RTEMS 6.1-rc4
Data Structures | Macros | Typedefs
grspwrouter-regs.h File Reference
This header file defines the GRSPWROUTER register block interface. More...
#include <stdint.h>
struct  grspwrouter_portstats
 This structure defines the SpaceWire Router Port Statistics register block memory map. More...
struct  grspwrouter
 This structure defines the SpaceWire Router register block memory map. More...
#define GRSPWROUTER_OCHARCNT_OR   0x80000000U
#define GRSPWROUTER_OCHARCNT_CC_SHIFT   0
#define GRSPWROUTER_OCHARCNT_CC_MASK   0x7fffffffU
#define GRSPWROUTER_OCHARCNT_CC_GET(_reg)
#define GRSPWROUTER_OCHARCNT_CC_SET(_reg, _val)
#define GRSPWROUTER_OCHARCNT_CC(_val)
#define GRSPWROUTER_ICHARCNT_OR   0x80000000U
#define GRSPWROUTER_ICHARCNT_CC_SHIFT   0
#define GRSPWROUTER_ICHARCNT_CC_MASK   0x7fffffffU
#define GRSPWROUTER_ICHARCNT_CC_GET(_reg)
#define GRSPWROUTER_ICHARCNT_CC_SET(_reg, _val)
#define GRSPWROUTER_ICHARCNT_CC(_val)
#define GRSPWROUTER_OPKTCNT_OR   0x80000000U
#define GRSPWROUTER_OPKTCNT_PC_SHIFT   0
#define GRSPWROUTER_OPKTCNT_PC_MASK   0x7fffffffU
#define GRSPWROUTER_OPKTCNT_PC_GET(_reg)
#define GRSPWROUTER_OPKTCNT_PC_SET(_reg, _val)
#define GRSPWROUTER_OPKTCNT_PC(_val)
#define GRSPWROUTER_IPKTCNT_OR   0x80000000U
#define GRSPWROUTER_IPKTCNT_PC_SHIFT   0
#define GRSPWROUTER_IPKTCNT_PC_MASK   0x7fffffffU
#define GRSPWROUTER_IPKTCNT_PC_GET(_reg)
#define GRSPWROUTER_IPKTCNT_PC_SET(_reg, _val)
#define GRSPWROUTER_IPKTCNT_PC(_val)
#define GRSPWROUTER_RTPMAP_PE_SHIFT   1
#define GRSPWROUTER_RTPMAP_PE_MASK   0xfffffffeU
#define GRSPWROUTER_RTPMAP_PE_GET(_reg)
#define GRSPWROUTER_RTPMAP_PE_SET(_reg, _val)
#define GRSPWROUTER_RTPMAP_PE(_val)
#define GRSPWROUTER_RTPMAP_PD   0x1U
#define GRSPWROUTER_RTACTRL_SR   0x8U
#define GRSPWROUTER_RTACTRL_EN   0x4U
#define GRSPWROUTER_RTACTRL_PR   0x2U
#define GRSPWROUTER_RTACTRL_HD   0x1U
#define GRSPWROUTER_PCTRLCFG_PL   0x20000U
#define GRSPWROUTER_PCTRLCFG_TS   0x10000U
#define GRSPWROUTER_PCTRLCFG_TR   0x200U
#define GRSPWROUTER_PCTRL_RD_SHIFT   24
#define GRSPWROUTER_PCTRL_RD_MASK   0xff000000U
#define GRSPWROUTER_PCTRL_RD_GET(_reg)
#define GRSPWROUTER_PCTRL_RD_SET(_reg, _val)
#define GRSPWROUTER_PCTRL_RD(_val)
#define GRSPWROUTER_PCTRL_RES_SHIFT   22
#define GRSPWROUTER_PCTRL_RES_MASK   0xc00000U
#define GRSPWROUTER_PCTRL_RES_GET(_reg)
#define GRSPWROUTER_PCTRL_RES_SET(_reg, _val)
#define GRSPWROUTER_PCTRL_RES(_val)
#define GRSPWROUTER_PCTRL_ST   0x200000U
#define GRSPWROUTER_PCTRL_SR   0x100000U
