RTEMS 6.1-rc5
#define | CONFIGURE_APPLICATION_NEEDS_LIBBLOCK |
This configuration option is a boolean feature define. | |
#define | CONFIGURE_BDBUF_BUFFER_MAX_SIZE |
This configuration option is an integer define. | |
#define | CONFIGURE_BDBUF_BUFFER_MIN_SIZE |
#define | CONFIGURE_BDBUF_CACHE_MEMORY_SIZE |
#define | CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS |
#define | CONFIGURE_BDBUF_MAX_WRITE_BLOCKS |
#define | CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY |
#define | CONFIGURE_BDBUF_TASK_STACK_SIZE |
#define | CONFIGURE_SWAPOUT_BLOCK_HOLD |
#define | CONFIGURE_SWAPOUT_SWAP_PERIOD |
#define | CONFIGURE_SWAPOUT_TASK_PRIORITY |
#define | CONFIGURE_SWAPOUT_WORKER_TASKS |
#define | CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY |
This section describes configuration options related to the Block Device Cache (bdbuf).
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK |
In case this configuration option is defined, then the Block Device Cache is initialized during system initialization.
#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE |
The value of this configuration option defines the maximum size of a buffer in bytes.
The following constraints apply to this configuration option:
#define CONFIGURE_BDBUF_BUFFER_MIN_SIZE |
The value of this configuration option defines the minimum size of a buffer in bytes.
#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE |
The value of this configuration option defines the size of the cache memory in bytes.
#define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS |
The value of this configuration option defines the maximum blocks per read-ahead request.
#define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS |
The value of this configuration option defines the maximum blocks per write request.
#define CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY |
The value of this configuration option defines the read-ahead task priority.
#define CONFIGURE_BDBUF_TASK_STACK_SIZE |
The value of this configuration option defines the task stack size of the Block Device Cache tasks in bytes.
<rtems/confdefs.h>
does not overflow an integer of type uintptr_t. #define CONFIGURE_SWAPOUT_BLOCK_HOLD |
The value of this configuration option defines the swapout task maximum block hold time in milliseconds.
#define CONFIGURE_SWAPOUT_SWAP_PERIOD |
The value of this configuration option defines the swapout task swap period in milliseconds.
#define CONFIGURE_SWAPOUT_TASK_PRIORITY |
The value of this configuration option defines the swapout task priority.
#define CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY |
The value of this configuration option defines the swapout worker task priority.
#define CONFIGURE_SWAPOUT_WORKER_TASKS |
The value of this configuration option defines the swapout worker task count.
