RTEMS 6.1-rc4
Drive strength configuration register 2 (DRVSTR2)
This group contains register bit definitions. More...
#define GR740_IOPLL_DRVSTR2_S19_SHIFT   18
#define GR740_IOPLL_DRVSTR2_S19_MASK   0xc0000U
#define GR740_IOPLL_DRVSTR2_S19_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S19_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S19(_val)
#define GR740_IOPLL_DRVSTR2_S18_SHIFT   16
#define GR740_IOPLL_DRVSTR2_S18_MASK   0x30000U
#define GR740_IOPLL_DRVSTR2_S18_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S18_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S18(_val)
#define GR740_IOPLL_DRVSTR2_S17_SHIFT   14
#define GR740_IOPLL_DRVSTR2_S17_MASK   0xc000U
#define GR740_IOPLL_DRVSTR2_S17_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S17_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S17(_val)
#define GR740_IOPLL_DRVSTR2_S16_SHIFT   12
#define GR740_IOPLL_DRVSTR2_S16_MASK   0x3000U
#define GR740_IOPLL_DRVSTR2_S16_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S16_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S16(_val)
#define GR740_IOPLL_DRVSTR2_S15_SHIFT   10
#define GR740_IOPLL_DRVSTR2_S15_MASK   0xc00U
#define GR740_IOPLL_DRVSTR2_S15_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S15_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S15(_val)
#define GR740_IOPLL_DRVSTR2_S14_SHIFT   8
#define GR740_IOPLL_DRVSTR2_S14_MASK   0x300U
#define GR740_IOPLL_DRVSTR2_S14_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S14_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S14(_val)
#define GR740_IOPLL_DRVSTR2_S13_SHIFT   6
#define GR740_IOPLL_DRVSTR2_S13_MASK   0xc0U
#define GR740_IOPLL_DRVSTR2_S13_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S13_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S13(_val)
#define GR740_IOPLL_DRVSTR2_S12_SHIFT   4
#define GR740_IOPLL_DRVSTR2_S12_MASK   0x30U
#define GR740_IOPLL_DRVSTR2_S12_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S12_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S12(_val)
#define GR740_IOPLL_DRVSTR2_S11_SHIFT   2
#define GR740_IOPLL_DRVSTR2_S11_MASK   0xcU
#define GR740_IOPLL_DRVSTR2_S11_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S11_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S11(_val)
#define GR740_IOPLL_DRVSTR2_S10_SHIFT   0
#define GR740_IOPLL_DRVSTR2_S10_MASK   0x3U
#define GR740_IOPLL_DRVSTR2_S10_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S10_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S10(_val)
◆ GR740_IOPLL_DRVSTR2_S10
#define GR740_IOPLL_DRVSTR2_S10 (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR2_S10_SHIFT ) & \
GR740_IOPLL_DRVSTR2_S10_MASK )
◆ GR740_IOPLL_DRVSTR2_S10_GET
#define GR740_IOPLL_DRVSTR2_S10_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR2_S10_MASK ) >> \
◆ GR740_IOPLL_DRVSTR2_S10_SET
#define GR740_IOPLL_DRVSTR2_S10_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR2_S10_MASK ) | \
GR740_IOPLL_DRVSTR2_S10_MASK ) )
◆ GR740_IOPLL_DRVSTR2_S11
#define GR740_IOPLL_DRVSTR2_S11 (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR2_S11_SHIFT ) & \
GR740_IOPLL_DRVSTR2_S11_MASK )
◆ GR740_IOPLL_DRVSTR2_S11_GET
#define GR740_IOPLL_DRVSTR2_S11_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR2_S11_MASK ) >> \
◆ GR740_IOPLL_DRVSTR2_S11_SET
#define GR740_IOPLL_DRVSTR2_S11_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR2_S11_MASK ) | \
GR740_IOPLL_DRVSTR2_S11_MASK ) )
◆ GR740_IOPLL_DRVSTR2_S12
#define GR740_IOPLL_DRVSTR2_S12 (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR2_S12_SHIFT ) & \
