RTEMS 6.1-rc8
This header file provides the interfaces of the ISR Locks. More...
| struct | ISR_lock_Context |
| Local ISR lock context for acquire and release pairs. More... | |
| #define | ISR_LOCK_NEEDS_OBJECT 0 |
| If this define has a non-zero value, then the interrupt lock operations require an object of type ::ISR_lock_Control, otherwise no lock object is required. | |
| #define | _ISR_lock_Initialize(_lock, _name) do { (void) _name; } while (0) |
| Initializes an ISR lock. | |
| #define | _ISR_lock_Destroy(_lock) |
| Destroys an ISR lock. | |
| #define | _ISR_lock_Set_name(_lock, _name) |
| Sets the name of an ISR lock. | |
| #define | _ISR_lock_ISR_disable_and_acquire(_lock, _context) _ISR_Local_disable( ( _context )->isr_level ) |
| Acquires an ISR lock. | |
| #define | _ISR_lock_Release_and_ISR_enable(_lock, _context) _ISR_Local_enable( ( _context )->isr_level ) |
| Releases an ISR lock. | |
| #define | _ISR_lock_Acquire(_lock, _context) do { (void) _context; } while ( 0 ) |
| Acquires an ISR lock inside an ISR disabled section. | |
| #define | _ISR_lock_Release(_lock, _context) do { (void) _context; } while ( 0 ) |
| Releases an ISR lock inside an ISR disabled section. | |
| #define | _ISR_lock_Acquire_inline(_lock, _context) do { (void) _context; } while ( 0 ) |
| Acquires an ISR lock inside an ISR disabled section (inline). | |
| #define | _ISR_lock_Release_inline(_lock, _context) do { (void) _context; } while ( 0 ) |
| Releases an ISR lock inside an ISR disabled section (inline). | |
| #define | _ISR_lock_ISR_disable_profile(_context) |
| #define | _ISR_lock_ISR_disable(_context) |
| Disables interrupts and saves the previous interrupt state in the ISR lock context. | |
| #define | _ISR_lock_ISR_enable(_context) _ISR_Local_enable( ( _context )->isr_level ) |
| Restores the saved interrupt state of the ISR lock context. | |
