RTEMS 6.1-rc5
Low-level event recording support. More...
Files | |
file | record-fetch.c |
This source file contains the implementation of the record fetching. | |
struct | rtems_record_fetch_control |
This structure controls the record fetching performed by rtems_record_fetch(). More... | |
struct | rtems_record_client_uptime |
struct | rtems_record_client_per_cpu |
struct | rtems_record_client_context |
struct | rtems_record_item_32 |
The 32-bit format record item. More... | |
struct | rtems_record_dump_base64_zlib_context |
The context for record dumps with zlib compression and base64 encoding. More... | |
#define | rtems_record_caller() _Record_Caller( RTEMS_RETURN_ADDRESS() ) |
Generates an RTEMS_RECORD_CALLER and an RTEMS_RECORD_LINE event. | |
#define | rtems_record_caller_3(event, data) _Record_Caller_3( RTEMS_RETURN_ADDRESS(), event, data ) |
Generates an RTEMS_RECORD_CALLER, an RTEMS_RECORD_LINE event, and an extra event. | |
#define | rtems_record_caller_4(event_0, data_0, event_1, data_1) |
Generates an RTEMS_RECORD_CALLER, an RTEMS_RECORD_LINE event, and two extra events. | |
#define | rtems_record_caller_arg(data) _Record_Caller_arg( RTEMS_RETURN_ADDRESS(), data ) |
Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and one argument event. | |
#define | rtems_record_caller_arg_2(data_0, data_1) |
Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and two argument events. | |
#define | rtems_record_caller_arg_3(data_0, data_1, data_2) |
Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and three argument events. | |
#define | rtems_record_caller_arg_4(data_0, data_1, data_2, data_3) |
Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and four argument events. | |
#define | rtems_record_caller_arg_5(data_0, data_1, data_2, data_3, data_4) |
Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and five argument events. | |
#define | rtems_record_caller_arg_6(data_0, data_1, data_2, data_3, data_4, data_5) |
Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and six argument events. | |
#define | rtems_record_caller_arg_7(data_0, data_1, data_2, data_3, data_4, data_5, data_6) |
Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and seven argument events. | |
#define | rtems_record_caller_arg_8(data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7) |
Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and eight argument events. | |
#define | rtems_record_caller_arg_9(data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8) |
Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and nine argument events. | |
#define | rtems_record_caller_arg_10(data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8, data_9) |
Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and ten argument events. | |
#define | rtems_record_entry(event) rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() ) |
Generates the specified entry event. | |
#define | rtems_record_entry_1(event, data) |
Generates the specified entry event and an argument event. | |
#define | rtems_record_entry_2(event, data_0, data_1) _Record_Entry_2( RTEMS_RETURN_ADDRESS(), event, data_0, data_1 ) |
Generates the specified entry event and two argument events. | |
#define | rtems_record_entry_3(event, data_0, data_1, data_2) |
Generates the specified entry event and three argument events. | |
#define | rtems_record_entry_4(event, data_0, data_1, data_2, data_3) |
Generates the specified entry event and four argument events. | |
#define | rtems_record_entry_5(event, data_0, data_1, data_2, data_3, data_4) |
Generates the specified entry event and five argument events. | |
#define | rtems_record_entry_6(event, data_0, data_1, data_2, data_3, data_4, data_5) |
Generates the specified entry event and six argument events. | |
#define | rtems_record_entry_7(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6) |
Generates the specified entry event and seven argument events. | |
#define | rtems_record_entry_8(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7) |
Generates the specified entry event and eight argument events. | |
#define | rtems_record_entry_9(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8) |
Generates the specified entry event and nine argument events. | |
#define | rtems_record_entry_10(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8, data_9) |
Generates the specified entry event and ten argument events. | |
#define | rtems_record_exit(event) rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() ) |
Generates the specified exit event. | |
#define | rtems_record_exit_1(event, data) |
Generates the specified exit event and a return event. | |
#define | rtems_record_exit_2(event, data_0, data_1) _Record_Entry_2( RTEMS_RETURN_ADDRESS(), event, data_0, data_1 ) |
Generates the specified exit event and two argument events. | |
#define | rtems_record_exit_3(event, data_0, data_1, data_2) |
Generates the specified exit event and three argument events. | |
#define | rtems_record_exit_4(event, data_0, data_1, data_2, data_3) |
Generates the specified exit event and four argument events. | |
#define | rtems_record_exit_5(event, data_0, data_1, data_2, data_3, data_4) |
Generates the specified exit event and five argument events. | |
#define | rtems_record_exit_6(event, data_0, data_1, data_2, data_3, data_4, data_5) |
Generates the specified exit event and six argument events. | |
#define | rtems_record_exit_7(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6) |
Generates the specified exit event and seven argument events. | |
#define | rtems_record_exit_8(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7) |
Generates the specified exit event and eight argument events. | |
#define | rtems_record_exit_9(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8) |
Generates the specified exit event and nine argument events. | |
#define | rtems_record_exit_10(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8, data_9) |
Generates the specified exit event and ten argument events. | |
#define | RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT 32 |
#define | RTEMS_RECORD_CLIENT_HOLD_BACK_REALLOCATION_LIMIT 0x100000 |
This constant defines the maximum capacity of the hold back item storage in case a reallocation is necessary. | |
#define | RTEMS_RECORD_THE_VERSION 10 |
The record version. | |
#define | RTEMS_RECORD_FORMAT_LE_32 0x11111111 |
The items are in 32-bit little-endian format. | |
#define | RTEMS_RECORD_FORMAT_LE_64 0x22222222 |
