RTEMS
6.1-rc4
libdl
rtl-alloc-heap.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* COPYRIGHT (c) 2012, 2018 Chris Johns <chrisj@rtems.org>
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#if !defined (_RTEMS_RTL_ALLOC_HEAP_H_)
37
#define _RTEMS_RTL_ALLOC_HEAP_H_
38
39
rtems/rtl/rtl-allocator.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
/* __cplusplus */
44
58
void
rtems_rtl_alloc_heap
rtems_rtl_alloc_cmd
cmd,
59
rtems_rtl_alloc_tag
tag,
60
void
** address,
61
size_t
size);
62
63
#ifdef __cplusplus
64
65
#endif
/* __cplusplus */
66
67
#endif
void rtems_rtl_alloc_heap(rtems_rtl_alloc_cmd cmd, rtems_rtl_alloc_tag tag, void **address, size_t size)
Definition:
rtl-alloc-heap.c:43
rtl-allocator.h
RTEMS Run-Time Linker Allocator.
rtems_rtl_alloc_tag
enum rtems_rtl_alloc_tags rtems_rtl_alloc_tag
Definition:
rtl-allocator.h:64
rtems_rtl_alloc_cmd
rtems_rtl_alloc_cmd
Definition:
rtl-allocator.h:69
