RTEMS 6.1-rc8
This source file contains the implementation of the interrupt controller support. More...
| void | leon3_ext_irq_init (irqamp *regs) |
| Initializes the interrupt controller for the boot processor. | |
| bool | bsp_interrupt_is_valid_vector (rtems_vector_number vector) |
| void | bsp_interrupt_facility_initialize (void) |
| BSP specific initialization. | |
| rtems_status_code | bsp_interrupt_get_attributes (rtems_vector_number vector, rtems_interrupt_attributes *attributes) |
| Gets the attributes of the interrupt vector. | |
| rtems_status_code | bsp_interrupt_is_pending (rtems_vector_number vector, bool *pending) |
| Checks if the interrupt is pending. | |
| rtems_status_code | bsp_interrupt_raise (rtems_vector_number vector) |
| Causes the interrupt vector. | |
| rtems_status_code | bsp_interrupt_clear (rtems_vector_number vector) |
| Clears the interrupt vector. | |
| rtems_status_code | bsp_interrupt_vector_is_enabled (rtems_vector_number vector, bool *enabled) |
| Checks if the interrupt is enabled. | |
| rtems_status_code | bsp_interrupt_vector_enable (rtems_vector_number vector) |
| Enables the interrupt vector. | |
| rtems_status_code | bsp_interrupt_vector_disable (rtems_vector_number vector) |
| Disables the interrupt vector. | |
| rtems_status_code | bsp_interrupt_set_priority (rtems_vector_number vector, uint32_t priority) |
| Sets the priority of the interrupt vector. | |
| rtems_status_code | bsp_interrupt_get_priority (rtems_vector_number vector, uint32_t *priority) |
| Gets the priority of the interrupt vector. | |
| uint32_t | LEON3_IrqCtrl_EIrq |
| This object provides the interrupt number used to multiplex extended interrupts or is zero if no extended interrupts are available. | |
| rtems_interrupt_lock | LEON3_IrqCtrl_Lock |
| This lock serializes the interrupt controller access. | |
