RTEMS 6.1-rc8
XECC user configuration. More...
#include <fsl_xecc.h>
Data Fields | |
| bool | enableXECC |
| bool | enableWriteECC |
| bool | enableReadECC |
| bool | enableSwap |
| uint32_t | Region0BaseAddress |
| uint32_t | Region0EndAddress |
| uint32_t | Region1BaseAddress |
| uint32_t | Region1EndAddress |
| uint32_t | Region2BaseAddress |
| uint32_t | Region2EndAddress |
| uint32_t | Region3BaseAddress |
| uint32_t | Region3EndAddress |
| bool _xecc_config::enableReadECC |
Enable read ECC function.
| bool _xecc_config::enableSwap |
Enable swap function. The minimum ECC region range is 4k, so the lower 12 bits of this register must be 0.
| bool _xecc_config::enableWriteECC |
Enable write ECC function.
| bool _xecc_config::enableXECC |
Enable the XECC function.
| uint32_t _xecc_config::Region0BaseAddress |
ECC region 0 base address.
| uint32_t _xecc_config::Region0EndAddress |
ECC region 0 end address.
| uint32_t _xecc_config::Region1BaseAddress |
ECC region 1 base address.
| uint32_t _xecc_config::Region1EndAddress |
ECC region 1 end address.
| uint32_t _xecc_config::Region2BaseAddress |
ECC region 2 base address.
| uint32_t _xecc_config::Region2EndAddress |
ECC region 2 end address.
| uint32_t _xecc_config::Region3BaseAddress |
ECC region 3 base address.
| uint32_t _xecc_config::Region3EndAddress |
ECC region 3 end address.
