RTEMS 6.1-rc7
Test context for spec:/rtems/clock/req/set test case. More...
rtems_status_code status
bool register_hook
Status_Control hook_status
rtems_time_of_daytarget_tod
rtems_time_of_day target_tod_value
rtems_time_of_day tod_before
rtems_status_code get_tod_before_status
rtems_time_of_day tod_after
rtems_status_code get_tod_after_status
rtems_id timer_id
int timer_routine_counter
rtems_time_of_day timer_routine_tod
struct {
   size_t   pcs [2]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsClockReqSet_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
