RTEMS 6.1-rc6
ECC_CTRL - ECC Control Register
#define XECC_ECC_CTRL_ECC_EN_MASK   (0x1U)
#define XECC_ECC_CTRL_ECC_EN_SHIFT   (0U)
#define XECC_ECC_CTRL_ECC_EN(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ECC_CTRL_ECC_EN_SHIFT)) & XECC_ECC_CTRL_ECC_EN_MASK)
#define XECC_ECC_CTRL_WECC_EN_MASK   (0x2U)
#define XECC_ECC_CTRL_WECC_EN_SHIFT   (1U)
#define XECC_ECC_CTRL_WECC_EN(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ECC_CTRL_WECC_EN_SHIFT)) & XECC_ECC_CTRL_WECC_EN_MASK)
#define XECC_ECC_CTRL_RECC_EN_MASK   (0x4U)
#define XECC_ECC_CTRL_RECC_EN_SHIFT   (2U)
#define XECC_ECC_CTRL_RECC_EN(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ECC_CTRL_RECC_EN_SHIFT)) & XECC_ECC_CTRL_RECC_EN_MASK)
#define XECC_ECC_CTRL_SWAP_EN_MASK   (0x8U)
#define XECC_ECC_CTRL_SWAP_EN_SHIFT   (3U)
#define XECC_ECC_CTRL_SWAP_EN(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ECC_CTRL_SWAP_EN_SHIFT)) & XECC_ECC_CTRL_SWAP_EN_MASK)
ERR_STATUS - Error Interrupt Status Register
#define XECC_ERR_STATUS_SINGLE_ERR_MASK   (0x1U)
#define XECC_ERR_STATUS_SINGLE_ERR_SHIFT   (0U)
#define XECC_ERR_STATUS_SINGLE_ERR(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ERR_STATUS_SINGLE_ERR_SHIFT)) & XECC_ERR_STATUS_SINGLE_ERR_MASK)
#define XECC_ERR_STATUS_MULTI_ERR_MASK   (0x2U)
#define XECC_ERR_STATUS_MULTI_ERR_SHIFT   (1U)
#define XECC_ERR_STATUS_MULTI_ERR(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ERR_STATUS_MULTI_ERR_SHIFT)) & XECC_ERR_STATUS_MULTI_ERR_MASK)
#define XECC_ERR_STATUS_Reserved1_MASK   (0xFFFFFFFCU)
#define XECC_ERR_STATUS_Reserved1_SHIFT   (2U)
#define XECC_ERR_STATUS_Reserved1(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ERR_STATUS_Reserved1_SHIFT)) & XECC_ERR_STATUS_Reserved1_MASK)
ERR_STAT_EN - Error Interrupt Status Enable Register
#define XECC_ERR_STAT_EN_SINGLE_ERR_STAT_EN_MASK   (0x1U)
#define XECC_ERR_STAT_EN_SINGLE_ERR_STAT_EN_SHIFT   (0U)
#define XECC_ERR_STAT_EN_SINGLE_ERR_STAT_EN(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ERR_STAT_EN_SINGLE_ERR_STAT_EN_SHIFT)) & XECC_ERR_STAT_EN_SINGLE_ERR_STAT_EN_MASK)
#define XECC_ERR_STAT_EN_MULIT_ERR_STAT_EN_MASK   (0x2U)
#define XECC_ERR_STAT_EN_MULIT_ERR_STAT_EN_SHIFT   (1U)
#define XECC_ERR_STAT_EN_MULIT_ERR_STAT_EN(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ERR_STAT_EN_MULIT_ERR_STAT_EN_SHIFT)) & XECC_ERR_STAT_EN_MULIT_ERR_STAT_EN_MASK)
#define XECC_ERR_STAT_EN_Reserved1_MASK   (0xFFFFFFFCU)
#define XECC_ERR_STAT_EN_Reserved1_SHIFT   (2U)