The items are in 64-bit little-endian format. | |
#define | RTEMS_RECORD_FORMAT_BE_32 0x33333333 |
The items are in 32-bit big-endian format. | |
#define | RTEMS_RECORD_FORMAT_BE_64 0x44444444 |
The items are in 64-bit big-endian format. | |
#define | RTEMS_RECORD_MAGIC 0x82e14ec1 |
Magic number to identify a record item stream. | |
#define | RTEMS_RECORD_NO_TIME_LAST RTEMS_RECORD_VERSION_CONTROL_KEY |
This constant represents the last system event number which may have no time stamp. | |
#define | RTEMS_RECORD_LAST RTEMS_RECORD_USER_511 |
#define | RTEMS_RECORD_USER(index) ( RTEMS_RECORD_USER_0 + ( index ) ) |
#define | RTEMS_RECORD_EVENT_BITS 10 |
Bits in the record item event member reserved for the actual event. | |
#define | RTEMS_RECORD_TIME_BITS 22 |
Bits in the record item event member reserved for the time of the event. | |
#define | RTEMS_RECORD_TIME_EVENT(time, event) ( ( ( time ) << RTEMS_RECORD_EVENT_BITS ) | ( event ) ) |
Builds a time event for the specified time stamp and event. | |
#define | RTEMS_RECORD_GET_TIME(time_event) ( ( time_event ) >> RTEMS_RECORD_EVENT_BITS ) |
Gets the time of a time event. | |
#define | RTEMS_RECORD_GET_EVENT(time_event) ( ( time_event ) & ( ( 1U << RTEMS_RECORD_EVENT_BITS ) - 1U ) ) |
Gets the event of a time event. | |
Typedefs | |
typedef rtems_record_client_status(* | rtems_record_client_handler) (uint64_t bt, uint32_t cpu, rtems_record_event event, uint64_t data, void *arg) |
typedef struct rtems_record_client_context | rtems_record_client_context |
typedef unsigned long | rtems_record_data |
The record data integer type. | |
typedef void(* | rtems_record_dump_chunk) (void *arg, const void *data, size_t length) |
Handler for record dumps to output a chunk of data. | |
typedef unsigned short int uint16 | __attribute__((__may_alias__)) = 100 |
The 64-bit format record item. | |
Enumerations | |
enum | rtems_record_fetch_status { RTEMS_RECORD_FETCH_DONE , RTEMS_RECORD_FETCH_CONTINUE , RTEMS_RECORD_FETCH_INVALID_ITEM_COUNT } |
This enumeration provides status codes returned by rtems_record_fetch(). More... | |
enum | rtems_record_client_status { RTEMS_RECORD_CLIENT_SUCCESS , RTEMS_RECORD_CLIENT_ERROR_INVALID_MAGIC , RTEMS_RECORD_CLIENT_ERROR_UNKNOWN_FORMAT , RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_VERSION , RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU , RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU_MAX , RTEMS_RECORD_CLIENT_ERROR_DOUBLE_CPU_MAX , RTEMS_RECORD_CLIENT_ERROR_DOUBLE_PER_CPU_COUNT , RTEMS_RECORD_CLIENT_ERROR_NO_CPU_MAX , RTEMS_RECORD_CLIENT_ERROR_NO_MEMORY , RTEMS_RECORD_CLIENT_ERROR_PER_CPU_ITEMS_OVERFLOW } |
enum | rtems_record_event { RTEMS_RECORD_EMPTY , RTEMS_RECORD_VERSION , RTEMS_RECORD_ARCH , RTEMS_RECORD_BSP , RTEMS_RECORD_FREQUENCY , RTEMS_RECORD_MULTILIB , RTEMS_RECORD_PER_CPU_COUNT , RTEMS_RECORD_PER_CPU_DISCARD , RTEMS_RECORD_PER_CPU_OVERFLOW , RTEMS_RECORD_PROCESSOR , RTEMS_RECORD_PROCESSOR_MAXIMUM , RTEMS_RECORD_THREAD_ID , RTEMS_RECORD_THREAD_NAME , RTEMS_RECORD_TIME_ADJUSTMENT , RTEMS_RECORD_TOOLS , RTEMS_RECORD_UNRELIABLE_TIME , RTEMS_RECORD_VERSION_CONTROL_KEY , RTEMS_RECORD_ACCEPT_ENTRY , RTEMS_RECORD_ACCEPT_EXIT , RTEMS_RECORD_ADDRESS , RTEMS_RECORD_ALIGNED_ALLOC_ENTRY , RTEMS_RECORD_ALIGNED_ALLOC_EXIT , RTEMS_RECORD_ARG_0 , RTEMS_RECORD_ARG_1 , RTEMS_RECORD_ARG_2 , RTEMS_RECORD_ARG_3 , RTEMS_RECORD_ARG_4 , RTEMS_RECORD_ARG_5 , RTEMS_RECORD_ARG_6 , RTEMS_RECORD_ARG_7 , RTEMS_RECORD_ARG_8 , RTEMS_RECORD_ARG_9 , RTEMS_RECORD_BIND_ENTRY , RTEMS_RECORD_BIND_EXIT , RTEMS_RECORD_BUFFER , RTEMS_RECORD_CALLER , RTEMS_RECORD_CALLOC_ENTRY , RTEMS_RECORD_CALLOC_EXIT , RTEMS_RECORD_CHOWN_ENTRY , RTEMS_RECORD_CHOWN_EXIT , RTEMS_RECORD_CLOSE_ENTRY , RTEMS_RECORD_CLOSE_EXIT , RTEMS_RECORD_CONNECT_ENTRY , RTEMS_RECORD_CONNECT_EXIT , RTEMS_RECORD_ETHER_INPUT , RTEMS_RECORD_ETHER_OUTPUT , RTEMS_RECORD_ERRNO , RTEMS_RECORD_FATAL_CODE , RTEMS_RECORD_FATAL_SOURCE , RTEMS_RECORD_FCHMOD_ENTRY , RTEMS_RECORD_FCHMOD_EXIT , RTEMS_RECORD_FCNTL_ENTRY , RTEMS_RECORD_FCNTL_EXIT , RTEMS_RECORD_FDATASYNC_ENTRY , RTEMS_RECORD_FDATASYNC_EXIT , RTEMS_RECORD_FREE_ENTRY , RTEMS_RECORD_FREE_EXIT , RTEMS_RECORD_FSTAT_ENTRY , RTEMS_RECORD_FSTAT_EXIT , RTEMS_RECORD_FSYNC_ENTRY , RTEMS_RECORD_FSYNC_EXIT , RTEMS_RECORD_FTRUNCATE_ENTRY , RTEMS_RECORD_FTRUNCATE_EXIT , RTEMS_RECORD_FUNCTION_ENTRY , RTEMS_RECORD_FUNCTION_EXIT , RTEMS_RECORD_GETSOCKOPT_ENTRY , RTEMS_RECORD_GETSOCKOPT_EXIT , RTEMS_RECORD_HEAP_ALLOC , RTEMS_RECORD_HEAP_FREE , RTEMS_RECORD_HEAP_SIZE , RTEMS_RECORD_HEAP_USAGE , RTEMS_RECORD_INTERRUPT_ENTRY , RTEMS_RECORD_INTERRUPT_EXIT , RTEMS_RECORD_INTERRUPT_INSTALL , RTEMS_RECORD_INTERRUPT_REMOVE , RTEMS_RECORD_INTERRUPT_SERVER_ENTRY , RTEMS_RECORD_INTERRUPT_SERVER_EXIT , RTEMS_RECORD_INTERRUPT_SERVER_INSTALL , RTEMS_RECORD_INTERRUPT_SERVER_MOVE , RTEMS_RECORD_INTERRUPT_SERVER_REMOVE , RTEMS_RECORD_INTERRUPT_SERVER_TRIGGER , RTEMS_RECORD_IOCTL_ENTRY , RTEMS_RECORD_IOCTL_EXIT , RTEMS_RECORD_IP6_INPUT , RTEMS_RECORD_IP6_OUTPUT , RTEMS_RECORD_IP_INPUT , RTEMS_RECORD_IP_OUTPUT , RTEMS_RECORD_ISR_DISABLE , RTEMS_RECORD_ISR_ENABLE , RTEMS_RECORD_ISR_LOCK_ACQUIRE_ENTRY , RTEMS_RECORD_ISR_LOCK_ACQUIRE_EXIT , RTEMS_RECORD_ISR_LOCK_ADDRESS , RTEMS_RECORD_ISR_LOCK_DESTROY , RTEMS_RECORD_ISR_LOCK_INITIALIZE , RTEMS_RECORD_ISR_LOCK_NAME , RTEMS_RECORD_ISR_LOCK_RELEASE , RTEMS_RECORD_KEVENT_ENTRY , RTEMS_RECORD_KEVENT_EXIT , RTEMS_RECORD_KQUEUE_ENTRY , RTEMS_RECORD_KQUEUE_EXIT , RTEMS_RECORD_LENGTH , RTEMS_RECORD_LINE , RTEMS_RECORD_LINK_ENTRY , RTEMS_RECORD_LINK_EXIT , RTEMS_RECORD_LISTEN_ENTRY , RTEMS_RECORD_LISTEN_EXIT , RTEMS_RECORD_LSEEK_ENTRY , RTEMS_RECORD_LSEEK_EXIT , RTEMS_RECORD_MALLOC_ENTRY , RTEMS_RECORD_MALLOC_EXIT , RTEMS_RECORD_MEMORY , RTEMS_RECORD_MKNOD_ENTRY , RTEMS_RECORD_MKNOD_EXIT , RTEMS_RECORD_MMAP_ENTRY , RTEMS_RECORD_MMAP_EXIT , RTEMS_RECORD_MOUNT_ENTRY , RTEMS_RECORD_MOUNT_EXIT , RTEMS_RECORD_OPEN_ENTRY , RTEMS_RECORD_OPEN_EXIT , RTEMS_RECORD_PAGE_ALLOC , RTEMS_RECORD_PAGE_FREE , RTEMS_RECORD_POLL_ENTRY , RTEMS_RECORD_POLL_EXIT , RTEMS_RECORD_POSIX_MEMALIGN_ENTRY , RTEMS_RECORD_POSIX_MEMALIGN_EXIT , RTEMS_RECORD_READ_ENTRY , RTEMS_RECORD_READ_EXIT , RTEMS_RECORD_READLINK_ENTRY , RTEMS_RECORD_READLINK_EXIT , RTEMS_RECORD_READV_ENTRY , RTEMS_RECORD_READV_EXIT , RTEMS_RECORD_REALLOC_ENTRY , RTEMS_RECORD_REALLOC_EXIT , RTEMS_RECORD_RECV_ENTRY , RTEMS_RECORD_RECV_EXIT , RTEMS_RECORD_RECVFROM_ENTRY , RTEMS_RECORD_RECVFROM_EXIT , RTEMS_RECORD_RECVMSG_ENTRY , RTEMS_RECORD_RECVMSG_EXIT , RTEMS_RECORD_REGISTERS , RTEMS_RECORD_RENAME_ENTRY , RTEMS_RECORD_RENAME_EXIT , RTEMS_RECORD_RETURN_0 , RTEMS_RECORD_RETURN_1 , RTEMS_RECORD_RETURN_2 , RTEMS_RECORD_RETURN_3 , RTEMS_RECORD_RETURN_4 , RTEMS_RECORD_RETURN_5 , RTEMS_RECORD_RETURN_6 , RTEMS_RECORD_RETURN_7 , RTEMS_RECORD_RETURN_8 , RTEMS_RECORD_RETURN_9 , RTEMS_RECORD_RTEMS_BARRIER_CREATE , RTEMS_RECORD_RTEMS_BARRIER_DELETE , RTEMS_RECORD_RTEMS_BARRIER_RELEASE , RTEMS_RECORD_RTEMS_BARRIER_WAIT , RTEMS_RECORD_RTEMS_CALLOC_ENTRY , RTEMS_RECORD_RTEMS_CALLOC_EXIT , RTEMS_RECORD_RTEMS_EVENT_RECEIVE , RTEMS_RECORD_RTEMS_EVENT_SEND , RTEMS_RECORD_RTEMS_EVENT_SYSTEM_RECEIVE , RTEMS_RECORD_RTEMS_EVENT_SYSTEM_SEND , RTEMS_RECORD_RTEMS_MALLOC_ENTRY , RTEMS_RECORD_RTEMS_MALLOC_EXIT , RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_BROADCAST , RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_CREATE , RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_DELETE , RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_FLUSH , RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_RECEIVE , RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_SEND , RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_URGENT , RTEMS_RECORD_RTEMS_PARTITION_CREATE , RTEMS_RECORD_RTEMS_PARTITION_DELETE , RTEMS_RECORD_RTEMS_PARTITION_GET_BUFFER , RTEMS_RECORD_RTEMS_PARTITION_RETURN_BUFFER , RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CANCEL , RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CREATE , RTEMS_RECORD_RTEMS_RATE_MONOTONIC_DELETE , RTEMS_RECORD_RTEMS_RATE_MONOTONIC_PERIOD , RTEMS_RECORD_RTEMS_SEMAPHORE_CREATE , RTEMS_RECORD_RTEMS_SEMAPHORE_DELETE , RTEMS_RECORD_RTEMS_SEMAPHORE_FLUSH , RTEMS_RECORD_RTEMS_SEMAPHORE_OBTAIN , RTEMS_RECORD_RTEMS_SEMAPHORE_RELEASE , RTEMS_RECORD_RTEMS_TIMER_CANCEL , RTEMS_RECORD_RTEMS_TIMER_CREATE , RTEMS_RECORD_RTEMS_TIMER_DELETE , RTEMS_RECORD_RTEMS_TIMER_FIRE_AFTER , RTEMS_RECORD_RTEMS_TIMER_FIRE_WHEN , RTEMS_RECORD_RTEMS_TIMER_RESET , RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_AFTER , RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_WHEN , RTEMS_RECORD_SBWAIT_ENTRY , RTEMS_RECORD_SBWAIT_EXIT , RTEMS_RECORD_SBWAKEUP_ENTRY , RTEMS_RECORD_SBWAKEUP_EXIT , RTEMS_RECORD_SCHEDULER_ADD_PROCESSOR , RTEMS_RECORD_SCHEDULER_ASK_FOR_HELP , RTEMS_RECORD_SCHEDULER_BLOCK , RTEMS_RECORD_SCHEDULER_CANCEL_JOB , RTEMS_RECORD_SCHEDULER_ID , RTEMS_RECORD_SCHEDULER_MAP_PRIORITY , RTEMS_RECORD_SCHEDULER_NAME , RTEMS_RECORD_SCHEDULER_PIN , RTEMS_RECORD_SCHEDULER_RECONSIDER_HELP_REQUEST , RTEMS_RECORD_SCHEDULER_RELEASE_JOB , RTEMS_RECORD_SCHEDULER_REMOVE_PROCESSOR , RTEMS_RECORD_SCHEDULER_SCHEDULE , RTEMS_RECORD_SCHEDULER_SET_AFFINITY , RTEMS_RECORD_SCHEDULER_TICK , RTEMS_RECORD_SCHEDULER_UNBLOCK , RTEMS_RECORD_SCHEDULER_UNMAP_PRIORITY , RTEMS_RECORD_SCHEDULER_UNPIN , RTEMS_RECORD_SCHEDULER_UPDATE_PRIORITY , RTEMS_RECORD_SCHEDULER_WITHDRAW_NODE , RTEMS_RECORD_SCHEDULER_YIELD , RTEMS_RECORD_SELECT_ENTRY , RTEMS_RECORD_SELECT_EXIT , RTEMS_RECORD_SEND_ENTRY , RTEMS_RECORD_SEND_EXIT , RTEMS_RECORD_SENDMSG_ENTRY , RTEMS_RECORD_SENDMSG_EXIT , RTEMS_RECORD_SENDTO_ENTRY , RTEMS_RECORD_SENDTO_EXIT , RTEMS_RECORD_SETSOCKOPT_ENTRY , RTEMS_RECORD_SETSOCKOPT_EXIT , RTEMS_RECORD_SHUTDOWN_ENTRY , RTEMS_RECORD_SHUTDOWN_EXIT , RTEMS_RECORD_SOABORT_ENTRY , RTEMS_RECORD_SOABORT_EXIT , RTEMS_RECORD_SOACCEPT_ENTRY , RTEMS_RECORD_SOACCEPT_EXIT , RTEMS_RECORD_SOALLOC_ENTRY , RTEMS_RECORD_SOALLOC_EXIT , RTEMS_RECORD_SOBINDAT_ENTRY , RTEMS_RECORD_SOBINDAT_EXIT , RTEMS_RECORD_SOBIND_ENTRY , RTEMS_RECORD_SOBIND_EXIT , RTEMS_RECORD_SOCKET_ENTRY , RTEMS_RECORD_SOCKET_EXIT , RTEMS_RECORD_SOCLOSE_ENTRY , RTEMS_RECORD_SOCLOSE_EXIT , RTEMS_RECORD_SOCONNECT2_ENTRY , RTEMS_RECORD_SOCONNECT2_EXIT , RTEMS_RECORD_SOCONNECTAT_ENTRY , RTEMS_RECORD_SOCONNECTAT_EXIT , RTEMS_RECORD_SOCREATE_ENTRY , RTEMS_RECORD_SOCREATE_EXIT , RTEMS_RECORD_SODEALLOC_ENTRY , RTEMS_RECORD_SODEALLOC_EXIT , RTEMS_RECORD_SODISCONNECT_ENTRY , RTEMS_RECORD_SODISCONNECT_EXIT , RTEMS_RECORD_SOFREE_ENTRY , RTEMS_RECORD_SOFREE_EXIT , RTEMS_RECORD_SOLISTEN_ENTRY , RTEMS_RECORD_SOLISTEN_EXIT , RTEMS_RECORD_SONEWCONN_ENTRY , RTEMS_RECORD_SONEWCONN_EXIT , RTEMS_RECORD_SORECEIVE_ENTRY , RTEMS_RECORD_SORECEIVE_EXIT , RTEMS_RECORD_SORFLUSH_ENTRY , RTEMS_RECORD_SORFLUSH_EXIT , RTEMS_RECORD_SOSEND_ENTRY , RTEMS_RECORD_SOSEND_EXIT , RTEMS_RECORD_SOSHUTDOWN_ENTRY , RTEMS_RECORD_SOSHUTDOWN_EXIT , RTEMS_RECORD_STATVFS_ENTRY , RTEMS_RECORD_STATVFS_EXIT , RTEMS_RECORD_SYMLINK_ENTRY , RTEMS_RECORD_SYMLINK_EXIT , RTEMS_RECORD_TCP_CLOSE , RTEMS_RECORD_TCP_INPUT , RTEMS_RECORD_TCP_OUTPUT , RTEMS_RECORD_THREAD_BEGIN , RTEMS_RECORD_THREAD_CONTINUE_ENTRY , RTEMS_RECORD_THREAD_CONTINUE_EXIT , RTEMS_RECORD_THREAD_CREATE , RTEMS_RECORD_THREAD_DELETE , RTEMS_RECORD_THREAD_DISPATCH_DISABLE , RTEMS_RECORD_THREAD_DISPATCH_ENABLE , RTEMS_RECORD_THREAD_EXIT , RTEMS_RECORD_THREAD_EXITTED , RTEMS_RECORD_THREAD_PRIO_CURRENT_HIGH , RTEMS_RECORD_THREAD_PRIO_CURRENT_LOW , RTEMS_RECORD_THREAD_PRIO_REAL_HIGH , RTEMS_RECORD_THREAD_PRIO_REAL_LOW , RTEMS_RECORD_THREAD_QUEUE_ADDRESS , RTEMS_RECORD_THREAD_QUEUE_DESTROY , RTEMS_RECORD_THREAD_QUEUE_ENQUEUE , RTEMS_RECORD_THREAD_QUEUE_ENQUEUE_STICKY , RTEMS_RECORD_THREAD_QUEUE_EXTRACT , RTEMS_RECORD_THREAD_QUEUE_ID , RTEMS_RECORD_THREAD_QUEUE_INITIALIZE , RTEMS_RECORD_THREAD_QUEUE_NAME , RTEMS_RECORD_THREAD_QUEUE_SURRENDER , RTEMS_RECORD_THREAD_QUEUE_SURRENDER_STICKY , RTEMS_RECORD_THREAD_RESOURCE_OBTAIN , RTEMS_RECORD_THREAD_RESOURCE_RELEASE , RTEMS_RECORD_THREAD_RESTART , RTEMS_RECORD_THREAD_STACK_CURRENT , RTEMS_RECORD_THREAD_STACK_SIZE , RTEMS_RECORD_THREAD_STACK_USAGE , RTEMS_RECORD_THREAD_START , RTEMS_RECORD_THREAD_STATE_CLEAR , RTEMS_RECORD_THREAD_STATE_SET , RTEMS_RECORD_THREAD_SWITCH_IN , RTEMS_RECORD_THREAD_SWITCH_OUT , RTEMS_RECORD_THREAD_TERMINATE , RTEMS_RECORD_THREAD_TIMER_INSERT_MONOTONIC , RTEMS_RECORD_THREAD_TIMER_INSERT_REALTIME , RTEMS_RECORD_THREAD_TIMER_INSERT_TICKS , RTEMS_RECORD_THREAD_TIMER_REMOVE , RTEMS_RECORD_UDP_INPUT , RTEMS_RECORD_UDP_OUTPUT , RTEMS_RECORD_UMA_ALLOC_PTR , RTEMS_RECORD_UMA_ALLOC_ZONE , RTEMS_RECORD_UMA_FREE_PTR , RTEMS_RECORD_UMA_FREE_ZONE , RTEMS_RECORD_UNLINK_ENTRY , RTEMS_RECORD_UNLINK_EXIT , RTEMS_RECORD_UNMOUNT_ENTRY , RTEMS_RECORD_UNMOUNT_EXIT , RTEMS_RECORD_UPTIME_HIGH , RTEMS_RECORD_UPTIME_LOW , RTEMS_RECORD_WATCHDOG_ADDRESS , RTEMS_RECORD_WATCHDOG_CPU , RTEMS_RECORD_WATCHDOG_INITIALIZE , RTEMS_RECORD_WATCHDOG_INSERT , RTEMS_RECORD_WATCHDOG_PREINITIALIZE , RTEMS_RECORD_WATCHDOG_REMOVE , RTEMS_RECORD_WATCHDOG_ROUTINE , RTEMS_RECORD_WATCHDOG_STATE , RTEMS_RECORD_WORKSPACE_ALLOC_ENTRY , RTEMS_RECORD_WORKSPACE_ALLOC_EXIT , RTEMS_RECORD_WORKSPACE_FREE_ENTY , RTEMS_RECORD_WORKSPACE_FREE_EXIT , RTEMS_RECORD_WORKSPACE_SIZE , RTEMS_RECORD_WORKSPACE_USAGE , RTEMS_RECORD_WRITE_ENTRY , RTEMS_RECORD_WRITE_EXIT , RTEMS_RECORD_WRITEV_ENTRY , RTEMS_RECORD_WRITEV_EXIT , RTEMS_RECORD_SYSTEM_342 , RTEMS_RECORD_SYSTEM_343 , RTEMS_RECORD_SYSTEM_344 , RTEMS_RECORD_SYSTEM_345 , RTEMS_RECORD_SYSTEM_346 , RTEMS_RECORD_SYSTEM_347 , RTEMS_RECORD_SYSTEM_348 , RTEMS_RECORD_SYSTEM_349 , RTEMS_RECORD_SYSTEM_350 , RTEMS_RECORD_SYSTEM_351 , RTEMS_RECORD_SYSTEM_352 , RTEMS_RECORD_SYSTEM_353 , RTEMS_RECORD_SYSTEM_354 , RTEMS_RECORD_SYSTEM_355 , RTEMS_RECORD_SYSTEM_356 , RTEMS_RECORD_SYSTEM_357 , RTEMS_RECORD_SYSTEM_358 , RTEMS_RECORD_SYSTEM_359 , RTEMS_RECORD_SYSTEM_360 , RTEMS_RECORD_SYSTEM_361 , RTEMS_RECORD_SYSTEM_362 , RTEMS_RECORD_SYSTEM_363 , RTEMS_RECORD_SYSTEM_364 , RTEMS_RECORD_SYSTEM_365 , RTEMS_RECORD_SYSTEM_366 , RTEMS_RECORD_SYSTEM_367 , RTEMS_RECORD_SYSTEM_368 , RTEMS_RECORD_SYSTEM_369 , RTEMS_RECORD_SYSTEM_370 , RTEMS_RECORD_SYSTEM_371 , RTEMS_RECORD_SYSTEM_372 , RTEMS_RECORD_SYSTEM_373 , RTEMS_RECORD_SYSTEM_374 , RTEMS_RECORD_SYSTEM_375 , RTEMS_RECORD_SYSTEM_376 , RTEMS_RECORD_SYSTEM_377 , RTEMS_RECORD_SYSTEM_378 , RTEMS_RECORD_SYSTEM_379 , RTEMS_RECORD_SYSTEM_380 , RTEMS_RECORD_SYSTEM_381 , RTEMS_RECORD_SYSTEM_382 , RTEMS_RECORD_SYSTEM_383 , RTEMS_RECORD_SYSTEM_384 , RTEMS_RECORD_SYSTEM_385 , RTEMS_RECORD_SYSTEM_386 , RTEMS_RECORD_SYSTEM_387 , RTEMS_RECORD_SYSTEM_388 , RTEMS_RECORD_SYSTEM_389 , RTEMS_RECORD_SYSTEM_390 , RTEMS_RECORD_SYSTEM_391 , RTEMS_RECORD_SYSTEM_392 , RTEMS_RECORD_SYSTEM_393 , RTEMS_RECORD_SYSTEM_394 , RTEMS_RECORD_SYSTEM_395 , RTEMS_RECORD_SYSTEM_396 , RTEMS_RECORD_SYSTEM_397 , RTEMS_RECORD_SYSTEM_398 , RTEMS_RECORD_SYSTEM_399 , RTEMS_RECORD_SYSTEM_400 , RTEMS_RECORD_SYSTEM_401 , RTEMS_RECORD_SYSTEM_402 , RTEMS_RECORD_SYSTEM_403 , RTEMS_RECORD_SYSTEM_404 , RTEMS_RECORD_SYSTEM_405 , RTEMS_RECORD_SYSTEM_406 , RTEMS_RECORD_SYSTEM_407 , RTEMS_RECORD_SYSTEM_408 , RTEMS_RECORD_SYSTEM_409 , RTEMS_RECORD_SYSTEM_410 , RTEMS_RECORD_SYSTEM_411 , RTEMS_RECORD_SYSTEM_412 , RTEMS_RECORD_SYSTEM_413 , RTEMS_RECORD_SYSTEM_414 , RTEMS_RECORD_SYSTEM_415 , RTEMS_RECORD_SYSTEM_416 , RTEMS_RECORD_SYSTEM_417 , RTEMS_RECORD_SYSTEM_418 , RTEMS_RECORD_SYSTEM_419 , RTEMS_RECORD_SYSTEM_420 , RTEMS_RECORD_SYSTEM_421 , RTEMS_RECORD_SYSTEM_422 , RTEMS_RECORD_SYSTEM_423 , RTEMS_RECORD_SYSTEM_424 , RTEMS_RECORD_SYSTEM_425 , RTEMS_RECORD_SYSTEM_426 , RTEMS_RECORD_SYSTEM_427 , RTEMS_RECORD_SYSTEM_428 , RTEMS_RECORD_SYSTEM_429 , RTEMS_RECORD_SYSTEM_430 , RTEMS_RECORD_SYSTEM_431 , RTEMS_RECORD_SYSTEM_432 , RTEMS_RECORD_SYSTEM_433 , RTEMS_RECORD_SYSTEM_434 , RTEMS_RECORD_SYSTEM_435 , RTEMS_RECORD_SYSTEM_436 , RTEMS_RECORD_SYSTEM_437 , RTEMS_RECORD_SYSTEM_438 , RTEMS_RECORD_SYSTEM_439 , RTEMS_RECORD_SYSTEM_440 , RTEMS_RECORD_SYSTEM_441 , RTEMS_RECORD_SYSTEM_442 , RTEMS_RECORD_SYSTEM_443 , RTEMS_RECORD_SYSTEM_444 , RTEMS_RECORD_SYSTEM_445 , RTEMS_RECORD_SYSTEM_446 , RTEMS_RECORD_SYSTEM_447 , RTEMS_RECORD_SYSTEM_448 , RTEMS_RECORD_SYSTEM_449 , RTEMS_RECORD_SYSTEM_450 , RTEMS_RECORD_SYSTEM_451 , RTEMS_RECORD_SYSTEM_452 , RTEMS_RECORD_SYSTEM_453 , RTEMS_RECORD_SYSTEM_454 , RTEMS_RECORD_SYSTEM_455 , RTEMS_RECORD_SYSTEM_456 , RTEMS_RECORD_SYSTEM_457 , RTEMS_RECORD_SYSTEM_458 , RTEMS_RECORD_SYSTEM_459 , RTEMS_RECORD_SYSTEM_460 , RTEMS_RECORD_SYSTEM_461 , RTEMS_RECORD_SYSTEM_462 , RTEMS_RECORD_SYSTEM_463 , RTEMS_RECORD_SYSTEM_464 , RTEMS_RECORD_SYSTEM_465 , RTEMS_RECORD_SYSTEM_466 , RTEMS_RECORD_SYSTEM_467 , RTEMS_RECORD_SYSTEM_468 , RTEMS_RECORD_SYSTEM_469 , RTEMS_RECORD_SYSTEM_470 , RTEMS_RECORD_SYSTEM_471 , RTEMS_RECORD_SYSTEM_472 , RTEMS_RECORD_SYSTEM_473 , RTEMS_RECORD_SYSTEM_474 , RTEMS_RECORD_SYSTEM_475 , RTEMS_RECORD_SYSTEM_476 , RTEMS_RECORD_SYSTEM_477 , RTEMS_RECORD_SYSTEM_478 , RTEMS_RECORD_SYSTEM_479 , RTEMS_RECORD_SYSTEM_480 , RTEMS_RECORD_SYSTEM_481 , RTEMS_RECORD_SYSTEM_482 , RTEMS_RECORD_SYSTEM_483 , RTEMS_RECORD_SYSTEM_484 , RTEMS_RECORD_SYSTEM_485 , RTEMS_RECORD_SYSTEM_486 , RTEMS_RECORD_SYSTEM_487 , RTEMS_RECORD_SYSTEM_488 , RTEMS_RECORD_SYSTEM_489 , RTEMS_RECORD_SYSTEM_490 , RTEMS_RECORD_SYSTEM_491 , RTEMS_RECORD_SYSTEM_492 , RTEMS_RECORD_SYSTEM_493 , RTEMS_RECORD_SYSTEM_494 , RTEMS_RECORD_SYSTEM_495 , RTEMS_RECORD_SYSTEM_496 , RTEMS_RECORD_SYSTEM_497 , RTEMS_RECORD_SYSTEM_498 , RTEMS_RECORD_SYSTEM_499 , RTEMS_RECORD_SYSTEM_500 , RTEMS_RECORD_SYSTEM_501 , RTEMS_RECORD_SYSTEM_502 , RTEMS_RECORD_SYSTEM_503 , RTEMS_RECORD_SYSTEM_504 , RTEMS_RECORD_SYSTEM_505 , RTEMS_RECORD_SYSTEM_506 , RTEMS_RECORD_SYSTEM_507 , RTEMS_RECORD_SYSTEM_508 , RTEMS_RECORD_SYSTEM_509 , RTEMS_RECORD_SYSTEM_510 , RTEMS_RECORD_SYSTEM_511 , RTEMS_RECORD_USER_0 , RTEMS_RECORD_USER_1 , RTEMS_RECORD_USER_2 , RTEMS_RECORD_USER_3 , RTEMS_RECORD_USER_4 , RTEMS_RECORD_USER_5 , RTEMS_RECORD_USER_6 , RTEMS_RECORD_USER_7 , RTEMS_RECORD_USER_8 , RTEMS_RECORD_USER_9 , RTEMS_RECORD_USER_10 , RTEMS_RECORD_USER_11 , RTEMS_RECORD_USER_12 , RTEMS_RECORD_USER_13 , RTEMS_RECORD_USER_14 , RTEMS_RECORD_USER_15 , RTEMS_RECORD_USER_16 , RTEMS_RECORD_USER_17 , RTEMS_RECORD_USER_18 , RTEMS_RECORD_USER_19 , RTEMS_RECORD_USER_20 , RTEMS_RECORD_USER_21 , RTEMS_RECORD_USER_22 , RTEMS_RECORD_USER_23 , RTEMS_RECORD_USER_24 , RTEMS_RECORD_USER_25 , RTEMS_RECORD_USER_26 , RTEMS_RECORD_USER_27 , RTEMS_RECORD_USER_28 , RTEMS_RECORD_USER_29 , RTEMS_RECORD_USER_30 , RTEMS_RECORD_USER_31 , RTEMS_RECORD_USER_32 , RTEMS_RECORD_USER_33 , RTEMS_RECORD_USER_34 , RTEMS_RECORD_USER_35 , RTEMS_RECORD_USER_36 , RTEMS_RECORD_USER_37 , RTEMS_RECORD_USER_38 , RTEMS_RECORD_USER_39 , RTEMS_RECORD_USER_40 , RTEMS_RECORD_USER_41 , RTEMS_RECORD_USER_42 , RTEMS_RECORD_USER_43 , RTEMS_RECORD_USER_44 , RTEMS_RECORD_USER_45 , RTEMS_RECORD_USER_46 , RTEMS_RECORD_USER_47 , RTEMS_RECORD_USER_48 , RTEMS_RECORD_USER_49 , RTEMS_RECORD_USER_50 , RTEMS_RECORD_USER_51 , RTEMS_RECORD_USER_52 , RTEMS_RECORD_USER_53 , RTEMS_RECORD_USER_54 , RTEMS_RECORD_USER_55 , RTEMS_RECORD_USER_56 , RTEMS_RECORD_USER_57 , RTEMS_RECORD_USER_58 , RTEMS_RECORD_USER_59 , RTEMS_RECORD_USER_60 , RTEMS_RECORD_USER_61 , RTEMS_RECORD_USER_62 , RTEMS_RECORD_USER_63 , RTEMS_RECORD_USER_64 , RTEMS_RECORD_USER_65 , RTEMS_RECORD_USER_66 , RTEMS_RECORD_USER_67 , RTEMS_RECORD_USER_68 , RTEMS_RECORD_USER_69 , RTEMS_RECORD_USER_70 , RTEMS_RECORD_USER_71 , RTEMS_RECORD_USER_72 , RTEMS_RECORD_USER_73 , RTEMS_RECORD_USER_74 , RTEMS_RECORD_USER_75 , RTEMS_RECORD_USER_76 , RTEMS_RECORD_USER_77 , RTEMS_RECORD_USER_78 , RTEMS_RECORD_USER_79 , RTEMS_RECORD_USER_80 , RTEMS_RECORD_USER_81 , RTEMS_RECORD_USER_82 , RTEMS_RECORD_USER_83 , RTEMS_RECORD_USER_84 , RTEMS_RECORD_USER_85 , RTEMS_RECORD_USER_86 , RTEMS_RECORD_USER_87 , RTEMS_RECORD_USER_88 , RTEMS_RECORD_USER_89 , RTEMS_RECORD_USER_90 , RTEMS_RECORD_USER_91 , RTEMS_RECORD_USER_92 , RTEMS_RECORD_USER_93 , RTEMS_RECORD_USER_94 , RTEMS_RECORD_USER_95 , RTEMS_RECORD_USER_96 , RTEMS_RECORD_USER_97 , RTEMS_RECORD_USER_98 , RTEMS_RECORD_USER_99 , RTEMS_RECORD_USER_100 , RTEMS_RECORD_USER_101 , RTEMS_RECORD_USER_102 , RTEMS_RECORD_USER_103 , RTEMS_RECORD_USER_104 , RTEMS_RECORD_USER_105 , RTEMS_RECORD_USER_106 , RTEMS_RECORD_USER_107 , RTEMS_RECORD_USER_108 , RTEMS_RECORD_USER_109 , RTEMS_RECORD_USER_110 , RTEMS_RECORD_USER_111 , RTEMS_RECORD_USER_112 , RTEMS_RECORD_USER_113 , RTEMS_RECORD_USER_114 , RTEMS_RECORD_USER_115 , RTEMS_RECORD_USER_116 , RTEMS_RECORD_USER_117 , RTEMS_RECORD_USER_118 , RTEMS_RECORD_USER_119 , RTEMS_RECORD_USER_120 , RTEMS_RECORD_USER_121 , RTEMS_RECORD_USER_122 , RTEMS_RECORD_USER_123 , RTEMS_RECORD_USER_124 , RTEMS_RECORD_USER_125 , RTEMS_RECORD_USER_126 , RTEMS_RECORD_USER_127 , RTEMS_RECORD_USER_128 , RTEMS_RECORD_USER_129 , RTEMS_RECORD_USER_130 , RTEMS_RECORD_USER_131 , RTEMS_RECORD_USER_132 , RTEMS_RECORD_USER_133 , RTEMS_RECORD_USER_134 , RTEMS_RECORD_USER_135 , RTEMS_RECORD_USER_136 , RTEMS_RECORD_USER_137 , RTEMS_RECORD_USER_138 , RTEMS_RECORD_USER_139 , RTEMS_RECORD_USER_140 , RTEMS_RECORD_USER_141 , RTEMS_RECORD_USER_142 , RTEMS_RECORD_USER_143 , RTEMS_RECORD_USER_144 , RTEMS_RECORD_USER_145 , RTEMS_RECORD_USER_146 , RTEMS_RECORD_USER_147 , RTEMS_RECORD_USER_148 , RTEMS_RECORD_USER_149 , RTEMS_RECORD_USER_150 , RTEMS_RECORD_USER_151 , RTEMS_RECORD_USER_152 , RTEMS_RECORD_USER_153 , RTEMS_RECORD_USER_154 , RTEMS_RECORD_USER_155 , RTEMS_RECORD_USER_156 , RTEMS_RECORD_USER_157 , RTEMS_RECORD_USER_158 , RTEMS_RECORD_USER_159 , RTEMS_RECORD_USER_160 , RTEMS_RECORD_USER_161 , RTEMS_RECORD_USER_162 , RTEMS_RECORD_USER_163 , RTEMS_RECORD_USER_164 , RTEMS_RECORD_USER_165 , RTEMS_RECORD_USER_166 , RTEMS_RECORD_USER_167 , RTEMS_RECORD_USER_168 , RTEMS_RECORD_USER_169 , RTEMS_RECORD_USER_170 , RTEMS_RECORD_USER_171 , RTEMS_RECORD_USER_172 , RTEMS_RECORD_USER_173 , RTEMS_RECORD_USER_174 , RTEMS_RECORD_USER_175 , RTEMS_RECORD_USER_176 , RTEMS_RECORD_USER_177 , RTEMS_RECORD_USER_178 , RTEMS_RECORD_USER_179 , RTEMS_RECORD_USER_180 , RTEMS_RECORD_USER_181 , RTEMS_RECORD_USER_182 , RTEMS_RECORD_USER_183 , RTEMS_RECORD_USER_184 , RTEMS_RECORD_USER_185 , RTEMS_RECORD_USER_186 , RTEMS_RECORD_USER_187 , RTEMS_RECORD_USER_188 , RTEMS_RECORD_USER_189 , RTEMS_RECORD_USER_190 , RTEMS_RECORD_USER_191 , RTEMS_RECORD_USER_192 , RTEMS_RECORD_USER_193 , RTEMS_RECORD_USER_194 , RTEMS_RECORD_USER_195 , RTEMS_RECORD_USER_196 , RTEMS_RECORD_USER_197 , RTEMS_RECORD_USER_198 , RTEMS_RECORD_USER_199 , RTEMS_RECORD_USER_200 , RTEMS_RECORD_USER_201 , RTEMS_RECORD_USER_202 , RTEMS_RECORD_USER_203 , RTEMS_RECORD_USER_204 , RTEMS_RECORD_USER_205 , RTEMS_RECORD_USER_206 , RTEMS_RECORD_USER_207 , RTEMS_RECORD_USER_208 , RTEMS_RECORD_USER_209 , RTEMS_RECORD_USER_210 , RTEMS_RECORD_USER_211 , RTEMS_RECORD_USER_212 , RTEMS_RECORD_USER_213 , RTEMS_RECORD_USER_214 , RTEMS_RECORD_USER_215 , RTEMS_RECORD_USER_216 , RTEMS_RECORD_USER_217 , RTEMS_RECORD_USER_218 , RTEMS_RECORD_USER_219 , RTEMS_RECORD_USER_220 , RTEMS_RECORD_USER_221 , RTEMS_RECORD_USER_222 , RTEMS_RECORD_USER_223 , RTEMS_RECORD_USER_224 , RTEMS_RECORD_USER_225 , RTEMS_RECORD_USER_226 , RTEMS_RECORD_USER_227 , RTEMS_RECORD_USER_228 , RTEMS_RECORD_USER_229 , RTEMS_RECORD_USER_230 , RTEMS_RECORD_USER_231 , RTEMS_RECORD_USER_232 , RTEMS_RECORD_USER_233 , RTEMS_RECORD_USER_234 , RTEMS_RECORD_USER_235 , RTEMS_RECORD_USER_236 , RTEMS_RECORD_USER_237 , RTEMS_RECORD_USER_238 , RTEMS_RECORD_USER_239 , RTEMS_RECORD_USER_240 , RTEMS_RECORD_USER_241 , RTEMS_RECORD_USER_242 , RTEMS_RECORD_USER_243 , RTEMS_RECORD_USER_244 , RTEMS_RECORD_USER_245 , RTEMS_RECORD_USER_246 , RTEMS_RECORD_USER_247 , RTEMS_RECORD_USER_248 , RTEMS_RECORD_USER_249 , RTEMS_RECORD_USER_250 , RTEMS_RECORD_USER_251 , RTEMS_RECORD_USER_252 , RTEMS_RECORD_USER_253 , RTEMS_RECORD_USER_254 , RTEMS_RECORD_USER_255 , RTEMS_RECORD_USER_256 , RTEMS_RECORD_USER_257 , RTEMS_RECORD_USER_258 , RTEMS_RECORD_USER_259 , RTEMS_RECORD_USER_260 , RTEMS_RECORD_USER_261 , RTEMS_RECORD_USER_262 , RTEMS_RECORD_USER_263 , RTEMS_RECORD_USER_264 , RTEMS_RECORD_USER_265 , RTEMS_RECORD_USER_266 , RTEMS_RECORD_USER_267 , RTEMS_RECORD_USER_268 , RTEMS_RECORD_USER_269 , RTEMS_RECORD_USER_270 , RTEMS_RECORD_USER_271 , RTEMS_RECORD_USER_272 , RTEMS_RECORD_USER_273 , RTEMS_RECORD_USER_274 , RTEMS_RECORD_USER_275 , RTEMS_RECORD_USER_276 , RTEMS_RECORD_USER_277 , RTEMS_RECORD_USER_278 , RTEMS_RECORD_USER_279 , RTEMS_RECORD_USER_280 , RTEMS_RECORD_USER_281 , RTEMS_RECORD_USER_282 , RTEMS_RECORD_USER_283 , RTEMS_RECORD_USER_284 , RTEMS_RECORD_USER_285 , RTEMS_RECORD_USER_286 , RTEMS_RECORD_USER_287 , RTEMS_RECORD_USER_288 , RTEMS_RECORD_USER_289 , RTEMS_RECORD_USER_290 , RTEMS_RECORD_USER_291 , RTEMS_RECORD_USER_292 , RTEMS_RECORD_USER_293 , RTEMS_RECORD_USER_294 , RTEMS_RECORD_USER_295 , RTEMS_RECORD_USER_296 , RTEMS_RECORD_USER_297 , RTEMS_RECORD_USER_298 , RTEMS_RECORD_USER_299 , RTEMS_RECORD_USER_300 , RTEMS_RECORD_USER_301 , RTEMS_RECORD_USER_302 , RTEMS_RECORD_USER_303 , RTEMS_RECORD_USER_304 , RTEMS_RECORD_USER_305 , RTEMS_RECORD_USER_306 , RTEMS_RECORD_USER_307 , RTEMS_RECORD_USER_308 , RTEMS_RECORD_USER_309 , RTEMS_RECORD_USER_310 , RTEMS_RECORD_USER_311 , RTEMS_RECORD_USER_312 , RTEMS_RECORD_USER_313 , RTEMS_RECORD_USER_314 , RTEMS_RECORD_USER_315 , RTEMS_RECORD_USER_316 , RTEMS_RECORD_USER_317 , RTEMS_RECORD_USER_318 , RTEMS_RECORD_USER_319 , RTEMS_RECORD_USER_320 , RTEMS_RECORD_USER_321 , RTEMS_RECORD_USER_322 , RTEMS_RECORD_USER_323 , RTEMS_RECORD_USER_324 , RTEMS_RECORD_USER_325 , RTEMS_RECORD_USER_326 , RTEMS_RECORD_USER_327 , RTEMS_RECORD_USER_328 , RTEMS_RECORD_USER_329 , RTEMS_RECORD_USER_330 , RTEMS_RECORD_USER_331 , RTEMS_RECORD_USER_332 , RTEMS_RECORD_USER_333 , RTEMS_RECORD_USER_334 , RTEMS_RECORD_USER_335 , RTEMS_RECORD_USER_336 , RTEMS_RECORD_USER_337 , RTEMS_RECORD_USER_338 , RTEMS_RECORD_USER_339 , RTEMS_RECORD_USER_340 , RTEMS_RECORD_USER_341 , RTEMS_RECORD_USER_342 , RTEMS_RECORD_USER_343 , RTEMS_RECORD_USER_344 , RTEMS_RECORD_USER_345 , RTEMS_RECORD_USER_346 , RTEMS_RECORD_USER_347 , RTEMS_RECORD_USER_348 , RTEMS_RECORD_USER_349 , RTEMS_RECORD_USER_350 , RTEMS_RECORD_USER_351 , RTEMS_RECORD_USER_352 , RTEMS_RECORD_USER_353 , RTEMS_RECORD_USER_354 , RTEMS_RECORD_USER_355 , RTEMS_RECORD_USER_356 , RTEMS_RECORD_USER_357 , RTEMS_RECORD_USER_358 , RTEMS_RECORD_USER_359 , RTEMS_RECORD_USER_360 , RTEMS_RECORD_USER_361 , RTEMS_RECORD_USER_362 , RTEMS_RECORD_USER_363 , RTEMS_RECORD_USER_364 , RTEMS_RECORD_USER_365 , RTEMS_RECORD_USER_366 , RTEMS_RECORD_USER_367 , RTEMS_RECORD_USER_368 , RTEMS_RECORD_USER_369 , RTEMS_RECORD_USER_370 , RTEMS_RECORD_USER_371 , RTEMS_RECORD_USER_372 , RTEMS_RECORD_USER_373 , RTEMS_RECORD_USER_374 , RTEMS_RECORD_USER_375 , RTEMS_RECORD_USER_376 , RTEMS_RECORD_USER_377 , RTEMS_RECORD_USER_378 , RTEMS_RECORD_USER_379 , RTEMS_RECORD_USER_380 , RTEMS_RECORD_USER_381 , RTEMS_RECORD_USER_382 , RTEMS_RECORD_USER_383 , RTEMS_RECORD_USER_384 , RTEMS_RECORD_USER_385 , RTEMS_RECORD_USER_386 , RTEMS_RECORD_USER_387 , RTEMS_RECORD_USER_388 , RTEMS_RECORD_USER_389 , RTEMS_RECORD_USER_390 , RTEMS_RECORD_USER_391 , RTEMS_RECORD_USER_392 , RTEMS_RECORD_USER_393 , RTEMS_RECORD_USER_394 , RTEMS_RECORD_USER_395 , RTEMS_RECORD_USER_396 , RTEMS_RECORD_USER_397 , RTEMS_RECORD_USER_398 , RTEMS_RECORD_USER_399 , RTEMS_RECORD_USER_400 , RTEMS_RECORD_USER_401 , RTEMS_RECORD_USER_402 , RTEMS_RECORD_USER_403 , RTEMS_RECORD_USER_404 , RTEMS_RECORD_USER_405 , RTEMS_RECORD_USER_406 , RTEMS_RECORD_USER_407 , RTEMS_RECORD_USER_408 , RTEMS_RECORD_USER_409 , RTEMS_RECORD_USER_410 , RTEMS_RECORD_USER_411 , RTEMS_RECORD_USER_412 , RTEMS_RECORD_USER_413 , RTEMS_RECORD_USER_414 , RTEMS_RECORD_USER_415 , RTEMS_RECORD_USER_416 , RTEMS_RECORD_USER_417 , RTEMS_RECORD_USER_418 , RTEMS_RECORD_USER_419 , RTEMS_RECORD_USER_420 , RTEMS_RECORD_USER_421 , RTEMS_RECORD_USER_422 , RTEMS_RECORD_USER_423 , RTEMS_RECORD_USER_424 , RTEMS_RECORD_USER_425 , RTEMS_RECORD_USER_426 , RTEMS_RECORD_USER_427 , RTEMS_RECORD_USER_428 , RTEMS_RECORD_USER_429 , RTEMS_RECORD_USER_430 , RTEMS_RECORD_USER_431 , RTEMS_RECORD_USER_432 , RTEMS_RECORD_USER_433 , RTEMS_RECORD_USER_434 , RTEMS_RECORD_USER_435 , RTEMS_RECORD_USER_436 , RTEMS_RECORD_USER_437 , RTEMS_RECORD_USER_438 , RTEMS_RECORD_USER_439 , RTEMS_RECORD_USER_440 , RTEMS_RECORD_USER_441 , RTEMS_RECORD_USER_442 , RTEMS_RECORD_USER_443 , RTEMS_RECORD_USER_444 , RTEMS_RECORD_USER_445 , RTEMS_RECORD_USER_446 , RTEMS_RECORD_USER_447 , RTEMS_RECORD_USER_448 , RTEMS_RECORD_USER_449 , RTEMS_RECORD_USER_450 , RTEMS_RECORD_USER_451 , RTEMS_RECORD_USER_452 , RTEMS_RECORD_USER_453 , RTEMS_RECORD_USER_454 , RTEMS_RECORD_USER_455 , RTEMS_RECORD_USER_456 , RTEMS_RECORD_USER_457 , RTEMS_RECORD_USER_458 , RTEMS_RECORD_USER_459 , RTEMS_RECORD_USER_460 , RTEMS_RECORD_USER_461 , RTEMS_RECORD_USER_462 , RTEMS_RECORD_USER_463 , RTEMS_RECORD_USER_464 , RTEMS_RECORD_USER_465 , RTEMS_RECORD_USER_466 , RTEMS_RECORD_USER_467 , RTEMS_RECORD_USER_468 , RTEMS_RECORD_USER_469 , RTEMS_RECORD_USER_470 , RTEMS_RECORD_USER_471 , RTEMS_RECORD_USER_472 , RTEMS_RECORD_USER_473 , RTEMS_RECORD_USER_474 , RTEMS_RECORD_USER_475 , RTEMS_RECORD_USER_476 , RTEMS_RECORD_USER_477 , RTEMS_RECORD_USER_478 , RTEMS_RECORD_USER_479 , RTEMS_RECORD_USER_480 , RTEMS_RECORD_USER_481 , RTEMS_RECORD_USER_482 , RTEMS_RECORD_USER_483 , RTEMS_RECORD_USER_484 , RTEMS_RECORD_USER_485 , RTEMS_RECORD_USER_486 , RTEMS_RECORD_USER_487 , RTEMS_RECORD_USER_488 , RTEMS_RECORD_USER_489 , RTEMS_RECORD_USER_490 , RTEMS_RECORD_USER_491 , RTEMS_RECORD_USER_492 , RTEMS_RECORD_USER_493 , RTEMS_RECORD_USER_494 , RTEMS_RECORD_USER_495 , RTEMS_RECORD_USER_496 , RTEMS_RECORD_USER_497 , RTEMS_RECORD_USER_498 , RTEMS_RECORD_USER_499 , RTEMS_RECORD_USER_500 , RTEMS_RECORD_USER_501 , RTEMS_RECORD_USER_502 , RTEMS_RECORD_USER_503 , RTEMS_RECORD_USER_504 , RTEMS_RECORD_USER_505 , RTEMS_RECORD_USER_506 , RTEMS_RECORD_USER_507 , RTEMS_RECORD_USER_508 , RTEMS_RECORD_USER_509 , RTEMS_RECORD_USER_510 , RTEMS_RECORD_USER_511 } |
The record events. | |
void | rtems_record_produce (rtems_record_event event, rtems_record_data data) |
Produces a record item. | |
void | rtems_record_produce_2 (rtems_record_event event_0, rtems_record_data data_0, rtems_record_event event_1, rtems_record_data data_1) |
Produces two record items. | |
void | rtems_record_produce_n (const rtems_record_item *items, size_t n) |
Produces n record items. | |
void | rtems_record_line (void) |
Generates an RTEMS_RECORD_LINE event. | |
void | rtems_record_line_2 (rtems_record_event event, rtems_record_data data) |
Generates an RTEMS_RECORD_LINE event and an extra event. | |
void | rtems_record_line_3 (rtems_record_event event_0, rtems_record_data data_0, rtems_record_event event_1, rtems_record_data data_1) |
Generates an RTEMS_RECORD_LINE event and two extra events. | |
void | rtems_record_line_arg (rtems_record_data data) |
Generates an RTEMS_RECORD_LINE event and one argument event. | |
void | rtems_record_line_arg_2 (rtems_record_data data_0, rtems_record_data data_1) |
Generates an RTEMS_RECORD_LINE event and two argument events. | |
void | rtems_record_line_arg_3 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2) |
Generates an RTEMS_RECORD_LINE event and three argument events. | |
void | rtems_record_line_arg_4 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3) |
Generates an RTEMS_RECORD_LINE event and four argument events. | |
void | rtems_record_line_arg_5 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4) |
Generates an RTEMS_RECORD_LINE event and five argument events. | |
void | rtems_record_line_arg_6 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5) |
Generates an RTEMS_RECORD_LINE event and six argument events. | |
void | rtems_record_line_arg_7 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6) |
Generates an RTEMS_RECORD_LINE event and seven argument events. | |
void | rtems_record_line_arg_8 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6, rtems_record_data data_7) |
Generates an RTEMS_RECORD_LINE event and eight argument events. | |
void | rtems_record_line_arg_9 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6, rtems_record_data data_7, rtems_record_data data_8) |
Generates an RTEMS_RECORD_LINE event and nine argument events. | |
void | rtems_record_line_arg_10 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6, rtems_record_data data_7, rtems_record_data data_8, rtems_record_data data_9) |