GR740_IOPLL_DRVSTR2_S12_MASK )
◆ GR740_IOPLL_DRVSTR2_S12_GET
#define GR740_IOPLL_DRVSTR2_S12_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR2_S12_MASK ) >> \
◆ GR740_IOPLL_DRVSTR2_S12_SET
#define GR740_IOPLL_DRVSTR2_S12_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR2_S12_MASK ) | \
GR740_IOPLL_DRVSTR2_S12_MASK ) )
◆ GR740_IOPLL_DRVSTR2_S13
#define GR740_IOPLL_DRVSTR2_S13 (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR2_S13_SHIFT ) & \
GR740_IOPLL_DRVSTR2_S13_MASK )
◆ GR740_IOPLL_DRVSTR2_S13_GET
#define GR740_IOPLL_DRVSTR2_S13_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR2_S13_MASK ) >> \
◆ GR740_IOPLL_DRVSTR2_S13_SET
#define GR740_IOPLL_DRVSTR2_S13_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR2_S13_MASK ) | \
GR740_IOPLL_DRVSTR2_S13_MASK ) )
◆ GR740_IOPLL_DRVSTR2_S14
#define GR740_IOPLL_DRVSTR2_S14 (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR2_S14_SHIFT ) & \
GR740_IOPLL_DRVSTR2_S14_MASK )
◆ GR740_IOPLL_DRVSTR2_S14_GET
#define GR740_IOPLL_DRVSTR2_S14_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR2_S14_MASK ) >> \
◆ GR740_IOPLL_DRVSTR2_S14_SET
#define GR740_IOPLL_DRVSTR2_S14_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR2_S14_MASK ) | \
GR740_IOPLL_DRVSTR2_S14_MASK ) )
◆ GR740_IOPLL_DRVSTR2_S15
#define GR740_IOPLL_DRVSTR2_S15 (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR2_S15_SHIFT ) & \
GR740_IOPLL_DRVSTR2_S15_MASK )
◆ GR740_IOPLL_DRVSTR2_S15_GET
#define GR740_IOPLL_DRVSTR2_S15_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR2_S15_MASK ) >> \
◆ GR740_IOPLL_DRVSTR2_S15_SET
#define GR740_IOPLL_DRVSTR2_S15_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR2_S15_MASK ) | \
GR740_IOPLL_DRVSTR2_S15_MASK ) )
◆ GR740_IOPLL_DRVSTR2_S16
#define GR740_IOPLL_DRVSTR2_S16 (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR2_S16_SHIFT ) & \
GR740_IOPLL_DRVSTR2_S16_MASK )
◆ GR740_IOPLL_DRVSTR2_S16_GET
#define GR740_IOPLL_DRVSTR2_S16_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR2_S16_MASK ) >> \
◆ GR740_IOPLL_DRVSTR2_S16_SET
#define GR740_IOPLL_DRVSTR2_S16_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR2_S16_MASK ) | \
GR740_IOPLL_DRVSTR2_S16_MASK ) )
◆ GR740_IOPLL_DRVSTR2_S17
#define GR740_IOPLL_DRVSTR2_S17 (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR2_S17_SHIFT ) & \
GR740_IOPLL_DRVSTR2_S17_MASK )
◆ GR740_IOPLL_DRVSTR2_S17_GET
#define GR740_IOPLL_DRVSTR2_S17_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR2_S17_MASK ) >> \
◆ GR740_IOPLL_DRVSTR2_S17_SET
#define GR740_IOPLL_DRVSTR2_S17_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR2_S17_MASK ) | \
GR740_IOPLL_DRVSTR2_S17_MASK ) )
◆ GR740_IOPLL_DRVSTR2_S18
#define GR740_IOPLL_DRVSTR2_S18 (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR2_S18_SHIFT ) & \
GR740_IOPLL_DRVSTR2_S18_MASK )
◆ GR740_IOPLL_DRVSTR2_S18_GET
#define GR740_IOPLL_DRVSTR2_S18_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR2_S18_MASK ) >> \
◆ GR740_IOPLL_DRVSTR2_S18_SET
#define GR740_IOPLL_DRVSTR2_S18_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR2_S18_MASK ) | \
GR740_IOPLL_DRVSTR2_S18_MASK ) )
◆ GR740_IOPLL_DRVSTR2_S19
#define GR740_IOPLL_DRVSTR2_S19 (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_DRVSTR2_S19_SHIFT ) & \
GR740_IOPLL_DRVSTR2_S19_MASK )
◆ GR740_IOPLL_DRVSTR2_S19_GET
#define GR740_IOPLL_DRVSTR2_S19_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_DRVSTR2_S19_MASK ) >> \
◆ GR740_IOPLL_DRVSTR2_S19_SET
#define GR740_IOPLL_DRVSTR2_S19_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_DRVSTR2_S19_MASK ) | \
GR740_IOPLL_DRVSTR2_S19_MASK ) )
