RTEMS 6.1-rc6
Files | Macros | Functions | Variables
AMD Zynq UltraScale+ MPSoC and RFSoC - Application Processing Unit
This group contains the BSP for the Application Processing Unit (APU) contained in AMD Zynq UltraScale+ MPSoC and RFSoC devices. More...
file  console.c
 This source file contains this BSP's console configuration.
file  management_apu.c
 This source file contains the management console implementation.
file  management_cfc400x.c
file  cache.c
 This source file contains the implementation of zynqmp_ecc_init().
file  ddr.c
 This source file contains the implementation of DDR ECC support.
file  ocm.c
 This source file contains the implementation of OCM ECC support.
file  bsp_fdt.c
 This source file contains the implementatin of bsp_fdt_get().
file  bsp.h
 This header file provides BSP-specific interfaces.
file  ecc.h
 This header file provides internal APIs for managing ECC events.
file  ecc_priv.h
file  irq.h
 This header file provides the BSP's IRQ definitions.
file  jffs2_xqspipsu.h
 XilinxZynqMP QSPI JFFS2 flash driver definitions.
file  xil-compat.h
file  tm27.h
 This header file provides functionality for the tm27 test.
file  bspstart.c
 This source file contains the implementation of bsp_start().
file  bspstartecc_cfc400x.c
 This source file contains the implementation of zynqmp_ecc_init_bsp().
file  bspstartecc_hw.c
file  bspstartecc_qemu.c
file  bspstartecc_zu3eg.c
file  bspstarthooks.c
 This source file contains the implementation of this BSP's startup hooks.
file  bspstartmmu.c
 This source file contains the default MMU tables and setup.
file  i2c-clocks.c
 This source file contains the implementation of zynqmp_clock_i2c0() and zynqmp_clock_i2c1().
file  mmu-config.c
 This source file contains the definition of aarch64_mmu_config_table and aarch64_mmu_config_table_size.
#define BSP_ARM_GIC_CPUIF_BASE   0xf9020000
#define BSP_ARM_GIC_DIST_BASE   0xf9010000
#define BSP_FDT_IS_SUPPORTED
#define NANDPSU_BASEADDR   0xFF100000
BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache (void)
 Zynq UltraScale+ MPSoC specific set up of the MMU.
BSP_START_TEXT_SECTION void zynqmp_setup_secondary_cpu_mmu_and_cache (void)
 Zynq UltraScale+ MPSoC specific set up of the MMU for non-primary cores.
void zynqmp_management_console_termios_init (void)
void zynqmp_debug_console_flush (void)
uint32_t zynqmp_clock_i2c0 (void)
uint32_t zynqmp_clock_i2c1 (void)
void zynqmp_configure_management_console (struct rtems_termios_device_context *base)
 Zynq UltraScale+ MPSoC specific set up of a management console.
unsigned int zynqmp_dtb_len
unsigned char zynqmp_dtb []
◆ zynqmp_configure_management_console()
void zynqmp_configure_management_console ( struct rtems_termios_device_context base)
Some systems may have a management interface which needs special initialization. Provide in the application to override the defaults in the BSP. This will only be called if the interface is found in the device tree.
◆ zynqmp_setup_mmu_and_cache()
BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache ( void  )
◆ zynqmp_setup_secondary_cpu_mmu_and_cache()
BSP_START_TEXT_SECTION void zynqmp_setup_secondary_cpu_mmu_and_cache ( void  )
