RTEMS 6.1-rc5
94#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
120#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE
146#define CONFIGURE_BDBUF_BUFFER_MIN_SIZE
172#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
203#define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
229#define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
248#define CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
280#define CONFIGURE_BDBUF_TASK_STACK_SIZE
306#define CONFIGURE_SWAPOUT_BLOCK_HOLD
332#define CONFIGURE_SWAPOUT_SWAP_PERIOD
351#define CONFIGURE_SWAPOUT_TASK_PRIORITY
377#define CONFIGURE_SWAPOUT_WORKER_TASKS
397#define CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
451#define CONFIGURE_MAXIMUM_BARRIERS
492#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES
532#define CONFIGURE_MAXIMUM_PARTITIONS
572#define CONFIGURE_MAXIMUM_PERIODS
612#define CONFIGURE_MAXIMUM_PORTS
652#define CONFIGURE_MAXIMUM_REGIONS
701#define CONFIGURE_MAXIMUM_SEMAPHORES
762#define CONFIGURE_MAXIMUM_TASKS
802#define CONFIGURE_MAXIMUM_TIMERS
835#define CONFIGURE_MAXIMUM_USER_EXTENSIONS
868#define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE
903#define CONFIGURE_INIT_TASK_ARGUMENTS
921#define CONFIGURE_INIT_TASK_ATTRIBUTES
978#define CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
1001#define CONFIGURE_INIT_TASK_ENTRY_POINT
1020#define CONFIGURE_INIT_TASK_INITIAL_MODES
1042#define CONFIGURE_INIT_TASK_NAME
1062#define CONFIGURE_INIT_TASK_PRIORITY
1101#define CONFIGURE_INIT_TASK_STACK_SIZE
1135#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
1185#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
1213#define CONFIGURE_APPLICATION_EXTRA_DRIVERS
1237#define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
1270#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
1306#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
1331#define CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
1355#define CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
1374#define CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
1399#define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
1439#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
1488#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
1508#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
1541#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
1566#define CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
1585#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
1614#define CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
1637#define CONFIGURE_ATA_DRIVER_TASK_PRIORITY
1662#define CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
1736#define CONFIGURE_MAXIMUM_DRIVERS
1776#define CONFIGURE_RECORD_EXTENSIONS_ENABLED
1805#define CONFIGURE_RECORD_FATAL_DUMP_BASE64
1833#define CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
1858#define CONFIGURE_RECORD_INTERRUPTS_ENABLED
1895#define CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
1946#define CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
2022#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
2052#define CONFIGURE_FILESYSTEM_ALL
2073#define CONFIGURE_FILESYSTEM_DOSFS
2090#define CONFIGURE_FILESYSTEM_FTPFS
2113#define CONFIGURE_FILESYSTEM_IMFS
2130#define CONFIGURE_FILESYSTEM_JFFS2
2147#define CONFIGURE_FILESYSTEM_NFS
2168#define CONFIGURE_FILESYSTEM_RFS
2185#define CONFIGURE_FILESYSTEM_TFTPFS
2201#define CONFIGURE_IMFS_DISABLE_CHMOD
2217#define CONFIGURE_IMFS_DISABLE_CHOWN
2233#define CONFIGURE_IMFS_DISABLE_LINK
2249#define CONFIGURE_IMFS_DISABLE_MKNOD
2265#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
2281#define CONFIGURE_IMFS_DISABLE_MKNOD_FILE
2297#define CONFIGURE_IMFS_DISABLE_MOUNT
2314#define CONFIGURE_IMFS_DISABLE_READDIR
