RTEMS 6.1-rc8
Barrier_Control Struct Reference
#include <barrierdata.h>
Objects_Control Object
CORE_barrier_Control Barrier
rtems_attribute attribute_set
This type defines the control block used to manage each barrier.
Field Documentation
◆ attribute_set
rtems_attribute Barrier_Control::attribute_set
This is used to specify the attributes of a barrier.
◆ Barrier
CORE_barrier_Control Barrier_Control::Barrier
This is used to implement the barrier.
◆ Object
Objects_Control Barrier_Control::Object
This is used to manage a barrier as an object.
