RTEMS 6.1-rc8
sai transceiver configurations More...
#include <fsl_sai.h>
Data Fields | |
| sai_serial_data_t | serialData |
| sai_frame_sync_t | frameSync |
| sai_bit_clock_t | bitClock |
| sai_master_slave_t | masterSlave |
| sai_sync_mode_t | syncMode |
| uint8_t | startChannel |
| uint8_t | channelMask |
| uint8_t | endChannel |
| uint8_t | channelNums |
| sai_bit_clock_t _sai_transceiver::bitClock |
bit clock configurations
| uint8_t _sai_transceiver::channelMask |
enabled channel mask value, reference _sai_channel_mask
| uint8_t _sai_transceiver::channelNums |
Total enabled channel numbers
| uint8_t _sai_transceiver::endChannel |
end channel number
| sai_frame_sync_t _sai_transceiver::frameSync |
ws configurations
| sai_master_slave_t _sai_transceiver::masterSlave |
transceiver is master or slave
| sai_serial_data_t _sai_transceiver::serialData |
serial data configurations
| uint8_t _sai_transceiver::startChannel |
Transfer start channel
| sai_sync_mode_t _sai_transceiver::syncMode |
transceiver sync mode