#define GRSPWROUTER_PCTRL_AD   0x80000U
#define GRSPWROUTER_PCTRL_LR   0x40000U
#define GRSPWROUTER_PCTRL_PL   0x20000U
#define GRSPWROUTER_PCTRL_TS   0x10000U
#define GRSPWROUTER_PCTRL_IC   0x8000U
#define GRSPWROUTER_PCTRL_ET   0x4000U
#define GRSPWROUTER_PCTRL_NF   0x2000U
#define GRSPWROUTER_PCTRL_PS   0x1000U
#define GRSPWROUTER_PCTRL_BE   0x800U
#define GRSPWROUTER_PCTRL_DI   0x400U
#define GRSPWROUTER_PCTRL_TR   0x200U
#define GRSPWROUTER_PCTRL_PR   0x100U
#define GRSPWROUTER_PCTRL_TF   0x80U
#define GRSPWROUTER_PCTRL_RS   0x40U
#define GRSPWROUTER_PCTRL_TE   0x20U
#define GRSPWROUTER_PCTRL_R   0x10U
#define GRSPWROUTER_PCTRL_CE   0x8U
#define GRSPWROUTER_PCTRL_AS   0x4U
#define GRSPWROUTER_PCTRL_LS   0x2U
#define GRSPWROUTER_PCTRL_LD   0x1U
#define GRSPWROUTER_PSTSCFG_EO   0x80000000U
#define GRSPWROUTER_PSTSCFG_EE   0x40000000U
#define GRSPWROUTER_PSTSCFG_PL   0x20000000U
#define GRSPWROUTER_PSTSCFG_TT   0x10000000U
#define GRSPWROUTER_PSTSCFG_PT   0x8000000U
#define GRSPWROUTER_PSTSCFG_HC   0x4000000U
#define GRSPWROUTER_PSTSCFG_PI   0x2000000U
#define GRSPWROUTER_PSTSCFG_CE   0x1000000U
#define GRSPWROUTER_PSTSCFG_EC_SHIFT   20
#define GRSPWROUTER_PSTSCFG_EC_MASK   0xf00000U
#define GRSPWROUTER_PSTSCFG_EC_GET(_reg)
#define GRSPWROUTER_PSTSCFG_EC_SET(_reg, _val)
#define GRSPWROUTER_PSTSCFG_EC(_val)
#define GRSPWROUTER_PSTSCFG_R   0x80000U
#define GRSPWROUTER_PSTSCFG_TS   0x40000U
#define GRSPWROUTER_PSTSCFG_ME   0x20000U
#define GRSPWROUTER_PSTSCFG_IP_SHIFT   7
#define GRSPWROUTER_PSTSCFG_IP_MASK   0xf80U
#define GRSPWROUTER_PSTSCFG_IP_GET(_reg)
#define GRSPWROUTER_PSTSCFG_IP_SET(_reg, _val)
#define GRSPWROUTER_PSTSCFG_IP(_val)
#define GRSPWROUTER_PSTSCFG_RES_SHIFT   5
#define GRSPWROUTER_PSTSCFG_RES_MASK   0x60U
#define GRSPWROUTER_PSTSCFG_RES_GET(_reg)
#define GRSPWROUTER_PSTSCFG_RES_SET(_reg, _val)
#define GRSPWROUTER_PSTSCFG_RES(_val)
#define GRSPWROUTER_PSTSCFG_CP   0x10U
#define GRSPWROUTER_PSTSCFG_PC_SHIFT   0
#define GRSPWROUTER_PSTSCFG_PC_MASK   0xfU
#define GRSPWROUTER_PSTSCFG_PC_GET(_reg)
#define GRSPWROUTER_PSTSCFG_PC_SET(_reg, _val)
#define GRSPWROUTER_PSTSCFG_PC(_val)
#define GRSPWROUTER_PSTS_PT_SHIFT   30
#define GRSPWROUTER_PSTS_PT_MASK   0xc0000000U
#define GRSPWROUTER_PSTS_PT_GET(_reg)
#define GRSPWROUTER_PSTS_PT_SET(_reg, _val)
#define GRSPWROUTER_PSTS_PT(_val)
#define GRSPWROUTER_PSTS_PL   0x20000000U
#define GRSPWROUTER_PSTS_TT   0x10000000U
#define GRSPWROUTER_PSTS_RS   0x8000000U
#define GRSPWROUTER_PSTS_SR   0x4000000U
