RTEMS 6.1-rc7
Test context for spec:/rtems/message/req/receive test case. More...
Data Fields | |
TQContext | tq_ctx |
This member contains the thread queue test context. | |
rtems_attribute | attribute_set |
This member specifies the attribute set of the message queue. | |
storage_area [MAXIMUM_PENDING_MESSAGES] | |
This member is used as storage area for the message queue. | |
uint32_t | magic |
This member contains always the same arbitrary number magic . | |
uint8_t | send_msg_counter |
This member contains a number which is sent as next message. | |
uint8_t | receive_buffer [MAXIMUM_MESSAGE_SIZE] |
This member contains a buffer to receive messages from the queue. | |
size_t | receive_size |
This member contains a buffer to receive the messages size. | |
rtems_id | id_param |
This member specifies the id parameter for the action. | |
void * | buffer_param |
This member specifies the buffer parameter for the action. | |
size_t * | size_param |
This member specifies the size parameter for the action. | |
rtems_option | option_set_param |
This member specifies the option_set parameter for the action. | |
rtems_interval | timeout_param |
This member specifies the timeout parameter for the action. | |
rtems_status_code | status |
This member contains the returned status code of the action. | |
uint32_t | action_duration |
This member contains the duration of the action in ticks. | |
rtems_id | task_id |
This member contains the task identifier of the main task. | |
rtems_id | worker_id |
This member contains the task identifier of the worker task. | |
void(* | concurrent_activity )(void *ctx_in) |
This member contains a pointer to a function which is executed while the worker is waiting to receive a message (delete(), nop() `). | |
void(* | check_msgq_unchanged )(void *ctx_in) |
This member contains a pointer to a function which is executed to check that the action has not changed the content of the message queue. | |
struct { | |
size_t pcs [8] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsMessageReqReceive_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
uint32_t RtemsMessageReqReceive_Context::magic |
It is used for run-time type checking.
