RTEMS 6.1-rc8
This header file provides interfaces of the Interrupt Manager implementation. More...
#include <stdbool.h>#include <rtems/irq-extension.h>#include <rtems/score/assert.h>#include <rtems/score/processormask.h>#include <bsp/irq.h>Go to the source code of this file.
| #define | BSP_INTERRUPT_DISPATCH_TABLE_SIZE BSP_INTERRUPT_VECTOR_COUNT |
| #define | bsp_interrupt_assert(e) _Assert(e) |
| void | bsp_interrupt_handler_default (rtems_vector_number vector) |
| Default interrupt handler. | |
| void | bsp_interrupt_initialize (void) |
| Initialize Interrupt Manager implementation. | |
| void | bsp_interrupt_facility_initialize (void) |
| BSP specific initialization. | |
| rtems_status_code | bsp_interrupt_get_attributes (rtems_vector_number vector, rtems_interrupt_attributes *attributes) |
| Gets the attributes of the interrupt vector. | |
| rtems_status_code | bsp_interrupt_vector_is_enabled (rtems_vector_number vector, bool *enabled) |
| Checks if the interrupt is enabled. | |
| rtems_status_code | bsp_interrupt_vector_enable (rtems_vector_number vector) |
| Enables the interrupt vector. | |
| rtems_status_code | bsp_interrupt_vector_disable (rtems_vector_number vector) |
| Disables the interrupt vector. | |
| rtems_status_code | bsp_interrupt_is_pending (rtems_vector_number vector, bool *pending) |
| Checks if the interrupt is pending. | |
| rtems_status_code | bsp_interrupt_raise (rtems_vector_number vector) |
| Causes the interrupt vector. | |
| rtems_status_code | bsp_interrupt_clear (rtems_vector_number vector) |
| Clears the interrupt vector. | |
| rtems_status_code | bsp_interrupt_get_priority (rtems_vector_number vector, uint32_t *priority) |
| Gets the priority of the interrupt vector. | |
| rtems_status_code | bsp_interrupt_set_priority (rtems_vector_number vector, uint32_t priority) |
| Sets the priority of the interrupt vector. | |
| rtems_status_code | bsp_interrupt_get_affinity (rtems_vector_number vector, Processor_mask *affinity) |
| Gets the processor affinity set of the interrupt vector. | |
| rtems_status_code | bsp_interrupt_set_affinity (rtems_vector_number vector, const Processor_mask *affinity) |
| Sets the processor affinity set of the interrupt vector. | |
| void | bsp_interrupt_lock (void) |
| Acquires the interrupt support lock. | |
| void | bsp_interrupt_unlock (void) |
| Releases the interrupt support lock. | |
| rtems_status_code | bsp_interrupt_check_and_lock (rtems_vector_number vector, rtems_interrupt_handler handler) |
| Checks the vector and routine. When the checks were successful, the interrupt support lock will be obtained. | |
| rtems_interrupt_entry * | bsp_interrupt_entry_find (rtems_vector_number vector, rtems_interrupt_handler routine, void *arg, rtems_interrupt_entry ***previous_next) |
| void | bsp_interrupt_entry_remove (rtems_vector_number vector, rtems_interrupt_entry *entry, rtems_interrupt_entry **previous_next) |
| rtems_interrupt_entry ** | bsp_interrupt_get_dispatch_table_slot (rtems_vector_number index) |
| Gets a reference to the interrupt handler table slot associated with the index. | |
| rtems_interrupt_entry * | bsp_interrupt_dispatch_table [] |
| Each member of this table references the first installed entry at the corresponding interrupt vector or is NULL. | |
| uint8_t | bsp_interrupt_handler_unique_table [] |
| This table contains a bit map which indicates if an entry is unique or shared. | |
| rtems_status_code bsp_interrupt_check_and_lock | ( | rtems_vector_number | vector, |
| rtems_interrupt_handler | handler | ||
| vector | is the interrupt vector number to check. |
| routine | is the routine to check. |
| RTEMS_SUCCESSFUL | The requested operation was successful. |
| RTEMS_INCORRECT_STATE | The interrupt support was not initialized. |
| RTEMS_CALLED_FROM_ISR | The function was called from within interrupt context. |
| RTEMS_INVALID_ADDRESS | The routine parameter was NULL. |
| RTEMS_INVALID_ID | There was no interrupt vector associated with the number specified by vector. |
| rtems_interrupt_entry ** bsp_interrupt_get_dispatch_table_slot | ( | rtems_vector_number | index | ) |
| void bsp_interrupt_lock | ( | void | ) |
The interrupt support lock is a mutex. The mutex is only acquired if the system is the SYSTEM_STATE_UP state.
| void bsp_interrupt_unlock | ( | void | ) |
The mutex is only released if the system is the SYSTEM_STATE_UP state.
extern |
If the bit associated with a vector is set, then the entry is unique, otherwise it may be shared. If the bit with index BSP_INTERRUPT_DISPATCH_TABLE_SIZE is set, then the interrupt support is initialized, otherwise it is not initialized.