#define GRSPWROUTER_PSTS_LR   0x400000U
#define GRSPWROUTER_PSTS_SP   0x200000U
#define GRSPWROUTER_PSTS_AC   0x100000U
#define GRSPWROUTER_PSTS_AP   0x80000U
#define GRSPWROUTER_PSTS_TS   0x40000U
#define GRSPWROUTER_PSTS_ME   0x20000U
#define GRSPWROUTER_PSTS_TF   0x10000U
#define GRSPWROUTER_PSTS_RE   0x8000U
#define GRSPWROUTER_PSTS_LS_SHIFT   12
#define GRSPWROUTER_PSTS_LS_MASK   0x7000U
#define GRSPWROUTER_PSTS_LS_GET(_reg)
#define GRSPWROUTER_PSTS_LS_SET(_reg, _val)
#define GRSPWROUTER_PSTS_LS(_val)
#define GRSPWROUTER_PSTS_IP_SHIFT   7
#define GRSPWROUTER_PSTS_IP_MASK   0xf80U
#define GRSPWROUTER_PSTS_IP_GET(_reg)
#define GRSPWROUTER_PSTS_IP_SET(_reg, _val)
#define GRSPWROUTER_PSTS_IP(_val)
#define GRSPWROUTER_PSTS_PR   0x40U
#define GRSPWROUTER_PSTS_PB   0x20U
#define GRSPWROUTER_PSTS_IA   0x10U
#define GRSPWROUTER_PSTS_CE   0x8U
#define GRSPWROUTER_PSTS_ER   0x4U
#define GRSPWROUTER_PSTS_DE   0x2U
#define GRSPWROUTER_PSTS_PE   0x1U
#define GRSPWROUTER_PTIMER_RL_SHIFT   0
#define GRSPWROUTER_PTIMER_RL_MASK   0x3ffU
#define GRSPWROUTER_PTIMER_RL_GET(_reg)
#define GRSPWROUTER_PTIMER_RL_SET(_reg, _val)
#define GRSPWROUTER_PTIMER_RL(_val)
#define GRSPWROUTER_PCTRL2CFG_SM_SHIFT   24
#define GRSPWROUTER_PCTRL2CFG_SM_MASK   0xff000000U
#define GRSPWROUTER_PCTRL2CFG_SM_GET(_reg)
#define GRSPWROUTER_PCTRL2CFG_SM_SET(_reg, _val)
#define GRSPWROUTER_PCTRL2CFG_SM(_val)
#define GRSPWROUTER_PCTRL2CFG_SV_SHIFT   16
#define GRSPWROUTER_PCTRL2CFG_SV_MASK   0xff0000U
#define GRSPWROUTER_PCTRL2CFG_SV_GET(_reg)
#define GRSPWROUTER_PCTRL2CFG_SV_SET(_reg, _val)
#define GRSPWROUTER_PCTRL2CFG_SV(_val)
#define GRSPWROUTER_PCTRL2CFG_OR   0x8000U
#define GRSPWROUTER_PCTRL2_SM_SHIFT   24
#define GRSPWROUTER_PCTRL2_SM_MASK   0xff000000U
#define GRSPWROUTER_PCTRL2_SM_GET(_reg)
#define GRSPWROUTER_PCTRL2_SM_SET(_reg, _val)
#define GRSPWROUTER_PCTRL2_SM(_val)
#define GRSPWROUTER_PCTRL2_SV_SHIFT   16
#define GRSPWROUTER_PCTRL2_SV_MASK   0xff0000U
#define GRSPWROUTER_PCTRL2_SV_GET(_reg)
#define GRSPWROUTER_PCTRL2_SV_SET(_reg, _val)
#define GRSPWROUTER_PCTRL2_SV(_val)
#define GRSPWROUTER_PCTRL2_OR   0x8000U
#define GRSPWROUTER_PCTRL2_UR   0x4000U
#define GRSPWROUTER_PCTRL2_R   0x2000U
#define GRSPWROUTER_PCTRL2_AT   0x1000U
#define GRSPWROUTER_PCTRL2_AR   0x800U
#define GRSPWROUTER_PCTRL2_IT   0x400U
#define GRSPWROUTER_PCTRL2_IR   0x200U
#define GRSPWROUTER_PCTRL2_SD_SHIFT   1
#define GRSPWROUTER_PCTRL2_SD_MASK   0x3eU
#define GRSPWROUTER_PCTRL2_SD_GET(_reg)
#define GRSPWROUTER_PCTRL2_SD_SET(_reg, _val)
