RTEMS 6.1-rc7
Test context for spec:/rtems/sem/req/flush test case. More...
TQContext tq_ctx
 This member contains the thread queue test context.
rtems_attribute attribute_set
 This member specifies if the attribute set of the semaphore.
uint32_t initial_count
 This member specifies if the initial count of the semaphore.
struct {
   size_t   pci [3]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [3]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsSemReqFlush_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
