RTEMS 6.1-rc8
Removable media support. More...
Files | |
| file | media.h |
| Media Manager API. | |
| #define | RTEMS_MEDIA_MOUNT_BASE "/media" |
| #define | RTEMS_MEDIA_DELIMITER '-' |
Typedefs | |
| typedef rtems_status_code(* | rtems_media_listener) (rtems_media_event event, rtems_media_state state, const char *src, const char *dest, void *listener_arg) |
| Event listener. | |
| typedef rtems_status_code(* | rtems_media_worker) (rtems_media_state state, const char *src, char **dest, void *worker_arg) |
| Do the work corresponding to an event. | |
Enumerations | |
| enum | rtems_media_event { RTEMS_MEDIA_EVENT_DISK_ATTACH , RTEMS_MEDIA_EVENT_DISK_DETACH , RTEMS_MEDIA_EVENT_MOUNT , RTEMS_MEDIA_EVENT_UNMOUNT , RTEMS_MEDIA_EVENT_PARTITION_INQUIRY , RTEMS_MEDIA_EVENT_PARTITION_ATTACH , RTEMS_MEDIA_EVENT_PARTITION_DETACH , RTEMS_MEDIA_EVENT_ERROR } |
| enum | rtems_media_state { RTEMS_MEDIA_STATE_INQUIRY , RTEMS_MEDIA_STATE_READY , RTEMS_MEDIA_STATE_ABORTED , RTEMS_MEDIA_STATE_SUCCESS , RTEMS_MEDIA_STATE_FAILED , RTEMS_MEDIA_ERROR_DISK_UNKNOWN , RTEMS_MEDIA_ERROR_DISK_EXISTS , RTEMS_MEDIA_ERROR_DISK_OR_PARTITION_UNKNOWN , RTEMS_MEDIA_ERROR_DISK_OR_PARTITION_EXISTS , RTEMS_MEDIA_ERROR_PARTITION_UNKNOWN , RTEMS_MEDIA_ERROR_PARTITION_ORPHAN , RTEMS_MEDIA_ERROR_PARTITION_DETACH_WITH_MOUNT , RTEMS_MEDIA_ERROR_PARTITION_WITH_UNKNOWN_DISK , RTEMS_MEDIA_ERROR_MOUNT_POINT_UNKNOWN , RTEMS_MEDIA_ERROR_MOUNT_POINT_EXISTS , RTEMS_MEDIA_ERROR_MOUNT_POINT_ORPHAN } |
Base | |
| rtems_status_code | rtems_media_listener_add (rtems_media_listener listener, void *listener_arg) |
| Adds the listener with argument listener_arg. | |
| rtems_status_code | rtems_media_listener_remove (rtems_media_listener listener, void *listener_arg) |
| Removes the listener with argument listener_arg. | |
| rtems_status_code | rtems_media_post_event (rtems_media_event event, const char *src, char **dest, rtems_media_worker worker, void *worker_arg) |
| Posts the event with source src. | |
Server | |
| rtems_status_code | rtems_media_server_initialize (rtems_task_priority priority, size_t stack_size, rtems_mode modes, rtems_attribute attributes) |
| Initializes the media manager and media server. | |
| rtems_status_code | rtems_media_server_post_event (rtems_media_event event, const char *src, rtems_media_worker worker, void *worker_arg) |
| Sends an event message to the media server. | |
Path Construction | |
| char * | rtems_media_create_path (const char *prefix, const char *name, rtems_device_major_number major) |
| Creates a new path as "prefix/name-major". | |
| char * | rtems_media_replace_prefix (const char *new_prefix, const char *path) |
| Replaces the prefix of the path with new_prefix. | |
| char * | rtems_media_append_minor (const char *path, rtems_device_minor_number minor) |
| Appends the minor number to the path resulting in "path-minor". | |
Support | |
| rtems_status_code | rtems_media_get_device_identifier (const char *device_path, dev_t *device_identifier) |
| Returns the device identifier for the device located at device_path in device_identifier. | |
| const char * | rtems_media_event_description (rtems_media_event event) |
| const char * | rtems_media_state_description (rtems_media_state state) |
The media manager may be used to maintain the life cycle of a removable media. Currently only disk devices are supported. The initiator posts an event to the media manager and it will respond with appropriate default actions. For example a disk attach will lead to inspection of the partition table and mounted file systems. Clients can register listeners to react to events.