#define GRSPWROUTER_PCTRL2_SD(_val)
#define GRSPWROUTER_PCTRL2_SC   0x1U
#define GRSPWROUTER_RTRCFG_SP_SHIFT   27
#define GRSPWROUTER_RTRCFG_SP_MASK   0xf8000000U
#define GRSPWROUTER_RTRCFG_SP_GET(_reg)
#define GRSPWROUTER_RTRCFG_SP_SET(_reg, _val)
#define GRSPWROUTER_RTRCFG_SP(_val)
#define GRSPWROUTER_RTRCFG_AP_SHIFT   22
#define GRSPWROUTER_RTRCFG_AP_MASK   0x7c00000U
#define GRSPWROUTER_RTRCFG_AP_GET(_reg)
#define GRSPWROUTER_RTRCFG_AP_SET(_reg, _val)
#define GRSPWROUTER_RTRCFG_AP(_val)
#define GRSPWROUTER_RTRCFG_FP_SHIFT   17
#define GRSPWROUTER_RTRCFG_FP_MASK   0x3e0000U
#define GRSPWROUTER_RTRCFG_FP_GET(_reg)
#define GRSPWROUTER_RTRCFG_FP_SET(_reg, _val)
#define GRSPWROUTER_RTRCFG_FP(_val)
#define GRSPWROUTER_RTRCFG_R   0x10000U
#define GRSPWROUTER_RTRCFG_SR   0x8000U
#define GRSPWROUTER_RTRCFG_PE   0x4000U
#define GRSPWROUTER_RTRCFG_IC   0x2000U
#define GRSPWROUTER_RTRCFG_IS   0x1000U
#define GRSPWROUTER_RTRCFG_IP   0x800U
#define GRSPWROUTER_RTRCFG_AI   0x400U
#define GRSPWROUTER_RTRCFG_AT   0x200U
#define GRSPWROUTER_RTRCFG_IE   0x100U
#define GRSPWROUTER_RTRCFG_RE   0x80U
#define GRSPWROUTER_RTRCFG_EE   0x40U
#define GRSPWROUTER_RTRCFG_R   0x20U
#define GRSPWROUTER_RTRCFG_SA   0x10U
#define GRSPWROUTER_RTRCFG_TF   0x8U
#define GRSPWROUTER_RTRCFG_RM   0x4U
#define GRSPWROUTER_RTRCFG_TA   0x2U
#define GRSPWROUTER_RTRCFG_PP   0x1U
#define GRSPWROUTER_TC_RE   0x200U
#define GRSPWROUTER_TC_EN   0x100U
#define GRSPWROUTER_TC_CF_SHIFT   6
#define GRSPWROUTER_TC_CF_MASK   0xc0U
#define GRSPWROUTER_TC_CF_GET(_reg)
#define GRSPWROUTER_TC_CF_SET(_reg, _val)
#define GRSPWROUTER_TC_CF(_val)
#define GRSPWROUTER_TC_TC_SHIFT   0
#define GRSPWROUTER_TC_TC_MASK   0x3fU
#define GRSPWROUTER_TC_TC_GET(_reg)
#define GRSPWROUTER_TC_TC_SET(_reg, _val)
#define GRSPWROUTER_TC_TC(_val)
#define GRSPWROUTER_VER_MA_SHIFT   24
#define GRSPWROUTER_VER_MA_MASK   0xff000000U
#define GRSPWROUTER_VER_MA_GET(_reg)
#define GRSPWROUTER_VER_MA_SET(_reg, _val)
#define GRSPWROUTER_VER_MA(_val)
#define GRSPWROUTER_VER_MI_SHIFT   16
#define GRSPWROUTER_VER_MI_MASK   0xff0000U
#define GRSPWROUTER_VER_MI_GET(_reg)
#define GRSPWROUTER_VER_MI_SET(_reg, _val)
#define GRSPWROUTER_VER_MI(_val)
#define GRSPWROUTER_VER_PA_SHIFT   8
#define GRSPWROUTER_VER_PA_MASK   0xff00U
#define GRSPWROUTER_VER_PA_GET(_reg)
#define GRSPWROUTER_VER_PA_SET(_reg, _val)
#define GRSPWROUTER_VER_PA(_val)
#define GRSPWROUTER_VER_ID_SHIFT   0
#define GRSPWROUTER_VER_ID_MASK   0xffU
#define GRSPWROUTER_VER_ID_GET(_reg)
