RTEMS 6.1-rc6
The kernel character input/output support is an extension of the I/O Manager to output characters to the kernel character output device and receive characters from the kernel character input device using a polled and non-blocking implementation. More...
Files | |
file | bspIo.h |
This header file provides the kernel character input/output support API. | |
file | getchark.c |
This source file contains the implementation of getchark(). | |
file | printk.c |
This source file contains the implementation of printk(). | |
file | printk_plugin.c |
This source file contains the implementation of rtems_printk_printer() and rtems_print_printer_printk(). | |
file | putk.c |
This source file contains the implementation of putk(). | |
file | rtems_put_char.c |
This source file contains the implementation of rtems_put_char(). | |
file | rtems_putc.c |
This source file contains the implementation of rtems_putc(). | |
file | vprintk.c |
This source file contains the implementation of vprintk(). | |
void | rtems_putc (char c) |
Outputs the character to the kernel character output device. | |
void | rtems_put_char (int c, void *unused) |
Puts the character using rtems_putc() | |
int | putk (const char *s) |
Outputs the characters of the string and a newline character to the kernel character output device. | |
RTEMS_PRINTFLIKE (1, 2) int printk(const char *fmt | |
Outputs the characters defined by the format string and the arguments to the kernel character output device. | |
int | vprintk (const char *fmt, va_list ap) |
Outputs the characters defined by the format string and the variable argument list to the kernel character output device. | |
int | rtems_printk_printer (void *unused, const char *fmt, va_list ap) |
int | getchark (void) |
Tries to dequeue a character from the kernel character input device. | |
BSP_output_char_function_type | BSP_output_char |
This function pointer references the kernel character output implementation. | |
BSP_polling_getchar_function_type | BSP_poll_char |
This function pointer may reference the kernel character input implementation. | |
The directives may be used to print debug and test information. The kernel character input/output support should work even if no Console Driver is configured, see CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER. The kernel character input and output device is provided by the BSP. Applications may change the device.
int getchark | ( | void | ) |
The directive tries to dequeue a character from the kernel character input device using the polled character input implementation referenced by BSP_poll_char if it is available.
-1 | The BSP_poll_char pointer was equal to NULL. |
-1 | There was no character enqueued on the kernel character input device. |
The following constraints apply to this directive:
int putk | ( | const char * | s | ) |
s | is the string to output. |
The directive may be used to print debug and test information. It uses rtems_putc() to output the characters. This directive performs a character translation from NL
to CR
followed by NR
If the kernel character output device is concurrently accessed, then interleaved output may occur.
Kernel putk (e.g. puts) function requiring minimal infrastrure.
RTEMS_PRINTFLIKE | ( | 1 | , |
2 | |||
) | const |
fmt | is a printf()-style format string. |
... | is a list of optional parameters required by the format string. |
to CR
followed by NR
int rtems_printk_printer | ( | void * | unused, |
const char * | fmt, | ||
va_list | ap | ||
unused | is an unused argument. |
ap | is the variable argument list required by the format string. |
to CR
followed by NR
void rtems_put_char | ( | int | c, |
void * | unused | ||
c | is the character to output. |
void rtems_putc | ( | char | c | ) |
The directive outputs the character specified by c
to the kernel character output device using the polled character output implementation provided by BSP_output_char. The directive performs a character translation from NL
to CR
followed by NR
int vprintk | ( | const char * | fmt, |
va_list | ap | ||
to CR
followed by NR
extern |
This function pointer shall never be NULL. It shall be provided by the BSP and statically initialized. The referenced function shall output exactly the character specified by the parameter. In particular, it shall not perform character translations, for example NL
to CR
followed by NR
. The function shall not block.
extern |
This function pointer may be NULL. It may reference a function provided by the BSP. Referenced functions shall dequeue the least recently received character from the device and return it as an unsigned character. If no character is enqueued on the device, then the function shall immediately return the value minus one.