#define XECC_ERR_STAT_EN_Reserved1(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ERR_STAT_EN_Reserved1_SHIFT)) & XECC_ERR_STAT_EN_Reserved1_MASK)
ERR_SIG_EN - Error Interrupt Enable Register
#define XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN_MASK   (0x1U)
#define XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN_SHIFT   (0U)
#define XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN_SHIFT)) & XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN_MASK)
#define XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN_MASK   (0x2U)
#define XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN_SHIFT   (1U)
#define XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN_SHIFT)) & XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN_MASK)
#define XECC_ERR_SIG_EN_Reserved1_MASK   (0xFFFFFFFCU)
#define XECC_ERR_SIG_EN_Reserved1_SHIFT   (2U)
#define XECC_ERR_SIG_EN_Reserved1(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ERR_SIG_EN_Reserved1_SHIFT)) & XECC_ERR_SIG_EN_Reserved1_MASK)
ERR_DATA_INJ - Error Injection On Write Data
#define XECC_ERR_DATA_INJ_ERR_DATA_INJ_MASK   (0xFFFFFFFFU)
#define XECC_ERR_DATA_INJ_ERR_DATA_INJ_SHIFT   (0U)
#define XECC_ERR_DATA_INJ_ERR_DATA_INJ(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ERR_DATA_INJ_ERR_DATA_INJ_SHIFT)) & XECC_ERR_DATA_INJ_ERR_DATA_INJ_MASK)
ERR_ECC_INJ - Error Injection On ECC Code of Write Data
#define XECC_ERR_ECC_INJ_ERR_ECC_INJ_MASK   (0xFFFFFFFFU)
#define XECC_ERR_ECC_INJ_ERR_ECC_INJ_SHIFT   (0U)
#define XECC_ERR_ECC_INJ_ERR_ECC_INJ(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ERR_ECC_INJ_ERR_ECC_INJ_SHIFT)) & XECC_ERR_ECC_INJ_ERR_ECC_INJ_MASK)
SINGLE_ERR_ADDR - Single Error Address
#define XECC_SINGLE_ERR_ADDR_SINGLE_ERR_ADDR_MASK   (0xFFFFFFFFU)
#define XECC_SINGLE_ERR_ADDR_SINGLE_ERR_ADDR_SHIFT   (0U)
#define XECC_SINGLE_ERR_ADDR_SINGLE_ERR_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << XECC_SINGLE_ERR_ADDR_SINGLE_ERR_ADDR_SHIFT)) & XECC_SINGLE_ERR_ADDR_SINGLE_ERR_ADDR_MASK)
SINGLE_ERR_DATA - Single Error Read Data
#define XECC_SINGLE_ERR_DATA_SINGLE_ERR_DATA_MASK   (0xFFFFFFFFU)
#define XECC_SINGLE_ERR_DATA_SINGLE_ERR_DATA_SHIFT   (0U)
#define XECC_SINGLE_ERR_DATA_SINGLE_ERR_DATA(x)   (((uint32_t)(((uint32_t)(x)) << XECC_SINGLE_ERR_DATA_SINGLE_ERR_DATA_SHIFT)) & XECC_SINGLE_ERR_DATA_SINGLE_ERR_DATA_MASK)
SINGLE_ERR_ECC - Single Error ECC Code
#define XECC_SINGLE_ERR_ECC_SINGLE_ERR_ECC_MASK   (0xFFFFFFFFU)