Generates an RTEMS_RECORD_LINE event and ten argument events. | |
uint32_t | rtems_record_interrupt_disable (void) |
Disables interrupts and generates an RTEMS_RECORD_ISR_DISABLE event. | |
void | rtems_record_interrupt_enable (uint32_t level) |
Restores the previous interrupt level and generates an RTEMS_RECORD_ISR_ENABLE event. | |
size_t | rtems_record_get_item_count_for_fetch (void) |
Returns the count of items which allows getting all available items for one processor through one call to rtems_record_fetch(). | |
void | rtems_record_fetch_initialize (rtems_record_fetch_control *control, rtems_record_item *items, size_t count) |
Initializes the record fetch control structure. | |
rtems_record_fetch_status | rtems_record_fetch (rtems_record_fetch_control *control) |
Fetches records from the record buffers of the processors. | |
rtems_record_client_status | rtems_record_client_init (rtems_record_client_context *ctx, rtems_record_client_handler handler, void *arg) |
Initializes a record client. | |
rtems_record_client_status | rtems_record_client_run (rtems_record_client_context *ctx, const void *buf, size_t n) |
Runs the record client to consume new stream data. | |
void | rtems_record_client_destroy (rtems_record_client_context *ctx) |
Drains all internal buffers and frees the allocated resources. | |
struct | __attribute__ ((__packed__)) |
The native record item. | |
const char * | rtems_record_event_text (rtems_record_event event) |
void | rtems_record_dump (rtems_record_dump_chunk chunk, void *arg) |
Dumps the record header, the thread names, and all items of all processors. | |
void | rtems_record_dump_base64 (void(*put_char)(int, void *), void *arg) |
Dumps the event records in base64 encoding. | |
void | rtems_record_dump_zlib_base64 (rtems_record_dump_base64_zlib_context *ctx, void(*put_char)(int, void *), void *arg) |
Dumps the event records compressed with zlib in base64 encoding. | |
rtems_record_item | |
rtems_record_item_64 | |
#define rtems_record_caller | ( | ) | _Record_Caller( RTEMS_RETURN_ADDRESS() ) |
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller().
#define rtems_record_caller_3 | ( | event, | |
data | |||
) | _Record_Caller_3( RTEMS_RETURN_ADDRESS(), event, data ) |
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_3().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_3().
event | The record event without a time stamp for the third item. |
data | The record data for the third item. |
#define rtems_record_caller_4 | ( | event_0, | |
data_0, | |||
event_1, | |||
data_1 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_4().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_4().
event_0 | The record event without a time stamp for the third item. |
data_0 | The record data for the third item. |
event_1 | The record event without a time stamp for the fourth item. |
data_1 | The record data for the fourth item. |
#define rtems_record_caller_arg | ( | data | ) | _Record_Caller_arg( RTEMS_RETURN_ADDRESS(), data ) |
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg().
data | The RTEMS_RECORD_ARG_0 event data. |
#define rtems_record_caller_arg_10 | ( | data_0, | |
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5, | |||
data_6, | |||
data_7, | |||
data_8, | |||
data_9 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_10().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_10().
data_0 | The RTEMS_RECORD_ARG_0 event data. |
data_1 | The RTEMS_RECORD_ARG_1 event data. |
data_2 | The RTEMS_RECORD_ARG_2 event data. |
data_3 | The RTEMS_RECORD_ARG_3 event data. |
data_4 | The RTEMS_RECORD_ARG_4 event data. |
data_5 | The RTEMS_RECORD_ARG_5 event data. |
data_6 | The RTEMS_RECORD_ARG_6 event data. |
data_7 | The RTEMS_RECORD_ARG_7 event data. |
data_8 | The RTEMS_RECORD_ARG_8 event data. |
data_10 | The RTEMS_RECORD_ARG_10 event data. |
#define rtems_record_caller_arg_2 | ( | data_0, | |
data_1 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_2().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_2().
#define rtems_record_caller_arg_3 | ( | data_0, | |
data_1, | |||
data_2 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_3().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_3().
#define rtems_record_caller_arg_4 | ( | data_0, | |
data_1, | |||
data_2, | |||
data_3 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_4().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_4().
#define rtems_record_caller_arg_5 | ( | data_0, | |
data_1, | |||
data_2, | |||
data_3, | |||
data_4 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_5().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_5().
#define rtems_record_caller_arg_6 | ( | data_0, | |
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_6().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_6().
#define rtems_record_caller_arg_7 | ( | data_0, | |
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5, | |||
data_6 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_7().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_7().
#define rtems_record_caller_arg_8 | ( | data_0, | |
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5, | |||
data_6, | |||
data_7 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_8().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_8().
#define rtems_record_caller_arg_9 | ( | data_0, | |
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5, | |||
data_6, | |||
data_7, | |||
data_8 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_9().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_9().
#define rtems_record_entry | ( | event | ) | rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() ) |
The event data of the specified entry event is the return address of the function calling rtems_record_entry().
event | The entry event. |
#define rtems_record_entry_1 | ( | event, | |
data | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_1().
#define rtems_record_entry_10 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5, | |||
data_6, | |||
data_7, | |||
data_8, | |||
data_9 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_10().
#define rtems_record_entry_2 | ( | event, | |
data_0, | |||
data_1 | |||
) | _Record_Entry_2( RTEMS_RETURN_ADDRESS(), event, data_0, data_1 ) |
The event data of the specified entry event is the return address of the function calling rtems_record_entry_2().