#define GRSPWROUTER_VER_ID_SET(_reg, _val)
#define GRSPWROUTER_VER_ID(_val)
#define GRSPWROUTER_IDIV_ID_SHIFT   0
#define GRSPWROUTER_IDIV_ID_MASK   0xffU
#define GRSPWROUTER_IDIV_ID_GET(_reg)
#define GRSPWROUTER_IDIV_ID_SET(_reg, _val)
#define GRSPWROUTER_IDIV_ID(_val)
#define GRSPWROUTER_CFGWE_WE   0x1U
#define GRSPWROUTER_PRESCALER_RL_SHIFT   0
#define GRSPWROUTER_PRESCALER_RL_MASK   0xffffffffU
#define GRSPWROUTER_PRESCALER_RL_GET(_reg)
#define GRSPWROUTER_PRESCALER_RL_SET(_reg, _val)
#define GRSPWROUTER_PRESCALER_RL(_val)
#define GRSPWROUTER_IMASK_PE   0x400U
#define GRSPWROUTER_IMASK_SR   0x200U
#define GRSPWROUTER_IMASK_RS   0x100U
#define GRSPWROUTER_IMASK_TT   0x80U
#define GRSPWROUTER_IMASK_PL   0x40U
#define GRSPWROUTER_IMASK_TS   0x20U
#define GRSPWROUTER_IMASK_AC   0x10U
#define GRSPWROUTER_IMASK_RE   0x8U
#define GRSPWROUTER_IMASK_IA   0x4U
#define GRSPWROUTER_IMASK_LE   0x2U
#define GRSPWROUTER_IMASK_ME   0x1U
#define GRSPWROUTER_IPMASK_IE_SHIFT   0
#define GRSPWROUTER_IPMASK_IE_MASK   0xffffffffU
#define GRSPWROUTER_IPMASK_IE_GET(_reg)
#define GRSPWROUTER_IPMASK_IE_SET(_reg, _val)
#define GRSPWROUTER_IPMASK_IE(_val)
#define GRSPWROUTER_PIP_IP_SHIFT   0
#define GRSPWROUTER_PIP_IP_MASK   0xffffffffU
#define GRSPWROUTER_PIP_IP_GET(_reg)
#define GRSPWROUTER_PIP_IP_SET(_reg, _val)
#define GRSPWROUTER_PIP_IP(_val)
#define GRSPWROUTER_ICODEGEN_HI   0x200000U
#define GRSPWROUTER_ICODEGEN_UA   0x100000U
#define GRSPWROUTER_ICODEGEN_AH   0x80000U
#define GRSPWROUTER_ICODEGEN_IT   0x40000U
#define GRSPWROUTER_ICODEGEN_TE   0x1U
#define GRSPWROUTER_ICODEGEN_EN   0x20000U
#define GRSPWROUTER_ICODEGEN_IN_SHIFT   6
#define GRSPWROUTER_ICODEGEN_IN_MASK   0xffc0U
#define GRSPWROUTER_ICODEGEN_IN_GET(_reg)
#define GRSPWROUTER_ICODEGEN_IN_SET(_reg, _val)
#define GRSPWROUTER_ICODEGEN_IN(_val)
#define GRSPWROUTER_ISR0_IB_SHIFT   0
#define GRSPWROUTER_ISR0_IB_MASK   0xffffffffU
#define GRSPWROUTER_ISR0_IB_GET(_reg)
#define GRSPWROUTER_ISR0_IB_SET(_reg, _val)
#define GRSPWROUTER_ISR0_IB(_val)
#define GRSPWROUTER_ISR1_IB_SHIFT   0
#define GRSPWROUTER_ISR1_IB_MASK   0xffffffffU
#define GRSPWROUTER_ISR1_IB_GET(_reg)
#define GRSPWROUTER_ISR1_IB_SET(_reg, _val)
#define GRSPWROUTER_ISR1_IB(_val)
#define GRSPWROUTER_ISRTIMER_RL_SHIFT   0
#define GRSPWROUTER_ISRTIMER_RL_MASK   0xffffffffU
#define GRSPWROUTER_ISRTIMER_RL_GET(_reg)
#define GRSPWROUTER_ISRTIMER_RL_SET(_reg, _val)
#define GRSPWROUTER_ISRTIMER_RL(_val)
#define GRSPWROUTER_AITIMER_RL_SHIFT   0