| typedef rtems_status_code(* rtems_media_listener) (rtems_media_event event, rtems_media_state state, const char *src, const char *dest, void *listener_arg) |
Event listener.
The listener will be called with the listener_arg passed to rtems_media_listener_add().
Source and destination values for each event and state:
| Event | State | Source | Destination |
| RTEMS_MEDIA_EVENT_DISK_ATTACH | RTEMS_MEDIA_STATE_INQUIRY | driver name | NULL |
| RTEMS_MEDIA_STATE_READY | driver name | NULL | |
| RTEMS_MEDIA_STATE_ABORTED | driver name | NULL | |
| RTEMS_MEDIA_STATE_SUCCESS | driver name | disk path | |
| RTEMS_MEDIA_STATE_FAILED | driver name | NULL | |
| RTEMS_MEDIA_EVENT_DISK_DETACH | RTEMS_MEDIA_STATE_INQUIRY | disk path | NULL |
| RTEMS_MEDIA_STATE_READY | disk path | NULL | |
| RTEMS_MEDIA_STATE_ABORTED | disk path | NULL | |
| RTEMS_MEDIA_STATE_SUCCESS | disk path | NULL | |
| RTEMS_MEDIA_STATE_FAILED | disk path | NULL | |
| RTEMS_MEDIA_EVENT_PARTITION_INQUIRY | RTEMS_MEDIA_STATE_INQUIRY | disk path | NULL |
| RTEMS_MEDIA_EVENT_PARTITION_ATTACH | RTEMS_MEDIA_STATE_INQUIRY | disk path | NULL |
| RTEMS_MEDIA_STATE_SUCCESS | disk path | partition path | |
| RTEMS_MEDIA_EVENT_PARTITION_DETACH | RTEMS_MEDIA_STATE_INQUIRY | partition path | NULL |
| RTEMS_MEDIA_STATE_READY | partition path | NULL | |
| RTEMS_MEDIA_STATE_ABORTED | partition path | NULL | |
| RTEMS_MEDIA_STATE_SUCCESS | partition path | NULL | |
| RTEMS_MEDIA_STATE_FAILED | partition path | NULL | |
| RTEMS_MEDIA_EVENT_MOUNT | RTEMS_MEDIA_STATE_INQUIRY | disk or partition path | NULL |
| RTEMS_MEDIA_STATE_READY | disk or partition path | NULL | |
| RTEMS_MEDIA_STATE_ABORTED | disk or partition path | NULL | |
| RTEMS_MEDIA_STATE_SUCCESS | disk or partition path | mount path | |
| RTEMS_MEDIA_STATE_FAILED | disk or partition path | NULL | |
| RTEMS_MEDIA_EVENT_UNMOUNT | RTEMS_MEDIA_STATE_INQUIRY | mount path | NULL |
| RTEMS_MEDIA_STATE_READY | mount path | NULL | |
| RTEMS_MEDIA_STATE_ABORTED | mount path | NULL | |
| RTEMS_MEDIA_STATE_SUCCESS | mount path | NULL | |
| RTEMS_MEDIA_STATE_FAILED | mount path | NULL | |
| RTEMS_MEDIA_EVENT_ERROR | RTEMS_MEDIA_ERROR_DISK_UNKNOWN | disk path | NULL |
| RTEMS_MEDIA_ERROR_DISK_EXISTS | disk path | NULL | |
| RTEMS_MEDIA_ERROR_DISK_OR_PARTITION_UNKNOWN | disk or partition path | NULL | |
| RTEMS_MEDIA_ERROR_DISK_OR_PARTITION_EXISTS | disk or partition path | NULL | |
| RTEMS_MEDIA_ERROR_PARTITION_UNKNOWN | partition path | NULL | |
| RTEMS_MEDIA_ERROR_PARTITION_ORPHAN | partition path | disk path | |
| RTEMS_MEDIA_ERROR_PARTITION_DETACH_WITH_MOUNT | partition path | mount path | |
| RTEMS_MEDIA_ERROR_PARTITION_WITH_UNKNOWN_DISK | partition path | disk path | |
| RTEMS_MEDIA_ERROR_MOUNT_POINT_UNKNOWN | mount path | NULL | |
| RTEMS_MEDIA_ERROR_MOUNT_POINT_EXISTS | mount path | NULL | |
| RTEMS_MEDIA_ERROR_MOUNT_POINT_ORPHAN | mount path | disk path |
| RTEMS_SUCCESSFUL | Successful operation. |
