RTEMS 6.1-rc8
Partition_Control Struct Reference
The Partition Control Block (PTCB) represents a partition. More...
#include <partdata.h>
Objects_Control Object
 This member turns the PTCB into an object.
const void * base_address
 This member contains the base address of the buffer area.
const void * limit_address
 This member contains the limit address of the buffer area.
size_t buffer_size
 This member contains the size of each buffer in bytes.
rtems_attribute attribute_set
 This member contains the attribute set provided at creation time.
uintptr_t number_of_used_blocks
 This member contains the count of allocated buffers.
Chain_Control Memory
 This chain is used to manage unallocated buffers.
Field Documentation
◆ base_address
const void* Partition_Control::base_address
The base address is the address of the first byte contained in the buffer area.
◆ limit_address
const void* Partition_Control::limit_address
The limit address is the address of the last byte contained in the buffer area.
