RTEMS 6.1-rc8
RTEMS File Systems Shell Commands Support. More...
#include <inttypes.h>#include <stdlib.h>#include <string.h>#include <rtems/rfs/rtems-rfs-block.h>#include <rtems/rfs/rtems-rfs-buffer.h>#include <rtems/rfs/rtems-rfs-group.h>#include <rtems/rfs/rtems-rfs-inode.h>#include <rtems/rfs/rtems-rfs-dir.h>#include <rtems/rtems-rfs-format.h>#include <sys/statvfs.h>Data Structures | |
| struct | rtems_rfs_shell_cmd |
Typedefs | |
| typedef int(* | rtems_rfs_shell_handler) (rtems_rfs_file_system *fs, int argc, char *argv[]) |
| int | rtems_shell_debugrfs (int argc, char *argv[]) |
| int | rtems_shell_rfs_format (int argc, char *argv[]) |
| typedef int(* rtems_rfs_shell_handler) (rtems_rfs_file_system *fs, int argc, char *argv[]) |
The type of the shell handlers we have.
| int rtems_shell_debugrfs | ( | int | argc, |
| char * | argv[] | ||
The shell command for the RFS debugger.
| [in] | argc | is the argument count. |
| [in] | argv | is a pointer to the argument variables. |
| 0 | Successful operation. |
| error_code | An error occurred. |
| int rtems_shell_rfs_format | ( | int | argc, |
The shell command for formatting an RFS file system.
| 1 | An error occurred. |
