file | __assert.c |
| Evaluate Assertion.
file | __getpid.c |
| Get Process Id.
file | __gettod.c |
| Get the Date and Time.
file | __times.c |
| Get Process Times.
file | __usrenv.c |
| RTEMS File System Location Support.
file | _calloc_r.c |
| Allocate Space for Array in Memory.
file | _free_r.c |
| Allocate and Free Dynamic Memory.
file | _realloc_r.c |
| _realloc_r Implementation
file | _rename_r.c |
| Rename a File.
file | access.c |
| access() - POSIX 1003.1b 5.6.3 - File Accessibility
file | assoclocalbyname.c |
| RTEMS Associate Local by Name.
file | assoclocalbyremote.c |
| RTEMS Associate Local by Remote.
file | assoclocalbyremotebitfield.c |
| RTEMS Associate Local by Remote Bitfield.
file | assocnamebad.c |
| RTEMS Associate Bad Name.
file | assocnamebylocal.c |
| RTEMS Associate Name by Local.
file | assocnamebylocalbitfield.c |
| RTEMS Associate Name by Local Bitfield.
file | assocnamebyremote.c |
| RTEMS Associate Name by Remote.
file | assocnamebyremotebitfield.c |
| RTEMS Associate Name by Remote Bitfield.
file | assocptrbylocal.c |
| RTEMS Associate Pointer by Local.
file | assocptrbyname.c |
| RTEMS Associate Pointer by Name.
file | assocptrbyremote.c |
| RTEMS Associate Pointer by Remote.
file | assocremotebylocal.c |
| RTEMS Associate Remote by Local.
file | assocremotebylocalbitfield.c |
| RTEMS Assoc Routines.
file | assocremotebyname.c |
| RTEMS Associate Remote by Name.
file | base_fs.c |
| Base File System Initialization.
file | cachealignedalloc.c |
| RTEMS Cache Aligned Malloc.
file | cachecoherentalloc.c |
file | calloc.c |
file | cfgetispeed.c |
| Baud Rate Functions.
file | cfgetospeed.c |
file | cfsetispeed.c |
file | cfsetospeed.c |
file | chdir.c |
| POSIX 1003.1b - 5.2.1 - Change Current Working Directory.
file | chmod.c |
| Change File Modes.
file | chown.c |
| Change Owner and Group of a File.
file | chroot.c |
| Change Root Directory.
file | clonenode.c |
| Clones a Node.
file | close.c |
| POSIX 1003.1b 6.3.1 - Close a File.
file | consolesimple.h [code] |
file | ctermid.c |
| Generate Terminal Pathname.
file | dup.c |
| POSIX 1003.1b 6.2.1 Duplicate an Open File Descriptor.
file | dup2.c |
file | error.c |
file | fchdir.c |
| Change Directory.
file | fchmod.c |
| Change File Modes.
file | fchown.c |
file | fcntl.c |
| POSIX 1003.1b 6.5.2 - File Control.
file | fdatasync.c |
| POSIX 1003.1b 6.6.2 - Synchronize the Data of a File.
file | flockfile.c |
| Lock File for Stdio.
file | fpathconf.c |
| Configurable Pathname Varables.
file | free.c |
| calloc()
file | freenode.c |
| Releases all Resources of a Location.
file | fsync.c |
| Synchronize the State of a File.
file | ftruncate.c |
| Truncate a File to the Specified Length.
file | funlockfile.c |
| Unlock File for Stdio.
file | futimens.c |
| Set file access and modification times based on file descriptor in nanoseconds.
file | gcovfork.c |
| This source file contains functions required by GCC if code and branch coverage instrumentation (gcov) is enabled.
file | getchark.c |
| This source file contains the implementation of getchark().
file | getdents.c |
| Get Directory Entries.
file | getegid.c |
| Get Real User, Effective User, Ral Group, and Effective Group IDs.
file | geteuid.c |
file | getgid.c |
file | getgrent.c |
| User Database Access Routines.
file | getgrnam.c |
file | getgroups.c |
| Get Supplementary IDs.
file | getlogin.c |
| Get User Name.
file | getpagesize.c |
| Get System Page Size.
file | getpgrp.c |
| Get process group IDs.
file | getpid.c |
| Process and Parent Process IDs.
file | getppid.c |
| Get Process and Parent Process IDs.
file | getpwent.c |
file | getuid.c |
file | ioctl.c |
| ioctl() system call
file | isatty_r.c |
| Test for a Terminal Device.
file | issetugid.c |
| Dummy Version of BSD Routine.
file | kill_noposix.c |
| Kill No POSIX.
file | libio.c |
| File Descriptor Routines.
file | libio_exit.c |
file | libio_init.c |
| RTEMS LibIO Initialization.
file | libiozeroiops.c |
| This source file provides rtems_libio_iops and rtems_libio_number_iops for a zero file descriptor application configuration.
file | link.c |
| Create a new link.
file | lseek.c |
| lseek() - POSIX 1003.1b 6.5.3 - Reposition Read/Write File Offset
file | lstat.c |
| Get File Status.
file | malloc.c |
| RTEMS Malloc Family Implementation.
file | malloc_deferred.c |
| Malloc Deferred Support.
file | malloc_dirtier.c |
| Dirty Memory Function.
file | malloc_p.h [code] |
| This header file provides interfaces used by the memory allocator implementation.
file | malloc_walk.c |
| Malloc Walk.
