RTEMS 6.1-rc5
API
This group contains the Application Programming Interfaces (APIs) of RTEMS. More...
 Application Configuration Information
 The application configuration information group provides an API to get the configuration of an application.
 Application Configuration Options
 Associativity Routines
 BSD Compatibility Support
 Base Definitions
 This group contains basic macros and defines to give access to compiler-specific features.
 CPU Usage Reporting
 The CPU usage reporting directives can be used to report and reset the CPU usage of threads.
 Classic
 This group contains the Classic API managers.
 Dynamic Memory Allocation
 This group contains non-standard interfaces to use dynamic memory allocation.
 Free-Running Counter and Busy Wait Delay
 Free-running counter and busy wait delay functions.
 Hash Algorithms
 This group contains interfaces to hash algorithms.
 IO
 IO.
 Linker Sets
 This group contains the linker sets API.
 Profiling Support
 The profiling support offers functions to report profiling information available in the system.
 RTEMS Application Loader
 RTEMS Runtime Link Editor
 RTEMS Test Framework
 The RTEMS Test Framework helps you to write tests.
 Red-Black Tree Heap
 The red-black tree heap provides a memory allocator using a red-black tree to maintain blocks of memory.
 Self-Contained Objects
 This group contains the self-contained objects API.
 Set Error Number Support
 Status Checks
 System Initialization Support
 The system initialization support provides an ordered invocation of system initialization handlers registered in a linker set.
 System Library
 This group contains the system library APIs of RTEMS.
 Test Support
 Test support functions.
 Tracing
 Tracing.
This group contains the RTEMS Application Programming Interface (API).