2330#define CONFIGURE_IMFS_DISABLE_READLINK
2346#define CONFIGURE_IMFS_DISABLE_RENAME
2362#define CONFIGURE_IMFS_DISABLE_RMNOD
2378#define CONFIGURE_IMFS_DISABLE_SYMLINK
2394#define CONFIGURE_IMFS_DISABLE_UNMOUNT
2410#define CONFIGURE_IMFS_DISABLE_UTIME
2426#define CONFIGURE_IMFS_ENABLE_MKFIFO
2476#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
2504#define CONFIGURE_JFFS2_DELAYED_WRITE_TASK_PRIORITY
2557#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
2595#define CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
2638#define CONFIGURE_DIRTY_MEMORY
2671#define CONFIGURE_DISABLE_BSP_SETTINGS
2693#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
2729#define CONFIGURE_EXECUTIVE_RAM_SIZE
2763#define CONFIGURE_EXTRA_TASK_STACKS
2784#define CONFIGURE_INIT
2815#define CONFIGURE_INITIAL_EXTENSIONS
2871#define CONFIGURE_INTERRUPT_STACK_SIZE
2894#define CONFIGURE_MALLOC_DIRTY
2928#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
2967#define CONFIGURE_MAXIMUM_PROCESSORS
3017#define CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
3058#define CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
3098#define CONFIGURE_MEMORY_OVERHEAD
3178#define CONFIGURE_MESSAGE_BUFFER_MEMORY
3230#define CONFIGURE_MICROSECONDS_PER_TICK
3281#define CONFIGURE_MINIMUM_TASK_STACK_SIZE
3306#define CONFIGURE_STACK_CHECKER_ENABLED
3336#define CONFIGURE_TICKS_PER_TIMESLICE
3365#define CONFIGURE_UNIFIED_WORK_AREAS
3397#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE
3425#define CONFIGURE_UNLIMITED_OBJECTS
3445#define CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION
3468#define CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
3518#define CONFIGURE_IDLE_TASK_BODY
3566#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
3602#define CONFIGURE_IDLE_TASK_STACK_SIZE
3657#define CONFIGURE_IDLE_TASK_STORAGE_SIZE
3714#define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
3737#define CONFIGURE_MP_APPLICATION
3772#define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
3802#define CONFIGURE_MP_MAXIMUM_NODES
3840#define CONFIGURE_MP_MAXIMUM_PROXIES
3869#define CONFIGURE_MP_MPCI_TABLE_POINTER
3906#define CONFIGURE_MP_NODE_NUMBER
3963#define CONFIGURE_MAXIMUM_POSIX_KEYS
4010#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
4056#define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
4101#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
4152#define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
4197#define CONFIGURE_MAXIMUM_POSIX_SHMS
4250#define CONFIGURE_MAXIMUM_POSIX_THREADS
4300#define CONFIGURE_MAXIMUM_POSIX_TIMERS
4329#define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
4368#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
4396#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
4431#define CONFIGURE_POSIX_INIT_THREAD_TABLE
4503#define CONFIGURE_CBS_MAXIMUM_SERVERS
4563#define CONFIGURE_MAXIMUM_PRIORITY
4615#define CONFIGURE_SCHEDULER_ASSIGNMENTS
4644#define CONFIGURE_SCHEDULER_CBS
4672#define CONFIGURE_SCHEDULER_EDF
4707#define CONFIGURE_SCHEDULER_EDF_SMP
4770#define CONFIGURE_SCHEDULER_NAME
4804#define CONFIGURE_SCHEDULER_PRIORITY
4839#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
4873#define CONFIGURE_SCHEDULER_PRIORITY_SMP
4901#define CONFIGURE_SCHEDULER_SIMPLE
4932#define CONFIGURE_SCHEDULER_SIMPLE_SMP
4959#define CONFIGURE_SCHEDULER_STRONG_APA
5024#define CONFIGURE_SCHEDULER_TABLE_ENTRIES
5069#define CONFIGURE_SCHEDULER_USER
5120#define CONFIGURE_TASK_STACK_ALLOCATOR
5140#define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
5190#define CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
5223#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT
5255#define CONFIGURE_TASK_STACK_DEALLOCATOR
5281#define CONFIGURE_TASK_STACK_FROM_ALLOCATOR
