RTEMS 6.1-rc5
print.h
2
13/*
14 * Copyright (c) 2016 Chris Johns <chrisj@rtems.org>
15 * All rights reserved.
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 */
38
39#ifndef _RTEMS_PRINT_H
40#define _RTEMS_PRINT_H
41
43
44#include <stdarg.h>
45
46#ifdef __cplusplus
47extern "C" {
48#endif
49
50typedef struct rtems_printer rtems_printer;
51
73extern int rtems_printf(const rtems_printer *printer,
74 const char *format,
75 ...) RTEMS_PRINTFLIKE(2, 3);
76
87extern int rtems_vprintf(const rtems_printer *printer,
88 const char *format,
89 va_list ap);
90
93#ifdef __cplusplus
94}
95#endif
96
97#endif /* _RTEMS_PRINT_H */
This header file provides basic definitions used by the API and the implementation.
#define RTEMS_PRINTFLIKE(_format_pos, _ap_pos)
Tells the compiler in a declaration that this function expects printf()-like arguments.
Definition: basedefs.h:772
int rtems_printf(const rtems_printer *printer, const char *format,...) RTEMS_PRINTFLIKE(2
Print to the kernel plugin handler. This has to be a macro because there is no vprint version of the ...
int int rtems_vprintf(const rtems_printer *printer, const char *format, va_list ap)
Definition: print_printf.c:42
Definition: mknod-pack_dev.c:254
Definition: printer.h:76
