RTEMS 6.1-rc7
_Thread_Control Struct Reference
#include <thread.h>
Objects_Control Object
Thread_queue_Control Join_queue
 Thread queue for thread join operations and multi-purpose lock.
States_Control current_state
Priority_Node Real_priority
 The base priority of this thread in its home scheduler instance.
Thread_Scheduler_control Scheduler
 Scheduler related control.
Thread_Wait_information Wait
Thread_Timer_information Timer
Context_Control Registers
 This member contains the context of this thread.
bool is_idle
bool is_preemptible
bool is_fp
bool was_created_with_inherited_scheduler
 True, if the thread was created with an inherited scheduler (PTHREAD_INHERIT_SCHED), and false otherwise.
Thread_CPU_budget_control CPU_budget
 This member contains the CPU budget control used to manage the CPU budget of the thread.
Timestamp_Control cpu_time_used
 This member contains the amount of CPU time consumed by this thread since it was created.
Timestamp_Control cpu_time_used_at_last_reset
 This member contains the amount of CPU time consumed by this thread at the time of the last reset of the CPU usage by rtems_cpu_usage_reset().
Thread_Start_information Start
Thread_Action_control Post_switch_actions
Context_Control_fpfp_context
struct _reent * libc_reent
void * API_Extensions [THREAD_API_LAST+1]
Thread_Keys_information Keys
 The POSIX Keys information.
Thread_Life_control Life
 Thread life-cycle control.
Thread_Capture_control Capture
struct rtems_user_env_tuser_environment
 Pointer to an optional thread-specific POSIX user environment.
struct _pthread_cleanup_context * last_cleanup_context
 LIFO list of POSIX cleanup contexts.
struct User_extensions_Iteratorlast_user_extensions_iterator
 LIFO list of user extensions iterators.
void * extensions [RTEMS_ZERO_LENGTH_ARRAY]
 Variable length array of user extension pointers.
This structure defines the Thread Control Block (TCB).
Uses a leading underscore in the structure name to allow forward declarations in standard header files provided by Newlib and GCC.
In case the second member changes (currently Join_queue), then the memset() in _Thread_Initialize() must be adjusted.
Field Documentation
◆ API_Extensions
void* _Thread_Control::API_Extensions[THREAD_API_LAST+1]
This array contains the API extension area pointers.
◆ current_state
States_Control _Thread_Control::current_state
This field is the current execution state of this thread.
◆ extensions
void* _Thread_Control::extensions[RTEMS_ZERO_LENGTH_ARRAY]
The length is defined by the application via <rtems/confdefs.h>.
◆ fp_context
Context_Control_fp* _Thread_Control::fp_context
This field points to the floating point context for this thread. If NULL, the thread is integer only.
◆ is_fp
bool _Thread_Control::is_fp
This field is true if the thread uses the floating point unit.
◆ is_idle
bool _Thread_Control::is_idle
This field is true if the thread is an idle thread.
◆ is_preemptible
bool _Thread_Control::is_preemptible
This field is true if the thread is preemptible.
◆ Join_queue
Thread_queue_Control _Thread_Control::Join_queue
The lock of this thread queue is used for various purposes. It protects the following fields
See also
_Thread_State_acquire().
◆ libc_reent
struct _reent* _Thread_Control::libc_reent
This field points to the newlib reentrancy structure for this thread.
◆ Life
Thread_Life_control _Thread_Control::Life
Control state changes triggered by thread restart and delete requests.
◆ Object
Objects_Control _Thread_Control::Object
This field is the object management structure for each thread.
◆ Registers
Context_Control _Thread_Control::Registers
This member is placed directly after the end of the common block so that the structure offsets are as small as possible. This helps on instruction set architectures with a very limited range for intermediate values.
◆ Start
Thread_Start_information _Thread_Control::Start
This field contains information about the starting state of this thread.
◆ Timer
Thread_Timer_information _Thread_Control::Timer
This field is the Watchdog used to manage thread delays and timeouts.
◆ Wait
Thread_Wait_information _Thread_Control::Wait
This field is the blocking information for this thread.