#define XECC_SINGLE_ERR_ECC_SINGLE_ERR_ECC_SHIFT   (0U)
#define XECC_SINGLE_ERR_ECC_SINGLE_ERR_ECC(x)   (((uint32_t)(((uint32_t)(x)) << XECC_SINGLE_ERR_ECC_SINGLE_ERR_ECC_SHIFT)) & XECC_SINGLE_ERR_ECC_SINGLE_ERR_ECC_MASK)
SINGLE_ERR_POS - Single Error Bit Position
#define XECC_SINGLE_ERR_POS_SINGLE_ERR_POS_MASK   (0xFFFFFFFFU)
#define XECC_SINGLE_ERR_POS_SINGLE_ERR_POS_SHIFT   (0U)
#define XECC_SINGLE_ERR_POS_SINGLE_ERR_POS(x)   (((uint32_t)(((uint32_t)(x)) << XECC_SINGLE_ERR_POS_SINGLE_ERR_POS_SHIFT)) & XECC_SINGLE_ERR_POS_SINGLE_ERR_POS_MASK)
SINGLE_ERR_BIT_FIELD - Single Error Bit Field
#define XECC_SINGLE_ERR_BIT_FIELD_SINGLE_ERR_BIT_FIELD_MASK   (0xFFU)
#define XECC_SINGLE_ERR_BIT_FIELD_SINGLE_ERR_BIT_FIELD_SHIFT   (0U)
#define XECC_SINGLE_ERR_BIT_FIELD_SINGLE_ERR_BIT_FIELD(x)   (((uint32_t)(((uint32_t)(x)) << XECC_SINGLE_ERR_BIT_FIELD_SINGLE_ERR_BIT_FIELD_SHIFT)) & XECC_SINGLE_ERR_BIT_FIELD_SINGLE_ERR_BIT_FIELD_MASK)
#define XECC_SINGLE_ERR_BIT_FIELD_Reserved1_MASK   (0xFFFFFF00U)
#define XECC_SINGLE_ERR_BIT_FIELD_Reserved1_SHIFT   (8U)
#define XECC_SINGLE_ERR_BIT_FIELD_Reserved1(x)   (((uint32_t)(((uint32_t)(x)) << XECC_SINGLE_ERR_BIT_FIELD_Reserved1_SHIFT)) & XECC_SINGLE_ERR_BIT_FIELD_Reserved1_MASK)
MULTI_ERR_ADDR - Multiple Error Address
#define XECC_MULTI_ERR_ADDR_MULTI_ERR_ADDR_MASK   (0xFFFFFFFFU)
#define XECC_MULTI_ERR_ADDR_MULTI_ERR_ADDR_SHIFT   (0U)
#define XECC_MULTI_ERR_ADDR_MULTI_ERR_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << XECC_MULTI_ERR_ADDR_MULTI_ERR_ADDR_SHIFT)) & XECC_MULTI_ERR_ADDR_MULTI_ERR_ADDR_MASK)
MULTI_ERR_DATA - Multiple Error Read Data
#define XECC_MULTI_ERR_DATA_MULTI_ERR_DATA_MASK   (0xFFFFFFFFU)
#define XECC_MULTI_ERR_DATA_MULTI_ERR_DATA_SHIFT   (0U)
#define XECC_MULTI_ERR_DATA_MULTI_ERR_DATA(x)   (((uint32_t)(((uint32_t)(x)) << XECC_MULTI_ERR_DATA_MULTI_ERR_DATA_SHIFT)) & XECC_MULTI_ERR_DATA_MULTI_ERR_DATA_MASK)
MULTI_ERR_ECC - Multiple Error ECC code
#define XECC_MULTI_ERR_ECC_MULTI_ERR_ECC_MASK   (0xFFFFFFFFU)
#define XECC_MULTI_ERR_ECC_MULTI_ERR_ECC_SHIFT   (0U)
#define XECC_MULTI_ERR_ECC_MULTI_ERR_ECC(x)   (((uint32_t)(((uint32_t)(x)) << XECC_MULTI_ERR_ECC_MULTI_ERR_ECC_SHIFT)) & XECC_MULTI_ERR_ECC_MULTI_ERR_ECC_MASK)
MULTI_ERR_BIT_FIELD - Multiple Error Bit Field
#define XECC_MULTI_ERR_BIT_FIELD_MULTI_ERR_BIT_FIELD_MASK   (0xFFU)
#define XECC_MULTI_ERR_BIT_FIELD_MULTI_ERR_BIT_FIELD_SHIFT   (0U)
#define XECC_MULTI_ERR_BIT_FIELD_MULTI_ERR_BIT_FIELD(x)   (((uint32_t)(((uint32_t)(x)) << XECC_MULTI_ERR_BIT_FIELD_MULTI_ERR_BIT_FIELD_SHIFT)) & XECC_MULTI_ERR_BIT_FIELD_MULTI_ERR_BIT_FIELD_MASK)