file | mallocfreespace.c |
| RTEMS Malloc Get Free Information.
file | mallocgetheapptr.c |
| RTEMS Malloc Get Heap Pointer.
file | mallocheap.c |
| This source file provides the C Program Heap control along with the system initialization handler.
file | mallocinfo.c |
| RTEMS Malloc Get Status Information.
file | mallocsetheapptr.c |
| RTEMS Malloc Set Heap Pointer.
file | mkdir.c |
| Make a Directory.
file | mkfifo.c |
| Make a FIFO Special File.
file | mknod.c |
| Create a Special or Ordinary File.
file | mount-mktgt.c |
| mount_and_make_target_path() implementation.
file | mount.c |
| Mounts a File System.
file | newlibc_reent.c |
| Newlib Support.
file | open.c |
| Open a File.
file | open_dev_console.c |
| open_dev_console - open /dev/console
file | pathconf.c |
file | posix_memalign.c |
file | print_fprintf.c |
| RTEMS Print Support.
file | print_printf.c |
file | printf_plugin.c |
| RTEMS Plugin Printf.
file | printk.c |
| This source file contains the implementation of printk().
file | printk_plugin.c |
| This source file contains the implementation of rtems_printk_printer() and rtems_print_printer_printk().
file | privateenv.c |
| Instantiate a Private User Environment.
file | putk.c |
| This source file contains the implementation of putk().
file | pwdgrp.c |
file | pwdgrp.h [code] |
file | read.c |
| Read From a File.
file | readlink.c |
| Read Value of a Symbolic Link.
file | readv.c |
| Read a Vector.
file | realloc.c |
| Reallocate Memory Block.
file | rmdir.c |
| Remove a Directory.
file | rtems_heap_extend.c |
| rtems_heap_extend() implementation.
file | rtems_heap_extend_via_sbrk.c |
| RTEMS Extend Heap via Sbrk.
file | rtems_heap_greedy.c |
| Greedy Allocate that Empties the Heap.
file | rtems_heap_sbrk_greedy.c |
| Greedy Allocate that Empties the sbrk system call.
file | rtems_memalign.c |
| RTEMS Variation on Aligned Memory Allocation.
file | rtems_mkdir.c |
| rtems_mkdir() implementation.
file | rtems_put_char.c |
| This source file contains the implementation of rtems_put_char().
file | rtems_putc.c |
| This source file contains the implementation of rtems_putc().
file | rtemscalloc.c |
| This source file contains the implementation of rtems_calloc().
file | setegid.c |
file | seteuid.c |
| Set Effective User Id.
file | setgid.c |
| POSIX sets user and group ids.
file | setpgid.c |
| Set Process Group ID for Job Control.
file | setsid.c |
| Create Session and Set Process Group ID.
file | stat.c |
| Get File Status.
file | sup_fs_check_permissions.c |
| RTEMS File System Permissions Check Support.
file | sup_fs_deviceio.c |
| RTEMS DeviceIO Support.
file | sup_fs_eval_path.c |
| RTEMS File Sysyem Path Eval Support.
file | sup_fs_eval_path_generic.c |
| RTEMS File System Eval Generic Path.
file | sup_fs_exist_in_same_instance.c |
| Checks that the Locations Exist in the Same File System Instance.
file | sup_fs_location.c |
file | sup_fs_mount_iterate.c |
| Mount table entry visitor.
file | sup_fs_next_token.c |
| RTEMS File System Eval Eat Delimiter Path.
file | symlink.c |
| Make a Symbolic Link to a File.
file | sync.c |
| This source file contains the implementation of sync().
file | tcdrain.c |
| Line Control Functions.
file | tcflow.c |
file | tcflush.c |
| tcflush() - POSIX 1003.1b 7.2.2 - Line Control Functions
file | tcgetattr.c |
| Get State.
file | tcgetpgrp.c |
| Get Foreground Process Group ID.
file | tcsendbreak.c |
file | tcsetattr.c |
| Get and Set State.
file | tcsetpgrp.c |
| Set Foreground Process Group ID.
file | termios.c |
file | termios_baud2index.c |
| Convert Bxxx Constant to Index.
file | termios_baud2num.c |
| Convert Baud Part of Termios control flags to an integral Baud Value.
file | termios_baudtable.c |
| RTEMS Termios Baud Table.
file | termios_num2baud.c |
| Converts the Integral Baud to Termios Control Flag Representation.
file | termios_posix_isig_handler.c |
file | termios_setinitialbaud.c |
| Sets the Initial Baud in the Termios Context.
file | termiosinitialize.c |
| This source file contains the implementation of rtems_termios_device_lock_acquire_default() and rtems_termios_device_lock_release_default().
file | truncate.c |
file | umask.c |
| Set File Creation Mask.
file | unlink.c |
| Remove an Existing Link.
file | unmount.c |
| Unmount a File System.
file | utime.c |
| Set file access and modification times in seconds.
file | utimensat.c |
| Set file access and modification times in nanoseconds.
file | utimes.c |
| Set file access and modification times in milliseconds.
file | utsname.c |
| Get System Name.
file | vprintk.c |
| This source file contains the implementation of vprintk().
file | write.c |
| Write to a File.
file | write_r.c |
| POSIX 1003.1b 6.4.2 - Write to a File.
file | writev.c |
| writev() - POSIX 1003.1 - Write a Vector
