RTEMS 6.1-rc8
| struct | _xecc_config |
| XECC user configuration. More... | |
| struct | _xecc_single_error_info |
| XECC single error information, including single error address, ECC code, error data, error bit position and error bit field. More... | |
| struct | _xecc_multi_error_info |
| XECC multiple error information, including multiple error address, ECC code, error data and error bit field. More... | |
Driver version | |
| enum | { kXECC_SingleErrorInterruptEnable = XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN_MASK , kXECC_MultiErrorInterruptEnable = XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN_MASK , kXECC_AllInterruptsEnable } |
| XECC interrupt configuration structure, , xecc_interrupt_enable_t. More... | |
| enum | { kXECC_SingleErrorInterruptStatusEnable , kXECC_MultiErrorInterruptStatusEnable , kXECC_AllInterruptsStatusEnable } |
| XECC interrupt status configuration structure, xecc_interrupt_status_enable_t. More... | |
| enum | { kXECC_SingleErrorInterruptFlag , kXECC_MultiErrorInterruptFlag , kXECC_AllInterruptsFlag } |
| XECC status flags, xecc_interrupt_status_t. More... | |
| typedef struct _xecc_config | xecc_config_t |
| XECC user configuration. | |
| typedef struct _xecc_single_error_info | xecc_single_error_info_t |
| XECC single error information, including single error address, ECC code, error data, error bit position and error bit field. | |
| typedef struct _xecc_multi_error_info | xecc_multi_error_info_t |
| XECC multiple error information, including multiple error address, ECC code, error data and error bit field. | |
| #define | FSL_XECC_DRIVER_VERSION (MAKE_VERSION(2U, 0U, 0U)) |
| Driver version 2.0.0. | |
Initialization and deinitialization | |
| void | XECC_Init (XECC_Type *base, const xecc_config_t *config) |
| XECC module initialization function. | |
| void | XECC_Deinit (XECC_Type *base) |
| Deinitializes the XECC. | |
| void | XECC_GetDefaultConfig (xecc_config_t *config) |
| Sets the XECC configuration structure to default values. | |
functional | |
| status_t | XECC_ErrorInjection (XECC_Type *base, uint32_t errordata, uint8_t erroreccdata) |
| XECC module error injection. | |
| void | XECC_GetSingleErrorInfo (XECC_Type *base, xecc_single_error_info_t *info) |
| XECC module get single error information. | |
| void | XECC_GetMultiErrorInfo (XECC_Type *base, xecc_multi_error_info_t *info) |
| XECC module get multiple error information. | |
| anonymous enum |
This structure contains the settings for all of the XECC interrupt configurations.
| Enumerator | |
| kXECC_SingleErrorInterruptEnable | Single bit error interrupt enable |
| kXECC_MultiErrorInterruptEnable | Multiple bit error interrupt enable |
| kXECC_AllInterruptsEnable | all interrupts enable |
| anonymous enum |
This structure contains the settings for all of the XECC interrupt status configurations.
| anonymous enum |
This provides constants for the XECC status flags for use in the XECC functions.
| void XECC_Deinit | ( | XECC_Type * | base | ) |
| base | XECC base address. |
brief Deinitializes the XECC.
| errordata | error data. |
| erroreccdata | ecc code. |
| kStatus_Success. |
| void XECC_GetDefaultConfig | ( | xecc_config_t * | config | ) |
| config | pointer to the XECC configuration structure. |
| void XECC_GetMultiErrorInfo | ( | XECC_Type * | base, |
| xecc_multi_error_info_t * | info | ||
| info | multiple error information. |
| void XECC_GetSingleErrorInfo | ( | XECC_Type * | base, |
| xecc_single_error_info_t * | info | ||
| info | single error information. |
| void XECC_Init | ( | XECC_Type * | base, |
| const xecc_config_t * | config | ||
brief XECC module initialization function.
param base XECC base address.