#define rtems_record_entry_3 | ( | event, | |
data_0, | |||
data_1, | |||
data_2 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_3().
#define rtems_record_entry_4 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_4().
#define rtems_record_entry_5 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3, | |||
data_4 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_5().
#define rtems_record_entry_6 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_6().
#define rtems_record_entry_7 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5, | |||
data_6 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_7().
#define rtems_record_entry_8 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5, | |||
data_6, | |||
data_7 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_8().
#define rtems_record_entry_9 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5, | |||
data_6, | |||
data_7, | |||
data_8 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_9().
#define rtems_record_exit | ( | event | ) | rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() ) |
The event data of the specified exit event is the return address of the function calling rtems_record_exit().
event | The exit event. |
#define rtems_record_exit_1 | ( | event, | |
data | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_1().
data | The RTEMS_RECORD_RETURN_0 event data. |
#define rtems_record_exit_10 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5, | |||
data_6, | |||
data_7, | |||
data_8, | |||
data_9 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_10().
data_0 | The RTEMS_RECORD_RETURN_0 event data. |
data_1 | The RTEMS_RECORD_RETURN_1 event data. |
data_2 | The RTEMS_RECORD_RETURN_2 event data. |
data_3 | The RTEMS_RECORD_RETURN_3 event data. |
data_4 | The RTEMS_RECORD_RETURN_4 event data. |
data_5 | The RTEMS_RECORD_RETURN_5 event data. |
data_6 | The RTEMS_RECORD_RETURN_6 event data. |
data_7 | The RTEMS_RECORD_RETURN_7 event data. |
data_8 | The RTEMS_RECORD_RETURN_8 event data. |
data_10 | The RTEMS_RECORD_RETURN_10 event data. |
#define rtems_record_exit_2 | ( | event, | |
data_0, | |||
data_1 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_2().
#define rtems_record_exit_3 | ( | event, | |
data_0, | |||
data_1, | |||
data_2 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_3().
#define rtems_record_exit_4 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_4().
#define rtems_record_exit_5 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3, | |||
data_4 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_5().
#define rtems_record_exit_6 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_6().
#define rtems_record_exit_7 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5, | |||
data_6 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_7().
#define rtems_record_exit_8 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5, | |||
data_6, | |||
data_7 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_8().
#define rtems_record_exit_9 | ( | event, | |
data_0, | |||
data_1, | |||
data_2, | |||
data_3, | |||
data_4, | |||
data_5, | |||
data_6, | |||
data_7, | |||
data_8 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_9().
#define RTEMS_RECORD_MAGIC 0x82e14ec1 |
This is a random number.
#define RTEMS_RECORD_THE_VERSION 10 |
The record version.
The record version reflects the record event definitions. It is reported by the RTEMS_RECORD_VERSION event.
#define RTEMS_RECORD_TIME_EVENT | ( | time, | |
event | |||
) | ( ( ( time ) << RTEMS_RECORD_EVENT_BITS ) | ( event ) ) |
The events are stored in the record item with a time stamp. There are 22 bits allocated to the time stamp and 10 bits allocated to the event. The 22 bits are enough to get reliable time stamps on a system with a 4GHz CPU counter and a 1000Hz clock tick.
typedef unsigned long rtems_record_data |
It is big enough to store 32-bit integers and pointers.
typedef void(* rtems_record_dump_chunk) (void *arg, const void *data, size_t length) |
arg | The argument passed to rtems_record_dump(). |
data | The begin of the data chunk. |
length | The length in bytes of the data chunk. |
Enumerator | |
RTEMS_RECORD_FETCH_DONE | This enumerator indicates that the current round of record fetches for all configure processors is done. |
RTEMS_RECORD_FETCH_CONTINUE | This enumerator indicates that the current round of record fetches for all configure processors has to continue. |
RTEMS_RECORD_FETCH_INVALID_ITEM_COUNT | This enumerator indicates that the item count passed to rtems_record_fetch() is invalid. |
struct __attribute__ | ( | (__packed__) | ) |
void rtems_record_client_destroy | ( | rtems_record_client_context * | ctx | ) |
The client context must not be used afterwards. It can be re-initialized via rtems_record_client_init().
ctx | The record client context. |
rtems_record_client_status rtems_record_client_init | ( | rtems_record_client_context * | ctx, |
rtems_record_client_handler | handler, | ||
void * | arg | ||
The record client consumes a record item stream produces by the record server.
ctx | The record client context to initialize. |
handler | The handler is invoked for each received record item. |
arg | The handler argument. |
rtems_record_client_status rtems_record_client_run | ( | rtems_record_client_context * | ctx, |
const void * | buf, | ||
size_t | n | ||
buf | The buffer with new stream data. |
n | The size of the buffer. |
void rtems_record_dump | ( | rtems_record_dump_chunk | chunk, |
void * | arg | ||
chunk | Handler to dump a chunk of data. |
flush | Handler to flush the data. |
arg | The argument for the handlers. |
void rtems_record_dump_base64 | ( | void(*)(int, void *) | put_char, |
void * | arg | ||
put_char | The put char handler. |
arg | The argument for the put char handler. |
void rtems_record_dump_zlib_base64 | ( | rtems_record_dump_base64_zlib_context * | ctx, |
void(*)(int, void *) | put_char, | ||
void * | arg | ||
ctx | The context to perform the record dump with zlib compression and base64 encoding. This context is too large for normal stack sizes. |
rtems_record_fetch_status rtems_record_fetch | ( | rtems_record_fetch_control * | control | ) |
The fetched items and count of fetched items is returned through the control structure.
[in,out] | control | is the structure used to control the record fetching. Use rtems_record_fetch_initialize() to initialize it before the first call to rtems_record_fetch(). |
RTEMS_RECORD_FETCH_DONE | This return status indicates that the current round of record fetches for all configure processors is done. |
RTEMS_RECORD_FETCH_CONTINUE | This return status indicates that the current round of record fetches for all configure processors has to continue. |
RTEMS_RECORD_FETCH_INVALID_ITEM_COUNT | This return status indicates that the specified item count was invalid. |
void rtems_record_fetch_initialize | ( | rtems_record_fetch_control * | control, |
rtems_record_item * | items, | ||
size_t | count | ||
This function shall be called before a record fetch control structure is passed to rtems_record_fetch().
[out] | control | is the structure to initialize. |
[out] | items | is a reference to an item array which is used to store the fetched items. |
count | is the count of items in the referenced array. See rtems_record_get_item_count_for_fetch(). |
size_t rtems_record_get_item_count_for_fetch | ( | void | ) |
The value depends on CONFIGURE_RECORD_PER_PROCESSOR_ITEMS and implementation details fo rtems_record_fetch().
uint32_t rtems_record_interrupt_disable | ( | void | ) |
void rtems_record_interrupt_enable | ( | uint32_t | level | ) |
level | The previous interrupt level. Must be the return value of the corresponding rtems_record_interrupt_disable(). |
void rtems_record_line | ( | void | ) |
The event data is the address of the call to this function.
void rtems_record_line_2 | ( | rtems_record_event | event, |
rtems_record_data | data | ||
event | The record event without a time stamp for the second item. |
data | The record data for the second item. |
void rtems_record_line_3 | ( | rtems_record_event | event_0, |
rtems_record_data | data_0, | ||
rtems_record_event | event_1, | ||
rtems_record_data | data_1 | ||
event_0 | The record event without a time stamp for the second item. |
data_0 | The record data for the second item. |
event_1 | The record event without a time stamp for the third item. |
data_1 | The record data for the third item. |
void rtems_record_line_arg | ( | rtems_record_data | data | ) |
The event data of the RTEMS_RECORD_LINE event is the address of the call to this function.
void rtems_record_line_arg_10 | ( | rtems_record_data | data_0, |
rtems_record_data | data_1, | ||
rtems_record_data | data_2, | ||
rtems_record_data | data_3, | ||
rtems_record_data | data_4, | ||
rtems_record_data | data_5, | ||
rtems_record_data | data_6, | ||
rtems_record_data | data_7, | ||
rtems_record_data | data_8, | ||
rtems_record_data | data_9 | ||
data_9 | The RTEMS_RECORD_ARG_9 event data. |
void rtems_record_line_arg_2 | ( | rtems_record_data | data_0, |
void rtems_record_line_arg_3 | ( | rtems_record_data | data_0, |
rtems_record_data | data_2 | ||
void rtems_record_line_arg_4 | ( | rtems_record_data | data_0, |
rtems_record_data | data_3 | ||
void rtems_record_line_arg_5 | ( | rtems_record_data | data_0, |
rtems_record_data | data_4 | ||
void rtems_record_line_arg_6 | ( | rtems_record_data | data_0, |
rtems_record_data | data_5 | ||
void rtems_record_line_arg_7 | ( | rtems_record_data | data_0, |
rtems_record_data | data_6 | ||
void rtems_record_line_arg_8 | ( | rtems_record_data | data_0, |
rtems_record_data | data_7 | ||
void rtems_record_line_arg_9 | ( | rtems_record_data | data_0, |
rtems_record_data | data_8 | ||
void rtems_record_produce | ( | rtems_record_event | event, |
event | The record event without a time stamp for the item. |
data | The record data for the item. |
void rtems_record_produce_2 | ( | rtems_record_event | event_0, |
event_0 | The record event without a time stamp for the first item. |
data_0 | The record data for the first item. |
event_1 | The record event without a time stamp for the second item. |
data_1 | The record data for the second item. |
void rtems_record_produce_n | ( | const rtems_record_item * | items, |
size_t | n | ||
item | The record items without a time stamps. |
n | The count of record items. |