#define XECC_MULTI_ERR_BIT_FIELD_Reserved1_MASK   (0xFFFFFF00U)
#define XECC_MULTI_ERR_BIT_FIELD_Reserved1_SHIFT   (8U)
#define XECC_MULTI_ERR_BIT_FIELD_Reserved1(x)   (((uint32_t)(((uint32_t)(x)) << XECC_MULTI_ERR_BIT_FIELD_Reserved1_SHIFT)) & XECC_MULTI_ERR_BIT_FIELD_Reserved1_MASK)
ECC_BASE_ADDR0 - ECC Region 0 Base Address
#define XECC_ECC_BASE_ADDR0_ECC_BASE_ADDR0_MASK   (0xFFFFFFFFU)
#define XECC_ECC_BASE_ADDR0_ECC_BASE_ADDR0_SHIFT   (0U)
#define XECC_ECC_BASE_ADDR0_ECC_BASE_ADDR0(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ECC_BASE_ADDR0_ECC_BASE_ADDR0_SHIFT)) & XECC_ECC_BASE_ADDR0_ECC_BASE_ADDR0_MASK)
ECC_END_ADDR0 - ECC Region 0 End Address
#define XECC_ECC_END_ADDR0_ECC_END_ADDR0_MASK   (0xFFFFFFFFU)
#define XECC_ECC_END_ADDR0_ECC_END_ADDR0_SHIFT   (0U)
#define XECC_ECC_END_ADDR0_ECC_END_ADDR0(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ECC_END_ADDR0_ECC_END_ADDR0_SHIFT)) & XECC_ECC_END_ADDR0_ECC_END_ADDR0_MASK)
ECC_BASE_ADDR1 - ECC Region 1 Base Address
#define XECC_ECC_BASE_ADDR1_ECC_BASE_ADDR1_MASK   (0xFFFFFFFFU)
#define XECC_ECC_BASE_ADDR1_ECC_BASE_ADDR1_SHIFT   (0U)
#define XECC_ECC_BASE_ADDR1_ECC_BASE_ADDR1(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ECC_BASE_ADDR1_ECC_BASE_ADDR1_SHIFT)) & XECC_ECC_BASE_ADDR1_ECC_BASE_ADDR1_MASK)
ECC_END_ADDR1 - ECC Region 1 End Address
#define XECC_ECC_END_ADDR1_ECC_END_ADDR1_MASK   (0xFFFFFFFFU)
#define XECC_ECC_END_ADDR1_ECC_END_ADDR1_SHIFT   (0U)
#define XECC_ECC_END_ADDR1_ECC_END_ADDR1(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ECC_END_ADDR1_ECC_END_ADDR1_SHIFT)) & XECC_ECC_END_ADDR1_ECC_END_ADDR1_MASK)
ECC_BASE_ADDR2 - ECC Region 2 Base Address
#define XECC_ECC_BASE_ADDR2_ECC_BASE_ADDR2_MASK   (0xFFFFFFFFU)
#define XECC_ECC_BASE_ADDR2_ECC_BASE_ADDR2_SHIFT   (0U)
#define XECC_ECC_BASE_ADDR2_ECC_BASE_ADDR2(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ECC_BASE_ADDR2_ECC_BASE_ADDR2_SHIFT)) & XECC_ECC_BASE_ADDR2_ECC_BASE_ADDR2_MASK)
ECC_END_ADDR2 - ECC Region 2 End Address
#define XECC_ECC_END_ADDR2_ECC_END_ADDR2_MASK   (0xFFFFFFFFU)
#define XECC_ECC_END_ADDR2_ECC_END_ADDR2_SHIFT   (0U)
#define XECC_ECC_END_ADDR2_ECC_END_ADDR2(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ECC_END_ADDR2_ECC_END_ADDR2_SHIFT)) & XECC_ECC_END_ADDR2_ECC_END_ADDR2_MASK)
ECC_BASE_ADDR3 - ECC Region 3 Base Address
#define XECC_ECC_BASE_ADDR3_ECC_BASE_ADDR3_MASK   (0xFFFFFFFFU)