#define GRSPWROUTER_AITIMER_RL_MASK   0xffffffffU
#define GRSPWROUTER_AITIMER_RL_GET(_reg)
#define GRSPWROUTER_AITIMER_RL_SET(_reg, _val)
#define GRSPWROUTER_AITIMER_RL(_val)
#define GRSPWROUTER_ISRCTIMER_RL_SHIFT   0
#define GRSPWROUTER_ISRCTIMER_RL_MASK   0x1fU
#define GRSPWROUTER_ISRCTIMER_RL_GET(_reg)
#define GRSPWROUTER_ISRCTIMER_RL_SET(_reg, _val)
#define GRSPWROUTER_ISRCTIMER_RL(_val)
#define GRSPWROUTER_LRUNSTAT_LR_SHIFT   1
#define GRSPWROUTER_LRUNSTAT_LR_MASK   0xfffffffeU
#define GRSPWROUTER_LRUNSTAT_LR_GET(_reg)
#define GRSPWROUTER_LRUNSTAT_LR_SET(_reg, _val)
#define GRSPWROUTER_LRUNSTAT_LR(_val)
#define GRSPWROUTER_LRUNSTAT_R   0x1U
#define GRSPWROUTER_CAP_AF_SHIFT   24
#define GRSPWROUTER_CAP_AF_MASK   0x3000000U
#define GRSPWROUTER_CAP_AF_GET(_reg)
#define GRSPWROUTER_CAP_AF_SET(_reg, _val)
#define GRSPWROUTER_CAP_AF(_val)
#define GRSPWROUTER_CAP_R   0x800000U
#define GRSPWROUTER_CAP_PF_SHIFT   20
#define GRSPWROUTER_CAP_PF_MASK   0x700000U
#define GRSPWROUTER_CAP_PF_GET(_reg)
#define GRSPWROUTER_CAP_PF_SET(_reg, _val)
#define GRSPWROUTER_CAP_PF(_val)
#define GRSPWROUTER_CAP_R   0x80000U
#define GRSPWROUTER_CAP_RM_SHIFT   16
#define GRSPWROUTER_CAP_RM_MASK   0x70000U
#define GRSPWROUTER_CAP_RM_GET(_reg)
#define GRSPWROUTER_CAP_RM_SET(_reg, _val)
#define GRSPWROUTER_CAP_RM(_val)
#define GRSPWROUTER_CAP_R   0x8000U
#define GRSPWROUTER_CAP_AA   0x4000U
#define GRSPWROUTER_CAP_AX   0x2000U
#define GRSPWROUTER_CAP_DP   0x1000U
#define GRSPWROUTER_CAP_ID   0x800U
#define GRSPWROUTER_CAP_SD   0x400U
#define GRSPWROUTER_CAP_PC_SHIFT   5
#define GRSPWROUTER_CAP_PC_MASK   0x3e0U
#define GRSPWROUTER_CAP_PC_GET(_reg)
#define GRSPWROUTER_CAP_PC_SET(_reg, _val)
#define GRSPWROUTER_CAP_PC(_val)
#define GRSPWROUTER_CAP_CC_SHIFT   0
#define GRSPWROUTER_CAP_CC_MASK   0x1fU
#define GRSPWROUTER_CAP_CC_GET(_reg)
#define GRSPWROUTER_CAP_CC_SET(_reg, _val)
#define GRSPWROUTER_CAP_CC(_val)
#define GRSPWROUTER_PNPVEND_VI_SHIFT   16
#define GRSPWROUTER_PNPVEND_VI_MASK   0xffff0000U
#define GRSPWROUTER_PNPVEND_VI_GET(_reg)
#define GRSPWROUTER_PNPVEND_VI_SET(_reg, _val)
#define GRSPWROUTER_PNPVEND_VI(_val)
#define GRSPWROUTER_PNPVEND_PI_SHIFT   0
#define GRSPWROUTER_PNPVEND_PI_MASK   0x3ffffffU
#define GRSPWROUTER_PNPVEND_PI_GET(_reg)
#define GRSPWROUTER_PNPVEND_PI_SET(_reg, _val)
#define GRSPWROUTER_PNPVEND_PI(_val)
#define GRSPWROUTER_PNPUVEND_VI_SHIFT   16
#define GRSPWROUTER_PNPUVEND_VI_MASK   0xffff0000U
#define GRSPWROUTER_PNPUVEND_VI_GET(_reg)
#define GRSPWROUTER_PNPUVEND_VI_SET(_reg, _val)
