RTEMS 6.1-rc8
This source file contains the implementation of _Scheduler_EDF_SMP_Add_processor(), _Scheduler_EDF_SMP_Ask_for_help(), _Scheduler_EDF_SMP_Block(), _Scheduler_EDF_SMP_Initialize(), _Scheduler_EDF_SMP_Node_initialize(), _Scheduler_EDF_SMP_Pin(), _Scheduler_EDF_SMP_Reconsider_help_request(), _Scheduler_EDF_SMP_Remove_processor(), _Scheduler_EDF_SMP_Set_affinity(), _Scheduler_EDF_SMP_Start_idle(), _Scheduler_EDF_SMP_Unblock(), _Scheduler_EDF_SMP_Unpin(), _Scheduler_EDF_SMP_Update_priority(), _Scheduler_EDF_SMP_Withdraw_node(), _Scheduler_EDF_SMP_Make_sticky(), _Scheduler_EDF_SMP_Clean_sticky(), and _Scheduler_EDF_SMP_Yield(). More...
| void | _Scheduler_EDF_SMP_Initialize (const Scheduler_Control *scheduler) |
| Initializes the context of the scheduler control. | |
| void | _Scheduler_EDF_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
| Initializes the node with the given priority. | |
| void | _Scheduler_EDF_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Blocks the thread. | |
| void | _Scheduler_EDF_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Unblocks the thread. | |
| void | _Scheduler_EDF_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Updates the priority of the node. | |
| bool | _Scheduler_EDF_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Asks for help operation. | |
| void | _Scheduler_EDF_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Reconsiders help operation. | |
| void | _Scheduler_EDF_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state) |
| Withdraws node operation. | |
| void | _Scheduler_EDF_SMP_Make_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Makes the node sticky. | |
| void | _Scheduler_EDF_SMP_Clean_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Cleans the sticky property from the node. | |
| void | _Scheduler_EDF_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle) |
| Adds processor. | |
| Thread_Control * | _Scheduler_EDF_SMP_Remove_processor (const Scheduler_Control *scheduler, Per_CPU_Control *cpu) |
| Removes an idle thread from the given cpu. | |
| void | _Scheduler_EDF_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Performs the yield of a thread. | |
| void | _Scheduler_EDF_SMP_Start_idle (const Scheduler_Control *scheduler, Thread_Control *idle, Per_CPU_Control *cpu) |
| Starts an idle thread. | |
| void | _Scheduler_EDF_SMP_Pin (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node_base, struct Per_CPU_Control *cpu) |
| Pin thread operation. | |
| void | _Scheduler_EDF_SMP_Unpin (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node_base, struct Per_CPU_Control *cpu) |
| Unpin thread operation. | |
| Status_Control | _Scheduler_EDF_SMP_Set_affinity (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node_base, const Processor_mask *affinity) |
| Checks if the processor set of the scheduler is the subset of the affinity set. | |
