RTEMS 6.1-rc4
Chain_Node Struct Reference
This structure represents a chain node. More...
#include <chain.h>
struct Chain_Nodenext
struct Chain_Nodeprevious
This is used to manage each element (node) which is placed on a chain.
Note
Typically, a more complicated structure will use the chain package. The more complicated structure will include a chain node as the first element in its control structure. It will then call the chain package with a pointer to that node element. The node pointer and the higher level structure start at the same address so the user can cast the pointers back and forth.
Field Documentation
◆ next
struct Chain_Node* Chain_Node::next
This points to the node after this one on this chain.
◆ previous
struct Chain_Node* Chain_Node::previous
This points to the node immediate prior to this one on this chain.