#define XECC_ECC_BASE_ADDR3_ECC_BASE_ADDR3_SHIFT   (0U)
#define XECC_ECC_BASE_ADDR3_ECC_BASE_ADDR3(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ECC_BASE_ADDR3_ECC_BASE_ADDR3_SHIFT)) & XECC_ECC_BASE_ADDR3_ECC_BASE_ADDR3_MASK)
ECC_END_ADDR3 - ECC Region 3 End Address
#define XECC_ECC_END_ADDR3_ECC_END_ADDR3_MASK   (0xFFFFFFFFU)
#define XECC_ECC_END_ADDR3_ECC_END_ADDR3_SHIFT   (0U)
#define XECC_ECC_END_ADDR3_ECC_END_ADDR3(x)   (((uint32_t)(((uint32_t)(x)) << XECC_ECC_END_ADDR3_ECC_END_ADDR3_SHIFT)) & XECC_ECC_END_ADDR3_ECC_END_ADDR3_MASK)
◆ XECC_ECC_BASE_ADDR0_ECC_BASE_ADDR0 [1/2]
#define XECC_ECC_BASE_ADDR0_ECC_BASE_ADDR0 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ECC_BASE_ADDR0_ECC_BASE_ADDR0_SHIFT)) & XECC_ECC_BASE_ADDR0_ECC_BASE_ADDR0_MASK)
◆ XECC_ECC_BASE_ADDR0_ECC_BASE_ADDR0 [2/2]
◆ XECC_ECC_BASE_ADDR1_ECC_BASE_ADDR1 [1/2]
#define XECC_ECC_BASE_ADDR1_ECC_BASE_ADDR1 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ECC_BASE_ADDR1_ECC_BASE_ADDR1_SHIFT)) & XECC_ECC_BASE_ADDR1_ECC_BASE_ADDR1_MASK)
◆ XECC_ECC_BASE_ADDR1_ECC_BASE_ADDR1 [2/2]
◆ XECC_ECC_BASE_ADDR2_ECC_BASE_ADDR2 [1/2]
#define XECC_ECC_BASE_ADDR2_ECC_BASE_ADDR2 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ECC_BASE_ADDR2_ECC_BASE_ADDR2_SHIFT)) & XECC_ECC_BASE_ADDR2_ECC_BASE_ADDR2_MASK)
◆ XECC_ECC_BASE_ADDR2_ECC_BASE_ADDR2 [2/2]
◆ XECC_ECC_BASE_ADDR3_ECC_BASE_ADDR3 [1/2]
#define XECC_ECC_BASE_ADDR3_ECC_BASE_ADDR3 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ECC_BASE_ADDR3_ECC_BASE_ADDR3_SHIFT)) & XECC_ECC_BASE_ADDR3_ECC_BASE_ADDR3_MASK)
◆ XECC_ECC_BASE_ADDR3_ECC_BASE_ADDR3 [2/2]
◆ XECC_ECC_CTRL_ECC_EN [1/2]
#define XECC_ECC_CTRL_ECC_EN (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ECC_CTRL_ECC_EN_SHIFT)) & XECC_ECC_CTRL_ECC_EN_MASK)
ECC_EN - ECC Function Enable 0b0..Disable 0b1..Enable
◆ XECC_ECC_CTRL_ECC_EN [2/2]
◆ XECC_ECC_CTRL_RECC_EN [1/2]
#define XECC_ECC_CTRL_RECC_EN (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ECC_CTRL_RECC_EN_SHIFT)) & XECC_ECC_CTRL_RECC_EN_MASK)
RECC_EN - Read ECC Function Enable 0b0..Disable 0b1..Enable
◆ XECC_ECC_CTRL_RECC_EN [2/2]
◆ XECC_ECC_CTRL_SWAP_EN [1/2]
#define XECC_ECC_CTRL_SWAP_EN (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ECC_CTRL_SWAP_EN_SHIFT)) & XECC_ECC_CTRL_SWAP_EN_MASK)
SWAP_EN - Swap Data Enable 0b0..Disable 0b1..Enable
◆ XECC_ECC_CTRL_SWAP_EN [2/2]
◆ XECC_ECC_CTRL_WECC_EN [1/2]
#define XECC_ECC_CTRL_WECC_EN (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ECC_CTRL_WECC_EN_SHIFT)) & XECC_ECC_CTRL_WECC_EN_MASK)
