RTEMS 6.1-rc7
Files | Macros | Functions
Thread Handler Multiprocessing (MP) Support
This group contains the implementation to support the Thread Handler in multiprocessing (MP) configurations. More...
file  threadmp.h
 This header file provides the interfaces of the Thread Handler Multiprocessing (MP) Support.
file  threadmp.c
 This source file contains the implementation of _Thread_MP_Handler_initialization(), _Thread_MP_Allocate_proxy(), _Thread_MP_Find_proxy(), _Thread_MP_Free_proxy().
#define _Thread_MP_Is_receive(_the_thread)    ((_the_thread) == _MPCI_Receive_server_tcb)
void _Thread_MP_Handler_initialization (uint32_t maximum_proxies)
 Initialize MP thread handler.
Thread_Control_Thread_MP_Allocate_proxy (States_Control the_state)
 Allocates a MP proxy control block from the inactive chain of free proxy control blocks.
Thread_Control_Thread_MP_Find_proxy (Objects_Id the_id)
 Removes the MP proxy control block for the specified id from the active chain of proxy control blocks.
void _Thread_MP_Extract_proxy (Thread_Control *the_thread)
 Extracts the proxy of the thread if necessary.
void _Thread_MP_Free_proxy (Thread_Control *the_thread)
 Trees a proxy control block to the inactive chain of free proxy control blocks.
This handler encapsulates functionality which is related to managing threads in a multiprocessor system configuration. This handler must manage proxies which represent remote threads blocking on local operations.
◆ _Thread_MP_Is_receive
#define _Thread_MP_Is_receive (   _the_thread)     ((_the_thread) == _MPCI_Receive_server_tcb)
This function returns true if the thread in question is the multiprocessing receive thread.
Note
This is a macro to avoid needing a prototype for _MPCI_Receive_server_tcb until it is used.
◆ _Thread_MP_Allocate_proxy()
Thread_Control * _Thread_MP_Allocate_proxy ( States_Control  the_state)
This allocates a proxy control block from the inactive chain of free proxy control blocks.
Note
This function returns a thread control pointer because proxies are substitutes for remote threads.
  • Parameters
    the_stateThe state for the allocated MP proxy control block.
◆ _Thread_MP_Extract_proxy()
void _Thread_MP_Extract_proxy ( Thread_Control the_thread)
This routine ensures that if there is a proxy for this thread on another node, it is also dealt with. A proxy is a data that is on the thread queue on the remote node and acts as a proxy for the local thread. If the local thread was waiting on a remote operation, then the remote side of the operation must be cleaned up.
Parameters
[in,out]the_threadis the thread to determine the proxy.
◆ _Thread_MP_Find_proxy()
Thread_Control * _Thread_MP_Find_proxy ( Objects_Id  the_id)
This function removes the proxy control block for the specified id from the active red-black tree of proxy control blocks.
Parameters
the_idThe id of the proxy control block to remove.
Returns
The removed proxy control block.
◆ _Thread_MP_Handler_initialization()
void _Thread_MP_Handler_initialization ( uint32_t  maximum_proxies)
This routine initializes the multiprocessing portion of the Thread Handler.
Parameters
maximum_proxiesThe maximum number of proxies for the MP thread handler.
