RTEMS 6.1-rc4
RTEMS Run-Time Linker Allocator for the standard heap. More...
void | rtems_rtl_alloc_heap (rtems_rtl_alloc_cmd cmd, rtems_rtl_alloc_tag tag, void **address, size_t size) |
void rtems_rtl_alloc_heap | ( | rtems_rtl_alloc_cmd | cmd, |
rtems_rtl_alloc_tag | tag, | ||
void ** | address, | ||
size_t | size | ||
Allocator handler for the standard libc heap.
cmd | The allocation command. |
tag | The type of allocation request. |
address | Pointer to the memory address. If an allocation the value is unspecific on entry and the allocated address or NULL on exit. The NULL value means the allocation failed. If a delete or free request the memory address is the block to free. A free request of NULL is silently ignored. |
size | The size of the allocation if an allocation request and not used if deleting or freeing a previous allocation. |