WECC_EN - Write ECC Encode Function Enable 0b0..Disable 0b1..Enable
◆ XECC_ECC_CTRL_WECC_EN [2/2]
◆ XECC_ECC_END_ADDR0_ECC_END_ADDR0 [1/2]
#define XECC_ECC_END_ADDR0_ECC_END_ADDR0 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ECC_END_ADDR0_ECC_END_ADDR0_SHIFT)) & XECC_ECC_END_ADDR0_ECC_END_ADDR0_MASK)
◆ XECC_ECC_END_ADDR0_ECC_END_ADDR0 [2/2]
◆ XECC_ECC_END_ADDR1_ECC_END_ADDR1 [1/2]
#define XECC_ECC_END_ADDR1_ECC_END_ADDR1 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ECC_END_ADDR1_ECC_END_ADDR1_SHIFT)) & XECC_ECC_END_ADDR1_ECC_END_ADDR1_MASK)
◆ XECC_ECC_END_ADDR1_ECC_END_ADDR1 [2/2]
◆ XECC_ECC_END_ADDR2_ECC_END_ADDR2 [1/2]
#define XECC_ECC_END_ADDR2_ECC_END_ADDR2 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ECC_END_ADDR2_ECC_END_ADDR2_SHIFT)) & XECC_ECC_END_ADDR2_ECC_END_ADDR2_MASK)
◆ XECC_ECC_END_ADDR2_ECC_END_ADDR2 [2/2]
◆ XECC_ECC_END_ADDR3_ECC_END_ADDR3 [1/2]
#define XECC_ECC_END_ADDR3_ECC_END_ADDR3 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ECC_END_ADDR3_ECC_END_ADDR3_SHIFT)) & XECC_ECC_END_ADDR3_ECC_END_ADDR3_MASK)
◆ XECC_ECC_END_ADDR3_ECC_END_ADDR3 [2/2]
◆ XECC_ERR_DATA_INJ_ERR_DATA_INJ [1/2]
#define XECC_ERR_DATA_INJ_ERR_DATA_INJ (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ERR_DATA_INJ_ERR_DATA_INJ_SHIFT)) & XECC_ERR_DATA_INJ_ERR_DATA_INJ_MASK)
◆ XECC_ERR_DATA_INJ_ERR_DATA_INJ [2/2]
◆ XECC_ERR_ECC_INJ_ERR_ECC_INJ [1/2]
#define XECC_ERR_ECC_INJ_ERR_ECC_INJ (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ERR_ECC_INJ_ERR_ECC_INJ_SHIFT)) & XECC_ERR_ECC_INJ_ERR_ECC_INJ_MASK)
◆ XECC_ERR_ECC_INJ_ERR_ECC_INJ [2/2]
◆ XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN [1/2]
#define XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN_SHIFT)) & XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN_MASK)
MULTI_ERR_SIG_EN - Multiple Bits Error Interrupt Enable 0b0..Masked 0b1..Enabled
◆ XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN [2/2]
◆ XECC_ERR_SIG_EN_Reserved1 [1/2]
#define XECC_ERR_SIG_EN_Reserved1 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ERR_SIG_EN_Reserved1_SHIFT)) & XECC_ERR_SIG_EN_Reserved1_MASK)
Reserved1 - Reserved
◆ XECC_ERR_SIG_EN_Reserved1 [2/2]
◆ XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN [1/2]
#define XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN_SHIFT)) & XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN_MASK)
SINGLE_ERR_SIG_EN - Single Bit Error Interrupt Enable 0b0..Masked 0b1..Enabled