| RTEMS_IO_ERROR | In the inquiry state this will abort the action. |
| RTEMS_INCORRECT_STATE | In the failed state this will cause a retry. Make sure to have a retry counter or similar to avoid endless loops if you use this value. |
| typedef rtems_status_code(* rtems_media_worker) (rtems_media_state state, const char *src, char **dest, void *worker_arg) |
The state will be
It will be called with the src and worker_arg arguments passed to rtems_media_post_event().
The destination shall be returned in dest in case of success. It shall be allocated with malloc().
| RTEMS_IO_ERROR | Failure. |
| enum rtems_media_event |
Disk life cycle events:
| enum rtems_media_state |
Normal state transition:
| char * rtems_media_append_minor | ( | const char * | path, |
| rtems_device_minor_number | minor | ||
NULL if no memory is available. | char * rtems_media_create_path | ( | const char * | prefix, |
| const char * | name, | ||
| rtems_device_major_number | major | ||
NULL if no memory is available. | rtems_status_code rtems_media_get_device_identifier | ( | const char * | device_path, |
| dev_t * | device_identifier | ||
| RTEMS_INVALID_ID | No device at this path. |
| rtems_status_code rtems_media_listener_add | ( | rtems_media_listener | listener, |
| void * | listener_arg | ||
| RTEMS_NO_MEMORY | Not enough memory. |
| RTEMS_TOO_MANY | Such a listener is already present. |
| rtems_status_code rtems_media_listener_remove | ( | rtems_media_listener | listener, |
| RTEMS_INVALID_ID | No such listener is present. |
| rtems_status_code rtems_media_post_event | ( | rtems_media_event | event, |
| const char * | src, | ||
| char ** | dest, | ||
| rtems_media_worker | worker, | ||
| void * | worker_arg | ||
The worker will be called with the worker_arg argument.
The destination will be returned in dest in case of success. It will be allocated with malloc() and should be freed if not needed anymore.
The work will be done by the calling thread. You can avoid this if you use the media server via rtems_media_server_post_event().
| RTEMS_UNSATISFIED | One or more listeners aborted the action. |
| RTEMS_IO_ERROR | The worker returned with an error status. |
| char * rtems_media_replace_prefix | ( | const char * | new_prefix, |
| const char * | path | ||
The prefix is everything up to the last '/'.
NULL if no memory is available. | rtems_status_code rtems_media_server_initialize | ( | rtems_task_priority | priority, |
| size_t | stack_size, | ||
| rtems_mode | modes, | ||
| rtems_attribute | attributes | ||
It creates a server task with the priority, stack_size, modes, and attributes parameters.
Calling this function more than once will have no effects. There is no protection against concurrent access.
| RTEMS_NO_MEMORY | Not enough resources. |
| rtems_status_code rtems_media_server_post_event | ( | rtems_media_event | event, |
| RTEMS_NO_MEMORY | Not enough resources to notify the media server. |
| RTEMS_NOT_CONFIGURED | Media server is not initialized. |
