RTEMS 6.1-rc4
This structure defines the GR740 I/0 and PLL Configuration register block memory map. More...
#include <gr740-iopll-regs.h>
uint32_t ftmfunc
 See FTMCTRL function enable register (FTMFUNC).
uint32_t altfunc
 See Alternative function enable register (ALTFUNC).
uint32_t lvdsmclk
 See LVDS and memory clock pad enable register (LVDSMCLK).
uint32_t pllnewcfg
 See PLL new configuration register (PLLNEWCFG).
uint32_t pllrecfg
 See PLL reconfigure command register (PLLRECFG).
uint32_t pllcurcfg
 See PLL current configuration register (PLLCURCFG).
uint32_t drvstr1
 See Drive strength configuration register 1 (DRVSTR1).
uint32_t drvstr2
 See Drive strength configuration register 2 (DRVSTR2).
uint32_t lockdown
 See Configuration lockdown register (LOCKDOWN).