◆ XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN [2/2]
◆ XECC_ERR_STAT_EN_MULIT_ERR_STAT_EN [1/2]
#define XECC_ERR_STAT_EN_MULIT_ERR_STAT_EN (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ERR_STAT_EN_MULIT_ERR_STAT_EN_SHIFT)) & XECC_ERR_STAT_EN_MULIT_ERR_STAT_EN_MASK)
MULIT_ERR_STAT_EN - Multiple Bits Error Status Enable 0b0..Masked 0b1..Enabled
◆ XECC_ERR_STAT_EN_MULIT_ERR_STAT_EN [2/2]
◆ XECC_ERR_STAT_EN_Reserved1 [1/2]
#define XECC_ERR_STAT_EN_Reserved1 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ERR_STAT_EN_Reserved1_SHIFT)) & XECC_ERR_STAT_EN_Reserved1_MASK)
◆ XECC_ERR_STAT_EN_Reserved1 [2/2]
◆ XECC_ERR_STAT_EN_SINGLE_ERR_STAT_EN [1/2]
#define XECC_ERR_STAT_EN_SINGLE_ERR_STAT_EN (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ERR_STAT_EN_SINGLE_ERR_STAT_EN_SHIFT)) & XECC_ERR_STAT_EN_SINGLE_ERR_STAT_EN_MASK)
SINGLE_ERR_STAT_EN - Single Bit Error Status Enable 0b0..Masked 0b1..Enabled
◆ XECC_ERR_STAT_EN_SINGLE_ERR_STAT_EN [2/2]
◆ XECC_ERR_STATUS_MULTI_ERR [1/2]
#define XECC_ERR_STATUS_MULTI_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ERR_STATUS_MULTI_ERR_SHIFT)) & XECC_ERR_STATUS_MULTI_ERR_MASK)
MULTI_ERR - Multiple Bits Error 0b0..Multiple bits error does not happen. 0b1..Multiple bits error happens.
◆ XECC_ERR_STATUS_MULTI_ERR [2/2]
◆ XECC_ERR_STATUS_Reserved1 [1/2]
#define XECC_ERR_STATUS_Reserved1 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ERR_STATUS_Reserved1_SHIFT)) & XECC_ERR_STATUS_Reserved1_MASK)
◆ XECC_ERR_STATUS_Reserved1 [2/2]
◆ XECC_ERR_STATUS_SINGLE_ERR [1/2]
#define XECC_ERR_STATUS_SINGLE_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_ERR_STATUS_SINGLE_ERR_SHIFT)) & XECC_ERR_STATUS_SINGLE_ERR_MASK)
SINGLE_ERR - Single Bit Error 0b0..Single bit error does not happen. 0b1..Single bit error happens.
◆ XECC_ERR_STATUS_SINGLE_ERR [2/2]
◆ XECC_MULTI_ERR_ADDR_MULTI_ERR_ADDR [1/2]
#define XECC_MULTI_ERR_ADDR_MULTI_ERR_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_MULTI_ERR_ADDR_MULTI_ERR_ADDR_SHIFT)) & XECC_MULTI_ERR_ADDR_MULTI_ERR_ADDR_MASK)
◆ XECC_MULTI_ERR_ADDR_MULTI_ERR_ADDR [2/2]
◆ XECC_MULTI_ERR_BIT_FIELD_MULTI_ERR_BIT_FIELD [1/2]
#define XECC_MULTI_ERR_BIT_FIELD_MULTI_ERR_BIT_FIELD (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_MULTI_ERR_BIT_FIELD_MULTI_ERR_BIT_FIELD_SHIFT)) & XECC_MULTI_ERR_BIT_FIELD_MULTI_ERR_BIT_FIELD_MASK)
◆ XECC_MULTI_ERR_BIT_FIELD_MULTI_ERR_BIT_FIELD [2/2]
◆ XECC_MULTI_ERR_BIT_FIELD_Reserved1 [1/2]
