RTEMS 6.1-rc8
LEON3 and LEON4 Board Support Package. More...
Modules | |
| GR740 Bootstrap Signals | |
| This group contains the GR740 Bootstrap Signals interfaces. | |
| GR740 I/0 and PLL Configuration | |
| This group contains the GR740 I/0 and PLL Configuration interfaces. | |
| GR740 Temperatur Sensor Controller | |
| This group contains the GR740 Temperatur Sensor Controller interfaces. | |
| LEON3 AMBA Driver Handler | |
| AMBA Plag & Play Bus Driver Macros. | |
Files | |
| file | gr_leon4_n2x.h |
| This header file provides interfaces of the GR-CPCI-LEON4-N2X (NGFP) PCI Peripheral driver. | |
| file | ckinit.c |
| This source file contains the Clock Driver implementation. | |
| file | printk_support.c |
| This source file contains the definition of BSP_output_char and BSP_poll_char. | |
| file | gnatsupp.c |
| Support for gnat/rtems interrupts and exception handling. | |
| file | bsp.h |
| Global BSP definitions. | |
| file | irq.h |
| LEON3 generic shared IRQ setup. | |
| file | irqimpl.h |
| This header file provides interfaces used by the interrupt support implementation. | |
| file | leon3.h |
| This header file provides interfaces used by the BSP implementation. | |
| file | leon.h |
| LEON3 BSP data types and macros. | |
| file | tm27.h |
| Implementations for interrupt mechanisms for Time Test 27. | |
| file | bspsmp.c |
| LEON3 SMP BSP Support. | |
| file | bspstart.c |
| This source file contains the implementation of bsp_start() and definitions of BSP-specific objects. | |
| file | cache.c |
| This source file contains the implementation of the Cache Manager. | |
| file | cpucounter.c |
| This source file contains the implementation of the CPU Counter. | |
| file | eirq.c |
| This source file contains the implementation of the interrupt controller support. | |
| file | gettargethash.c |
| This source file contains the sparc/leon3 implementation of rtems_get_target_hash(). | |
| file | setvec.c |
| Install an interrupt vector on SPARC. | |
| file | bsp_isr_handler.c |
| This source file contains the implementation of _SPARC_Interrupt_dispatch(). | |
| struct | leon3_timecounter |
| Represents the LEON3-specific timecounter. More... | |
| #define | LEON3 1 |
| #define | BSP_FEATURE_IRQ_EXTENSION |
| #define | BSP_IDLE_TASK_BODY bsp_idle_thread |
| #define | BSP_NUMBER_OF_TERMIOS_PORTS 8 |
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME_OPENETH "open_eth1" |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH rtems_leon_open_eth_driver_attach |
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME_SMC91111 "smc_eth1" |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH_SMC91111 rtems_smc91111_driver_attach_leon3 |
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME_GRETH "gr_eth1" |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH_GRETH rtems_leon_greth_driver_attach |
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME RTEMS_BSP_NETWORK_DRIVER_NAME_GRETH |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH RTEMS_BSP_NETWORK_DRIVER_ATTACH_GRETH |
| #define | HAS_SMC91111 |
| #define | GRETH_SUPPORTED |
| #define | GRETH_MEM_LOAD(addr) leon_r32_no_cache((uintptr_t)addr) |
| #define | AMBAPPBUS_INFO_AVAIL /* AMBAPP Bus driver */ |
| #define | APBUART_INFO_AVAIL /* APBUART Console driver */ |
| #define | GPTIMER_INFO_AVAIL /* GPTIMER Timer driver */ |
| #define | GRETH_INFO_AVAIL /* GRETH Ethernet driver */ |
| #define | LEON3_IRQCTRL_ACQUIRE(_lock_context) rtems_interrupt_lock_acquire( &LEON3_IrqCtrl_Lock, _lock_context ) |
| Acquires the interrupt controller lock. | |
| #define | LEON3_IRQCTRL_RELEASE(_lock_context) rtems_interrupt_lock_release( &LEON3_IrqCtrl_Lock, _lock_context ) |
| Releases the interrupt controller lock. | |
| #define | LEON3_REG_CACHE_CTRL_FI 0x00200000U |
| This constant represents the flush instruction cache flag of the LEON cache control register. | |
| #define | LEON3_REG_CACHE_CTRL_DS 0x00800000U |
| This constant represents the data cache snooping enable flag of the LEON cache control register. | |
| #define | LEON3_CLOCK_INDEX 0 |
| This constant defines the index of the GPTIMER timer used by the clock driver. | |
