RTEMS 6.1-rc7
Test context for spec:/newlib/req/futex-wait test case. More...
TQContext tq_ctx
 This member contains the thread queue test context.
int expected_value
 This member specifies the expected futex state value.
struct _Futex_Control futex
 This member provides the futex object.
int state
 This member provides the futex state.
struct {
   size_t   pcs [1]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   NewlibReqFutexWait_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
