate all SAI send.
| void SAI_TransferTxCreateHandle | ( | I2S_Type * | base, |
This function initializes the Tx handle for the SAI Tx transactional APIs. Call this function once to get the handle initialized.
| userData | User parameter passed to the callback function |
brief Initializes the SAI Tx handle.
param base SAI base pointer param handle SAI handle pointer. param callback Pointer to the user callback function. param userData User parameter passed to the callback function
| void SAI_TransferTxHandleIRQ | ( | I2S_Type * | base, |
| void SAI_TransferTxSetConfig | ( | I2S_Type * | base, |
This function initializes the Tx, include bit clock, frame sync, master clock, serial data and fifo configurations.
| config | tranmitter configurations. |
brief SAI transmitter transfer configurations.
| status_t SAI_TransferTxSetFormat | ( | I2S_Type * | base, |
brief Configures the SAI Tx audio format.
deprecated Do not use this function. It has been superceded by SAI_TransferTxSetConfig
param base SAI base pointer. param handle SAI handle pointer. param format Pointer to the SAI audio data format structure. param mclkSourceClockHz SAI master clock source frequency in Hz. param bclkSourceClockHz SAI bit clock source frequency in Hz. If a bit clock source is a master clock, this value should equal the masterClockHz in format. return Status of this function. Return value is the status_t.
| void SAI_TxEnable | ( | I2S_Type * | base, |
| bool | enable | ||
| enable | True means enable SAI Tx, false means disable. |
brief Enables/disables the SAI Tx.
param base SAI base pointer param enable True means enable SAI Tx, false means disable.
| void SAI_TxGetDefaultConfig | ( | sai_config_t * | config | ) |
This API initializes the configuration structure for use in SAI_TxConfig(). The initialized structure can remain unchanged in SAI_TxConfig(), or it can be modified before calling SAI_TxConfig(). This is an example.
brief Sets the SAI Tx configuration structure to default values.
deprecated Do not use this function. It has been superceded by SAI_GetClassicI2SConfig, SAI_GetLeftJustifiedConfig,SAI_GetRightJustifiedConfig, SAI_GetDSPConfig,SAI_GetTDMConfig
This API initializes the configuration structure for use in SAI_TxConfig(). The initialized structure can remain unchanged in SAI_TxConfig(), or it can be modified before calling SAI_TxConfig(). This is an example. code sai_config_t config; SAI_TxGetDefaultConfig(&config); endcode
| void SAI_TxInit | ( | I2S_Type * | base, |
Ungates the SAI clock, resets the module, and configures SAI Tx with a configuration structure. The configuration structure can be custom filled or set with default values by SAI_TxGetDefaultConfig().
brief Initializes the SAI Tx peripheral.
note This API should be called at the beginning of the application to use the SAI driver. Otherwise, accessing the SAIM module can cause a hard fault because the clock is not enabled.
| void SAI_TxReset | ( | I2S_Type * | base | ) |
Resets the SAI Tx.
This function enables the software reset and FIFO reset of SAI Tx. After reset, clear the reset bit.
brief Resets the SAI Tx.
| void SAI_TxSetBitclockConfig | ( | I2S_Type * | base, |
brief Transmitter Bit clock configurations.
| void SAI_TxSetBitClockPolarity | ( | I2S_Type * | base, |
| polarity |
brief Set the Tx data order.
| void SAI_TxSetBitClockRate | ( | I2S_Type * | base, |
brief Transmitter bit clock rate configurations.
| void SAI_TxSetChannelFIFOMask | ( | I2S_Type * | base, |
| uint8_t | mask | ||
brief Set the Tx channel FIFO enable mask.
| void SAI_TxSetConfig | ( | I2S_Type * | base, |
| config | transmitter configurations. |
brief SAI transmitter configurations.
| void SAI_TxSetDataOrder | ( | I2S_Type * | base, |
| void SAI_TxSetFormat | ( | I2S_Type * | base, |
deprecated Do not use this function. It has been superceded by SAI_TxSetConfig
| void SAI_TxSetFrameSyncConfig | ( | I2S_Type * | base, |
brief SAI transmitter Frame sync configurations.
| void SAI_TxSetFrameSyncPolarity | ( | I2S_Type * | base, |
| polarity |
| void SAI_TxSetSerialDataConfig | ( | I2S_Type * | base, |
brief SAI transmitter Serial data configurations.
param base SAI base pointer. param config serial data configurations.
| void SAI_TxSoftwareReset | ( | I2S_Type * | base, |
FIFO reset means clear all the data in the FIFO, and make the FIFO pointer both to 0. Software reset means clear the Tx internal logic, including the bit clock, frame count etc. But software reset will not clear any configuration registers like TCR1~TCR5. This function will also clear all the error flags such as FIFO error, sync error etc.
| tresetType | Reset type, FIFO reset or software reset |
| void SAI_WriteBlocking | ( | I2S_Type * | base, |
| buffer | Pointer to the data to be written. |
| size | Bytes to be written. |
brief Sends data using a blocking method.
param base SAI base pointer. param channel Data channel used. param bitWidth How many bits in an audio word; usually 8/16/24/32 bits. param buffer Pointer to the data to be written. param size Bytes to be written.
| void SAI_WriteMultiChannelBlocking | ( | I2S_Type * | base, |
brief Sends data to multi channel using a blocking method.
param base SAI base pointer. param channel Data channel used. param channelMask channel mask. param bitWidth How many bits in an audio word; usually 8/16/24/32 bits. param buffer Pointer to the data to be written. param size Bytes to be written.