| #define | LEON3_COUNTER_GPTIMER_INDEX ( LEON3_CLOCK_INDEX + 1 ) |
| This constant defines the index of the GPTIMER timer used by the CPU counter if the CPU counter uses the GPTIMER. | |
| #define | LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER 1000000 |
| This constant defines the frequency set by the boot loader of the first GPTIMER instance. | |
Typedefs | |
| typedef void(* | bsp_shared_isr) (void *arg) |
| void * | bsp_idle_thread (uintptr_t ignored) |
| Optimized idle task. | |
| int | rtems_leon_open_eth_driver_attach (struct rtems_bsdnet_ifconfig *config, int attach) |
| int | rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config, int attach) |
| int | rtems_leon_greth_driver_attach (struct rtems_bsdnet_ifconfig *config, int attach) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler. | |
| void | BSP_fatal_exit (uint32_t error) |
| void | rtems_bsp_delay (int usecs) |
| void | leon3_ext_irq_init (irqamp *regs) |
| Initializes the interrupt controller for the boot processor. | |
| RTEMS_NO_RETURN void | leon3_power_down_loop (void) |
| Sets asr19 to zero to enter the power-down mode of the processor in an infinite loop. | |
| int | CPU_SPARC_HAS_SNOOPING |
| int | RAM_START |
| int | RAM_END |
| int | RAM_SIZE |
| int | PROM_START |
| int | PROM_END |
| int | PROM_SIZE |
| int | CLOCK_SPEED |
| int | end |
| uint32_t | LEON3_Cpu_Index |
| This object provides the index of the boot processor. | |
| rtems_interrupt_lock | LEON3_IrqCtrl_Lock |
| This lock serializes the interrupt controller access. | |
| irqamp * | LEON3_IrqCtrl_Regs |
| This pointer provides the IRQ(A)MP register block address. | |
| struct ambapp_dev * | LEON3_IrqCtrl_Adev |
| This pointer provides the IRQ(A)MP device information block. | |
| uint32_t | LEON3_IrqCtrl_EIrq |
| This object provides the interrupt number used to multiplex extended interrupts or is zero if no extended interrupts are available. | |
| int | leon3_timer_core_index |
| This object lets the user override which on-chip GPTIMER core will be used for system clock timer. | |
| unsigned int | leon3_timer_prescaler |
| This object lets the user override system clock timer prescaler. | |
| gptimer * | LEON3_Timer_Regs |
| This pointer provides the GPTIMER register block address. | |
| struct ambapp_dev * | LEON3_Timer_Adev |
| This pointer provides the GPTIMER device information block. | |
| apbuart * | leon3_debug_uart |
| This pointer provides the debug APBUART register block address. | |
| leon3_timecounter | leon3_timecounter_instance |
| Provides the LEON3-specific timecounter. | |
| #define LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER 1000000 |
We assume that a boot loader (usually GRMON) initialized the GPTIMER 0 to run with 1MHz. This is used to determine all clock frequencies of the PnP devices. See also ambapp_freq_init() and ambapp_freq_get().
| #define LEON3_IRQCTRL_ACQUIRE | ( | _lock_context | ) | rtems_interrupt_lock_acquire( &LEON3_IrqCtrl_Lock, _lock_context ) |
| [out] | _lock_context | is the lock context. |
| #define LEON3_IRQCTRL_RELEASE | ( | _lock_context | ) | rtems_interrupt_lock_release( &LEON3_IrqCtrl_Lock, _lock_context ) |
| [in,out] | _lock_context | is the lock context. |
| void * bsp_idle_thread | ( | uintptr_t | ignored | ) |
This BSP provides its own IDLE thread to override the RTEMS one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
| void leon3_ext_irq_init | ( | irqamp * | regs | ) |
| [in,out] | regs | is the IRQ(A)MP register block address. |
| rtems_isr_entry set_vector | ( | rtems_isr_entry | handler, |
| rtems_vector_number | vector, | ||
| int | type | ||
This method installs an interrupt handle.
| [in] | handler | is the isr routine |
| [in] | vector | is the vector number |
| [in] | type | indicates whether RTEMS or RAW intr |
extern |
This object should be read-only after initialization.
extern |
extern |
It is also used by the CPU counter implementation.
extern |
This controls which timer core will be accociated with LEON3_Timer_Regs registers base address. This value will by destroyed during initialization.
extern |
This affects all timer instances on the system clock timer core determined by leon3_timer_core_index.