#define XECC_MULTI_ERR_BIT_FIELD_Reserved1 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_MULTI_ERR_BIT_FIELD_Reserved1_SHIFT)) & XECC_MULTI_ERR_BIT_FIELD_Reserved1_MASK)
◆ XECC_MULTI_ERR_BIT_FIELD_Reserved1 [2/2]
◆ XECC_MULTI_ERR_DATA_MULTI_ERR_DATA [1/2]
#define XECC_MULTI_ERR_DATA_MULTI_ERR_DATA (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_MULTI_ERR_DATA_MULTI_ERR_DATA_SHIFT)) & XECC_MULTI_ERR_DATA_MULTI_ERR_DATA_MASK)
◆ XECC_MULTI_ERR_DATA_MULTI_ERR_DATA [2/2]
◆ XECC_MULTI_ERR_ECC_MULTI_ERR_ECC [1/2]
#define XECC_MULTI_ERR_ECC_MULTI_ERR_ECC (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_MULTI_ERR_ECC_MULTI_ERR_ECC_SHIFT)) & XECC_MULTI_ERR_ECC_MULTI_ERR_ECC_MASK)
◆ XECC_MULTI_ERR_ECC_MULTI_ERR_ECC [2/2]
◆ XECC_SINGLE_ERR_ADDR_SINGLE_ERR_ADDR [1/2]
#define XECC_SINGLE_ERR_ADDR_SINGLE_ERR_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_SINGLE_ERR_ADDR_SINGLE_ERR_ADDR_SHIFT)) & XECC_SINGLE_ERR_ADDR_SINGLE_ERR_ADDR_MASK)
◆ XECC_SINGLE_ERR_ADDR_SINGLE_ERR_ADDR [2/2]
◆ XECC_SINGLE_ERR_BIT_FIELD_Reserved1 [1/2]
#define XECC_SINGLE_ERR_BIT_FIELD_Reserved1 (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_SINGLE_ERR_BIT_FIELD_Reserved1_SHIFT)) & XECC_SINGLE_ERR_BIT_FIELD_Reserved1_MASK)
◆ XECC_SINGLE_ERR_BIT_FIELD_Reserved1 [2/2]
◆ XECC_SINGLE_ERR_BIT_FIELD_SINGLE_ERR_BIT_FIELD [1/2]
#define XECC_SINGLE_ERR_BIT_FIELD_SINGLE_ERR_BIT_FIELD (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_SINGLE_ERR_BIT_FIELD_SINGLE_ERR_BIT_FIELD_SHIFT)) & XECC_SINGLE_ERR_BIT_FIELD_SINGLE_ERR_BIT_FIELD_MASK)
◆ XECC_SINGLE_ERR_BIT_FIELD_SINGLE_ERR_BIT_FIELD [2/2]
◆ XECC_SINGLE_ERR_DATA_SINGLE_ERR_DATA [1/2]
#define XECC_SINGLE_ERR_DATA_SINGLE_ERR_DATA (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_SINGLE_ERR_DATA_SINGLE_ERR_DATA_SHIFT)) & XECC_SINGLE_ERR_DATA_SINGLE_ERR_DATA_MASK)
◆ XECC_SINGLE_ERR_DATA_SINGLE_ERR_DATA [2/2]
◆ XECC_SINGLE_ERR_ECC_SINGLE_ERR_ECC [1/2]
#define XECC_SINGLE_ERR_ECC_SINGLE_ERR_ECC (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_SINGLE_ERR_ECC_SINGLE_ERR_ECC_SHIFT)) & XECC_SINGLE_ERR_ECC_SINGLE_ERR_ECC_MASK)
SINGLE_ERR_ECC - Single Error ECC code
◆ XECC_SINGLE_ERR_ECC_SINGLE_ERR_ECC [2/2]
◆ XECC_SINGLE_ERR_POS_SINGLE_ERR_POS [1/2]
#define XECC_SINGLE_ERR_POS_SINGLE_ERR_POS (   x)    (((uint32_t)(((uint32_t)(x)) << XECC_SINGLE_ERR_POS_SINGLE_ERR_POS_SHIFT)) & XECC_SINGLE_ERR_POS_SINGLE_ERR_POS_MASK)
SINGLE_ERR_POS - Single Error bit Position
◆ XECC_SINGLE_ERR_POS_SINGLE_ERR_POS [2/2]