#define GRSPWROUTER_PNPUVEND_VI(_val)
#define GRSPWROUTER_PNPUVEND_PI_SHIFT   0
#define GRSPWROUTER_PNPUVEND_PI_MASK   0x3ffffffU
#define GRSPWROUTER_PNPUVEND_PI_GET(_reg)
#define GRSPWROUTER_PNPUVEND_PI_SET(_reg, _val)
#define GRSPWROUTER_PNPUVEND_PI(_val)
#define GRSPWROUTER_PNPUSN_SN_SHIFT   0
#define GRSPWROUTER_PNPUSN_SN_MASK   0xffffffffU
#define GRSPWROUTER_PNPUSN_SN_GET(_reg)
#define GRSPWROUTER_PNPUSN_SN_SET(_reg, _val)
#define GRSPWROUTER_PNPUSN_SN(_val)
#define GRSPWROUTER_PNPNETDISC_ND_SHIFT   0
#define GRSPWROUTER_PNPNETDISC_ND_MASK   0xffffffffU
#define GRSPWROUTER_PNPNETDISC_ND_GET(_reg)
#define GRSPWROUTER_PNPNETDISC_ND_SET(_reg, _val)
#define GRSPWROUTER_PNPNETDISC_ND(_val)
#define GRSPWROUTER_MAXPLEN_ML_SHIFT   0
#define GRSPWROUTER_MAXPLEN_ML_MASK   0x1ffffffU
#define GRSPWROUTER_MAXPLEN_ML_GET(_reg)
#define GRSPWROUTER_MAXPLEN_ML_SET(_reg, _val)
#define GRSPWROUTER_MAXPLEN_ML(_val)
#define GRSPWROUTER_CREDCNT_OC_SHIFT   6
#define GRSPWROUTER_CREDCNT_OC_MASK   0xfc0U
#define GRSPWROUTER_CREDCNT_OC_GET(_reg)
#define GRSPWROUTER_CREDCNT_OC_SET(_reg, _val)
#define GRSPWROUTER_CREDCNT_OC(_val)
#define GRSPWROUTER_CREDCNT_IC_SHIFT   0
#define GRSPWROUTER_CREDCNT_IC_MASK   0x3fU
#define GRSPWROUTER_CREDCNT_IC_GET(_reg)
#define GRSPWROUTER_CREDCNT_IC_SET(_reg, _val)
#define GRSPWROUTER_CREDCNT_IC(_val)
#define GRSPWROUTER_GPO_GPO_SHIFT   0
#define GRSPWROUTER_GPO_GPO_MASK   0xffffffffU
#define GRSPWROUTER_GPO_GPO_GET(_reg)
#define GRSPWROUTER_GPO_GPO_SET(_reg, _val)
#define GRSPWROUTER_GPO_GPO(_val)
#define GRSPWROUTER_GPI_GPI_SHIFT   0
#define GRSPWROUTER_GPI_GPI_MASK   0xffffffffU
#define GRSPWROUTER_GPI_GPI_GET(_reg)
#define GRSPWROUTER_GPI_GPI_SET(_reg, _val)
#define GRSPWROUTER_GPI_GPI(_val)
#define GRSPWROUTER_RTCOMB_SR   0x80000000U
#define GRSPWROUTER_RTCOMB_EN   0x40000000U
#define GRSPWROUTER_RTCOMB_PR   0x20000000U
#define GRSPWROUTER_RTCOMB_HD   0x10000000U
#define GRSPWROUTER_RTCOMB_PE_SHIFT   1
#define GRSPWROUTER_RTCOMB_PE_MASK   0xffffffeU
#define GRSPWROUTER_RTCOMB_PE_GET(_reg)
#define GRSPWROUTER_RTCOMB_PE_SET(_reg, _val)
#define GRSPWROUTER_RTCOMB_PE(_val)
#define GRSPWROUTER_RTCOMB_PD   0x1U
#define GRSPWROUTER_APBAREA_APB_SHIFT   0
#define GRSPWROUTER_APBAREA_APB_MASK   0xffffffffU
#define GRSPWROUTER_APBAREA_APB_GET(_reg)
#define GRSPWROUTER_APBAREA_APB_SET(_reg, _val)
#define GRSPWROUTER_APBAREA_APB(_val)
typedef struct grspwrouter_portstats grspwrouter_portstats
typedef struct grspwrouter grspwrouter
