RTEMS 6.1-rc4
Test context for spec:/dev/clock/xil-ttc/val/fatal-irq-install test case. More...
Data Fields | |
rtems_fatal_source | source |
This member contains a copy of the corresponding DevClockXilTtcValFatalIrqInstall_Run() parameter. | |
rtems_fatal_code | code |
