RTEMS 6.1-rc5
Multiprocessing Configuration
#define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
 This configuration option is an integer define.
#define CONFIGURE_MP_APPLICATION
 This configuration option is a boolean feature define.
#define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
#define CONFIGURE_MP_MAXIMUM_NODES
#define CONFIGURE_MP_MAXIMUM_PROXIES
#define CONFIGURE_MP_MPCI_TABLE_POINTER
 This configuration option is an initializer define.
#define CONFIGURE_MP_NODE_NUMBER
This section describes multiprocessing related configuration options. The options are only used if RTEMS was built when the multiprocessing build configuration option is enabled. The multiprocessing configuration is distinct from the SMP configuration. Additionally, this class of configuration options are only applicable if the configuration option CONFIGURE_MP_APPLICATION is defined. The multiprocessing (MPCI) support must not be confused with the SMP support.
◆ CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
The value of this configuration option defines the number of bytes the applications wishes to add to the MPCI task stack on top of CONFIGURE_MINIMUM_TASK_STACK_SIZE.
Default Value
The default value is 0.
Constraints
The following constraints apply to this configuration option:
  • The value of the configuration option shall be greater than or equal to zero.
  • The value of the configuration option shall be less than or equal to UINT32_MAX.
  • The value of the configuration option shall be small enough so that the MPCI receive server stack area calculation carried out by <rtems/confdefs.h> does not overflow an integer of type size_t.
Notes
This configuration option is only evaluated if CONFIGURE_MP_APPLICATION is defined.
◆ CONFIGURE_MP_APPLICATION
This configuration option is defined to indicate that the application intends to be part of a multiprocessing configuration. Additional configuration options are assumed to be provided.
Default Configuration
If this configuration option is undefined, then the multiprocessing services are not initialized.
Notes
This configuration option shall be undefined if the multiprocessing support is not enabled (e.g. RTEMS was built without the multiprocessing build configuration option enabled). Otherwise a compile time error in the configuration file will occur.
◆ CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
The value of this configuration option defines the maximum number of concurrently active global objects in a multiprocessor system.
Default Value
The default value is 32.
Constraints
Notes
This value corresponds to the total number of objects which can be created with the RTEMS_GLOBAL attribute.
◆ CONFIGURE_MP_MAXIMUM_NODES
The value of this configuration option defines the maximum number of nodes in a multiprocessor system.
Default Value
The default value is 2.
Constraints
Notes
◆ CONFIGURE_MP_MAXIMUM_PROXIES
The value of this configuration option defines the maximum number of concurrently active thread/task proxies on this node in a multiprocessor system.
Default Value
Constraints
Notes
Since a proxy is used to represent a remote task/thread which is blocking on this node. This configuration parameter reflects the maximum number of remote tasks/threads which can be blocked on objects on this node, see Proxies.
◆ CONFIGURE_MP_MPCI_TABLE_POINTER
The value of this configuration option initializes the MPCI Configuration Table.
Default Value
The default value is &MPCI_table.
Constraints
The value of the configuration option shall be a pointer to ::rtems_mpci_table.
Notes
RTEMS provides a Shared Memory MPCI Device Driver which can be used on any Multiprocessor System assuming the BSP provides the proper set of supporting methods.
◆ CONFIGURE_MP_NODE_NUMBER
The value of this configuration option defines the node number of this node in a multiprocessor system.
Default Value
The default value is NODE_NUMBER.
Constraints
Notes
In the RTEMS Multiprocessing Test Suite, the node number is derived from the Makefile variable NODE_NUMBER. The same code is compiled with the NODE_NUMBER set to different values. The test programs behave differently based upon their node number.
