RTEMS 6.1-rc5
stackchk.h File Reference
This header file provides the Stack Checker API. More...
#include <rtems/print.h>
struct  rtems_stack_checker_info
 Stack information provided by the stack checker. More...
#define RTEMS_STACK_CHECKER_EXTENSION
 Stack Checker Extension Set Definition.
typedef void(* rtems_stack_checker_visitor) (const rtems_stack_checker_info *info, void *arg)
 Visitor routines invoked by rtems_stack_checker_iterate() shall have this type.
typedef void(* Stack_checker_Reporter_handler) (const rtems_tcb *running, bool pattern_ok)
 The Stack Checker Reporter Initialization Handler.
bool rtems_stack_checker_is_blown (void)
 Checks if current task is blown its stack.
void rtems_stack_checker_report_usage (void)
 Print the stack usage report using printk.
void rtems_stack_checker_report_usage_with_plugin (const rtems_printer *printer)
 Print the stack usage report using caller's routine.
void rtems_stack_checker_iterate (rtems_stack_checker_visitor visit, void *arg)
 Iterates over all stacks used by the system and invokes the visitor routine for each stack.
bool rtems_stack_checker_create_extension (rtems_tcb *running, rtems_tcb *the_thread)
 Stack Checker Task Create Extension.
void rtems_stack_checker_begin_extension (rtems_tcb *executing)
void rtems_stack_checker_switch_extension (rtems_tcb *running, rtems_tcb *heir)
 Stack Checker Task Context Switch Extension.
void rtems_stack_checker_reporter_quiet (const rtems_tcb *running, bool pattern_ok)
 A Quiet Version of Stack Checker Reporter.
void rtems_stack_checker_reporter_print_details (const rtems_tcb *running, bool pattern_ok)
 The Default Function to Report a Blown Stack.
const Stack_checker_Reporter_handler Stack_checker_Reporter
